Use this procedure to upgrade the Transaction Server RTE component that was installed using Server Manager.
Obtain the RTE software component to which you wish to upgrade from Oracle eDelivery.
Place the new RTE component into this folder:
<AGENT_LOC>\components
Log on to the Server Manager console.
Click on the RTE instance.
In the Software Component Version section, click the Change button.
On the Change Tools Release layout, select the desired version to install from the component by selecting the radio button.
Click the Change Component button.
An upgrade of RTE server only upgrades the Transaction Server RTE component of JD Edwards, and not the JMS components.Refer to the JD Edwards EnterpriseOne Server Manager Guide to upgrade the Server Manager Agent. You can only update the Server Manager Agent after you have upgraded the Server Manager Console to Tools Release 9.1.
