After you have used Server Manager to install your Tools Release to an IBM i-based Enterprise Server, as in previous JD Edwards EnterpriseOne Tools Releases, you must re-link the Business Functions.
For each path code, re-link the business functions located in the associated IBM i library. The program LINKBSFN is delivered with the installation of each Tools Release to simplify this process. The following commands must be executed against each full package for a specified path code.
Run LINKBSFN against the full package of the path code.
LINKBSFN
After you have entered the LINKBSFN command, press F4 to display the system prompt. Enter the package library name for the first parameter and the path code for the second parameter.
Wait until the previous step completes successfully before continuing to the next step. Repeat this step for every package and path code you are updating.
