Translating PeopleTools
This chapter provides an overview of PeopleTools translation, lists prerequisites, and discusses how to:
Click to jump to parent topicUnderstanding PeopleTools Translation
The PeopleSoft system provides utilities and methods for translating all definitional application objects, such as pages and reports, built using PeopleTools. There are some PeopleTools components that are visible to end-users and should be translated as well. These include messages issued by the Application Server, the Windows components of PeopleTools (such as the PS/nVision designer and PeopleSoft Query) and images used for standard navigation in the PeopleSoft Pure Internet Architecture.
This chapter explains the different translatable PeopleTools components, and how you can customize the translations delivered by the PeopleSoft system or translate PeopleTools into new languages.
See Also
Using Global Reporting and Data Analysis Tools
Click to jump to parent topicPrerequisites
Before you begin modifying or creating new translations of PeopleTools, ensure that you have the required files and software tools.
This section discusses:
To modify translations of PeopleTools or to translate PeopleTools into a new language, you must have installed the PeopleTools Language Development Kit. When you install PeopleTools, you have the option to install the PeopleTools Language Development Kit when you install the file server. If you have installed this kit, you will find a directory PS_HOME\SRC\RES on your file server. You can install the PeopleTools Language Development Kit at any time − if this directory does not exist on the file server where you are planning to perform the translation, rerun the PeopleTools setup program and select only this option.
The PeopleSoft system provides source code to the English language resource files and selected local language resources. It also supports header files that you need in order to produce alternate language DLLs. The PeopleSoft system also provides batch files to automate the resource compilation process.
In addition to the source code to the resource files that are delivered in the PeopleTools Language Development Kit, the PeopleSoft system delivers precompiled alternate language DLLs for each language provided by the PeopleSoft system. These are installed by selecting the PeopleTools Language Pack from the PeopleTools installer. If you intend on using a translation that PeopleSoft provides but don’t plan on modifying PeopleTools translations, you only need to install the language pack, not the Language Development Kit.
The tools that you need to customize Microsoft Windows resources are part of Microsoft’s Visual C++ compiler package. You won’t have to change or compile any C++ code, but you must use the resource compiler and linker. If you are translating any resources other than strings, you must use the Microsoft Developer Studio.
See Also
PeopleTools 8.52 Hardware and Software Requirements
Click to jump to parent topicUsing Alternate Language DLLs
Although the majority of PeopleTools user interface elements viewed by the end user are stored in the database, PeopleTools executable modules do contain some translatable elements. When running PeopleTools components (such as the application server, PS/nVision, and PeopleSoft Query) on Microsoft Windows, the translations are read from alternate language DLLs. An alternate language DLL is a file that stores translated strings for an associated PeopleTools module, a DLL or EXE file. At run time, the system uses the resources in the alternate language DLLs that correspond to the user’s language preference.
The PeopleSoft system uses a naming convention that includes the name of the base executable (an executable with English strings) and the language code that identifies the language of the alternate language DLL. An alternate language DLL is named as follows:
PSZZZXXX.dll
ZZZ
Three-character code that identifies the PeopleTools module associated with the alternate language DLL.
XXX
Three-character code that identifies the language of the alternate language DLL.
The following diagram illustrates the structure and execution flow of a base module (psmod.dll) and its French alternate language DLL (PSMODFRA.dll). The base executable, psmod.dll, contains all executable code plus English strings. The alternate language DLL is used only to store translated resources. Program execution follows this flow:
  1. The system calls psmod.
  2. The session language is determined: English (ENG) or French (FRA).
  3. In both cases, psmod.dll is executed.
  4. Execution of psmod.dll requests a string.
  5. If the session language is English, psmod.dll retrieves the English string from itself, psmod.dll.
  6. If the session language is French, then the system determines whether the alternate language DLL, PSMODFRA.dll exists.
  7. If the alternate language DLL exists, then psmod.dll retrieves the French string from PSMODFRA.dll.
  8. If the alternate language DLL does not exist, psmod.dll retrieves the English string from itself, psmod.dll.
Structure and execution flow psmod.dll and PSMODFRA.dll
Click to jump to parent topicLocating Resource Directories
Alternate language DLLs must be present on all application servers. PeopleTools development environments in a three-tier installation also must have the alternate language DLLs present.
Microsoft Windows application servers and PeopleTools development environment workstations use Microsoft Windows resources from the base language and alternate language DLLs. Unix/Linux application servers, however, store resources for all languages and modules in a single file, PSAPPSERV.RES. This file contains the same resources as the alternate language DLLs.
The following table shows the content of the directories that are used to support translated resources. These directories are distributed with PeopleTools and contain user-customizable resource files and other supporting files that are needed to compile, bind, name, and copy alternate language resource DLLs.
