Although it is supported it is not recommended that you create the subscriber queue in the Transaction Server container. This section describes the recommendation, which is to create the a subscriber JMS queue on a WebLogic Server other than the Transaction Server.
This appendix describes these tasks:
To create the JMS Server:
From the WebLogic Administration Console, select the domain in which you want to create the JMS Server.
Click on YourDomain > Services > Messaging > JMS Servers
In the right panel click the New button.
On Create a New JMS Server, enter a value for the name of the JMS server to be created. In this guide, the name is Test-JMSServer.
Use the pulldown to select the Persistence Store.
If Persistence Store does not exist you must create a new Persistence Store by clicking the Create a New Store button.Click the Next button.
On Create a New JMS Server, select the Weblogic server node and click the Finish button.
As shown below, at this point using the example in this guide a JMS server called Test-JMSServer is created. This Test-JMSServer is targeted to AdminServer. However this can be targeted to any other container available, which may not necessarily be AdminServer
To create a subscriber queue on WebLogic Server:
In the WebLogic Administration Console, select the domain into which you want to create the JMS Module.
Click on YourDomain > Services > Messaging > JMS Modules
On Create JMS System Module, enter a value for the name of the JMS module to be created. In this guide, the name is Test-SystemModule.
On Create JMS System Module, select the target of Weblogic server node.
Click the Finish button.
As shown below at this point, using the example in this guide, the Test-SystemModule is created. This Test- SystemModule is targeted to AdminServer. However this can be targeted to any other container .
Use this procedure to create a JMS resource such as connection factory, queue, or topic in the JMS Module you created in the previous section.
To create a JMS Resource:
Click the JMS Module where you want to create a resource (in this guide Test-SystemModule).
On Settings for <Module_Name> , click the New Button.
On Create a New JMS System Module Resource, select the radio button for the resource type to be created. In this example, Connection Factory is selected.
On Create a New JMS System Module Resource, enter Connection Factory name and JNDI name for this Connection Factory.
On Create a New JMS System Module Resource, use the pulldown to select the Subdeployment. If no existing Subdeployment can be used click on Create a New Subdeployment button.
On Create a New Subdeployment, enter a name for a new Subdeployment.
Click the OK button.
On Create a New JMS System Module Resource, click the checkbox next to the JMS Server for which you just created a resource.
On Create a New JMS System Module Resource, click the radio button for Queue.
On Create a New JMS System Module Resource, enter a I and JNDI Name for this Queue.
On Create a New JMS System Module Resource, select the Subdeployment.
As shown below, verify that both the xxxx
