This applies to customers who use the Vertex Quantum Payroll Tax and Vertex Sales Tax Q Series (formerly Quantum for Sales and Use Tax) applications with JD Edwards EnterpriseOne.
These are the business functions that you may need to rebuild after applying Tools Release 9.1.
| Business Function | Description |
| B0700058 | Establish connection to Vertex |
| B0000182 | Initialize environment for vendor business functions |
| B0000183 | Free environment for vendor business function |
| B7300004 | Retrieve Quantum GeoCodes |
| B7300002 | Validate Quantum GeoCodes |
| B7300012 | Retrieve Quantum software information |
| X00TAX | Calculate and edit tax amounts |
For more information about using Vertex Quantum applications with ERP, see Configuring JD Edwards EnterpriseOne for Use with Vertex Quantum Tax Applications in the JD Edwards EnterpriseOne Applications Release Installation Guide or JD Edwards EnterpriseOne Applications Release Upgrade Guide, for Applications Release 9.0 or 9.1, as applicable.
Refer to the Section 1.4, "Accessing Minimum Technical Requirements" to verify the supported versions of Vertex which vary according to platform.