Directories and Files
Purpose
\SRC\RES
The root directory for alternate language resource DLLs. The files in this directory include some batch files that are used in constructing alternate language DLLs.
\SRC\RES\ENG
A prototypical alternate language development directory for the English language. One of these directories exists for each alternate language. Copy this directory for each new alternate language that you create.
\SRC\RES\ENG\INC
Holds header (.H) files that are common to several DLLs and various icons and bitmaps.
\SRC\RES\ENG\xxxxx
This directory contains directories for most PeopleTools DLL and EXE files found in \SRC\BIN. These directories contain the following file types:
  • *.RCX: string table resource files.
  • *.RC: menu and dialog box resource files.
  • *.CUR: cursors.
  • *.H: header files containing resource identifiers.
  • *.BMP: bitmap files used for icons and other graphical components.
  • *.ICO: icon files for Microsoft Windows Explorer.
See Also
Compile Translated Resource Files Using MAKEUNIX.BAT
Click to jump to parent topicTranslating Resource Files
To translate resource files into a new language, copy the source code for the English translations provided by the PeopleSoft system and use this as a starting point for the new language. Alternatively, if you are only making minor modifications to an existing translation provided by the PeopleSoft system (such as to change terminology), you can use any of the languages provided by the PeopleSoft system as a starting point. This section assumes that you are using the English translations as your start, and that you’re adding a new translation.
Note. The PeopleSoft system provides pre-translated PeopleTools alternate language DLLs for many languages. You must follow these steps only if you want to translate PeopleTools into a language that is not provided by the PeopleSoft system or if you want to modify one of the provided translations.
Click to jump to top of pageClick to jump to parent topicTranslating Resource Files
To translate resource files:
  1. Determine the three-letter designation of the new language.
    In this example, QUE is the designation for Quechua. For consistency in referring to languages throughout the system, use one of the standard code values stored in the Translate table for the LANGUAGE_CD field. The PeopleSoft system does not use standard ISO codes for languages, but three-letter codes instead. You can decide the appropriate three-letter code for your language, but you should ensure that it is consistently used across PeopleTools whenever you use this language.
    See Adding New Languages.
  2. Copy the contents of \SRC\RES\ENG to the target resource directory.
    For Quechua, the target resource directory is \SRC\RES\QUE.
  3. Use Microsoft Developer Studio to convert the English resources to the alternate language.
    A text editor is adequate to change string resources contained in the *.RCX files, however when modifying *.RC files that contain Microsoft Windows dialog boxes and other graphical elements, you should use the resource editor provided in Microsoft Developer Studio bundled with Microsoft Visual C++. The resource editor enables you to size and position elements in dialog boxes and to edit bitmaps, cursors, and other graphic components of the resource files.
  4. Set up the environment variables.
    Before compiling your translated resource files, you must set the appropriate environment variables for the C++ resource compiler. Typically, Microsoft Visual C++ provides a batch file, VCVARS32.BAT, which sets the variables for you. In addition to the variables set in this batch file, set the environment variable TOOLBIN to the PS_HOME\BIN\CLIENT\WINX86 directory of your file server, and append the PS_HOME\SRC\RES\ENG\INC directory to the environment variable INCLUDE.
  5. Compile alternate language DLLs using MAKEALTL.BAT.
  6. (Microsoft Windows application servers only) Copy the resultant alternate language DLLs to the BIN\SERVER\WINX86 directory of your Microsoft Windows application server.
  7. (Unix/Linux application servers only) Compile Unix/Linux application server resources and transfer to the Unix/Linux application server.
    If you are using a Unix/Linux application server, you must run MAKEUNIX.BAT to compile the resource files into a format that is readable by the Unix/Linux application server.
Note. If you have changed any menu item text, update the Security settings to give users access to the menu items.
See Also
Compiling Translated Resource Files Using MAKEALTL.BAT
Click to jump to top of pageClick to jump to parent topicCompiling Translated Resource Files Using MAKEALTL.BAT
The MAKEALTL.BAT file calls the Microsoft Visual C++ Resource Compiler and Linker to compile translated resources into a Windows DLL. Before running MAKEALTL.BAT, ensure that the environment variables required by the Resource Compiler and Linker are set correctly in your current DOS window. This table describes and shows an example of these environment variables:
Environment Variable
Description
Example
%path%
Must include the Microsoft Visual C++ executables directory.
C:\MSDEV\BIN
%include%
Must include the Microsoft Visual C++ INC directory and the Microsoft Foundation Classes (MFC) BIN directory. It must also include a copy of the PeopleTools resource include directory.
