This chapter contains the following topics:
This guide describes the configuration of the Application Interface Services (AIS) Server which provides the communication interface between JD Edwards EnterpriseOne ADF enterprise applications and JD Edwards EnterpriseOne. It also contains information about additional setup tasks that must be performed in EnterpriseOne to determine the data that ADF users can access and work with in ADF enterprise applications.
As you read through the contents of this guide and the Oracle® Fusion Middleware: Developing Applications for Oracle Weblogic Server 12c Release 1 (12.1.1) guide, use the following list of tasks as a checklist for setting up ADF enterprise applications:
Setting Up and Configuring AIS Server
Setting Up and Configuring ADF
Building and Deploying EnterpriseOne ADF Applications
Building and Deploying EnterpriseOne ADF Container
The following list contains references to the minimum technical requirements for the AIS Server for ADF:
Customers must conform to the supported platforms for the AIS Server, which can be found in the Certifications tab on My Oracle Support: https://support.oracle.com.
For more information about JD Edwards EnterpriseOne Minimum Technical Requirements, see the following document on My Oracle Support:
JD Edwards EnterpriseOne Minimum Technical Requirements Reference:
See certifications for JD Edwards EnterpriseOne ADF Foundation.
