To create a JMS Topic in the Transaction Server Application:
Log on to the WebLogic Admin Console.
To create a JMS Topic for your JD Edwards EnterpriseOne, navigate to Home Page > Services > Messaging > JMS Modules, select your JMS Module and click the New button.
On Create a New JMS System Module Resource, select the radio button for Topic.
The process for creating the Connection Factory for this topic is the same as the JMS Connection Factory created for the queue. Ensure you use the same values as the ones used when setting up your JMSTOPIC Subscriber in P90702A.
