If you are upgrading your IBM i to JD Edwards EnterpriseOne Release 9.1 with Tools Release 9.1, you must make modifications to the jde.ini file. These changes are required to enable successful builds of applications business functions on the IBM i machine.
You must add the following bold sections to your existing jde.ini setting on your IBM i JD Edwards EnterpriseOne Enterprise Server.
[BSFN BUILD] LinkLibraries=JDEUNICODE JDELIB JDEKRNL OWVER V_VERIFY XERCESWRAP
In yourjde.ini file, you should enter this command line for CRTSRVPGM.[AS400] CRTSRVPGM=CRTSRVPGM SRVPGM(%ls/%ls) MODULE(%ls/*ALL) BNDSRVPGM(JDEUNICODE JDELIB JDEKRNL OWVER V_VERIFY XERCESWRAP) EXPORT(*ALL) OPTION(*DUPPROC *DUPVAR *UNRSLVREF) ALWLIBUPD(*YES) TGTRLS(*CURRENT)
You should enter the above command line as a single contiguous string.
