This chapter contains the following topics:
This section discusses these topics:
Overview of Web Client
Web Client Architecture
Web Client Certified Platforms
Additional References
JD Edwards EnterpriseOne end users access all applications through the web client via a web browser. The HTML server delivers the user interface to the web browser as HTML and JavaScript. The user interface is highly interactive, allowing the end user not only to simply enter and retrieve transactional data, but also to personalize the interface, set lists of favorites, view business intelligence reports, and aggregate content from other external web sources.
There are no requirements to install additional components on the end-user's desktop; all interaction with the JD Edwards EnterpriseOne applications takes place through the web browser. Certain JD Edwards EnterpriseOne functionality, such as the ability to import/export data to/from the grid, may require third party software such as Microsoft Office to be installed on the users' desktops; however, such features are generally optional.
Web Client is certified to run on the following platforms:
Microsoft Windows /x86-64 (32-bit or 64-bit desktop operating systems)
Internet Explorer
Firefox
Chrome
Apple Mac OS
Firefox
Oracle Certification: https://support.oracle.com, Certifications tab
Product = JD Edwards EnterpriseOne Web Client
Overview of Mobile Applications
Mobile Applications Architecture
Mobile Applications Certified Platforms
JD Edwards EnterpriseOne mobile applications provide users in the field access to timely and critical data to meet their business needs and quickly and efficiently perform tasks, such as:
Entering expense reports
Reviewing and approving expense reports
Reviewing and approving purchase orders
Reviewing and approving requisitions entered through Requisition Self Service
Reviewing current and historical sales orders
Querying item price and availability information
The mobile applications were developed using Oracle Application Development Framework Mobile (ADF Mobile), a component of Oracle Fusion Middleware
JD Edwards EnterpriseOne mobile architecture takes advantage of Oracle's Application Development Framework for Mobile which allows the mobile applications to be an extension of the EnterpriseOne application suite. In order to ensure data integrity across your system, the mobile applications leverage the same business logic and interact with the same data tables as the existing JD Edwards EnterpriseOne web applications. Each application adjusts to the unique mobile device transparently delivering the same functionality no matter which device is used.
Mobile Client is certified to run on the following platforms:
Apple iOS
BlackBerry
Android
Product = JD Edwards EnterpriseOne Mobile Client
JD Edwards EnterpriseOne Mobile Applications Installation and Configuration Guide
Overview of Development Client
Development Client Architecture
Development Client Certified Platforms
The JD Edwards EnterpriseOne development client (also known as a Web Development Client, Fat Client, Administrative Client, Windows client, or Workstation) contains components that run as standard Microsoft Windows applications (for example, Active Console, Forms Design Aid (FDA), and Report Design Aid (RDA)) and components that run in a web browser.
This document uses the following terminology when discussing JD Edwards EnterpriseOne clients:
Web Client - Components that run in a web browser.
Development Client - Composed of standard Windows components and Web Client.
The Web Client part of the Development Client runs inside an application server that is installed locally on the development client. The local application server allows the developer to preview web applications on the desktop before deploying them to the production environment.
The supported Application Servers are:
Oracle Application Server (OAS)
IBM WebSphere Application Server (WAS) Express or WebSphere Application Server for Developers.
The development client also uses a locally installed database, which stores local versions of objects that are under development. An integrated object management facility controls the check-out, check-in, and promotion of objects throughout their lifecycle.
Figure 9-4 Development Client Architecture
Development Client is certified to run on the following platforms:
Microsoft Windows /x86-64 (64-bit) desktop operating systems
Local Web Application Server
IBM WebSphere Application Server Express
IBM WebSphere Application Server for Developers
Local Database
Oracle Database
Compiler
Microsoft Visual Studio
Product: jD Edwards EnterpriseOne Development Client
JD Edwards EnterpriseOne Tools Development Tools Overview Guide
JD Edwards EnterpriseOne Tools Development Guidelines for Application Design Guide
JD Edwards EnterpriseOne Tools Development Standards for Business Function Programming Guide
Tools Release 9.1.x and Applications Release 9.0 or 9.1 for Microsoft Windows
Applications Release 9.0 or 9.1 and Tools Release 9.1.x for Oracle Application Server (OAS) and WebSphere Application Server (WAS) Express
JD Edwards EnterpriseOne 9.1.X Web Client Support Statement (Doc ID 1487909.1)