C:\MSDEV\INC C:\MSDEV\MFC\INC C:\PT850\SRC\RES\ENG\INC
%lib%
Must include the Microsoft Visual C++ library directory.
C:\MSDEV\LIB
%toolbin%
Must point to the directory containing the PeopleTools executables.
C:\PT850\BIN\CLIENT\WINX86
For customer builds the PS_HOME\res\stinggray directory should exist and the PS_HOME variable must be set. For internal builds the ..\src\inc\nonps\stingray directory should exist, and the variable PSVER must be set.
If neither of them exist you can set CUSTOMER_BUILD to NO. For example in Microsoft windows:
set CUSTOMER_BUILD=NO
In addition, set the PSVER variable.
Once you have verified that the variables in the table above are correct, you can run MAKEALTL.BAT.
To run MAKEALTL.BAT:
  1. In a DOS window, go to the SRC\RES directory.
  2. Run the MAKEALTL batch file with language and PeopleTools_module parameters.
    This process compiles the resources into language-specific DLLs and copies the files to your PeopleTools executables directory.
    The syntax of the command is as follows:
    MAKEALTL ​language ​PeopleTools_module
Click to jump to top of pageClick to jump to parent topicCompile Translated Resource Files Using MAKEUNIX.BAT
MAKEUNIX.BAT compiles the translated resources into a single file that is readable by the PeopleSoft Unix/Linux application servers. It reads the same translated resources as MAKEALTL.BAT, but instead of producing a separate DLL for each language/module combination, MAKEUNIX.BAT produces a single indexed resource file called PSAPPSRV.RES.
To run MAKEUNIX.BAT, you must also have the Microsoft Visual C++ development environment installed on your workstation. MAKEUNIX.BAT calls the C++ compiler to parse the resource files from all languages and to create PSAPPSRV.RES. In addition to the environment variables that are required to run MAKEALTL.BAT, MAKEUNIX.BAT requires that you set the %PSVER% environment variable. Set this variable to the base directory in which you installed PeopleTools.
If you have added any new languages as part of your PeopleTools translations, you must edit MAKEUNIX.BAT to include the new languages so that they are included in the PSAPPSRV.RES file.
To run MAKEUNIX.BAT:
  1. Open a DOS command prompt window.
  2. Change the directory to your \PT850\RES directory.
  3. Run the MAKEUNIX batch file.
    MAKEUNIX doesn’t require that you pass the module or language name arguments; it compiles the Unix/Linux application server resources for all languages and modules in one pass.
    The output from MAKEUNIX.BAT, and PSAPPSRV.RES is placed in PS_HOME\APPSERV\UNIX. You must transfer PSAPPSRV.RES to the BIN directory of your Unix/Linux application server using a network file transfer utility, such as FTP.
Click to jump to parent topicTranslating Objects
Not all translatable elements used internally by PeopleTools can be contained in resource files. Some strings referenced by Java and other components of PeopleTools are stored in Java-style property files. The PeopleSoft Pure Internet Architecture makes use of images for many navigational and user interface elements. Some of these images contain text which must also be translated.
Click to jump to top of pageClick to jump to parent topicTranslating Properties Files
Java components of PeopleTools, such as the servlets on the web server, derive some strings from Java-style properties files. Java properties files are simple text files that are read at runtime by the servlet; these files contain strings that are displayed to the user, typically in error messages.
These files can be translated using any standard text editor, and are located on the web server. This table show the files that contain translatable text:
Base Properties File
Translated Properties File
text.properties
text_language_code.properties
errors.properties
errors_language_code.properties
The base version of the file (without a language code) contains the English version of the strings. Copy this file to a new file containing the language code of your target language before translating the contents. For example, if you are translating the resources into Quechua, you would create text_QUE.properties and errors_QUE.properties, and update these files with Quechua translations of the contents.
When translating into a language that cannot be represented by the Latin-1 character set, such as Japanese, Chinese and Korean, the contents of the Java properties files must be converted into escaped Unicode character references. The Java Development Kit (JDK) contains the native2ascii utility that you can use to convert Unicode character references in a Java properties file into a native character set and vice versa. Refer to the native2ascii utility documentation in the JDK for more information.
Click to jump to top of pageClick to jump to parent topicTranslating Images
The PeopleSoft Pure Internet Architecture uses many images as part of its user interface component, and some of these images contain text. You will typically translate only images that contain textual elements or elements that are specific to one language or culture.
Translating an Image
To translate an image:
  1. Change the PeopleSoft Configuration Manager language preference to the target language.
  2. Open Application Designer.
  3. Open the image.
    Choose File, Open and select the image you want to open.
  4. Export the image to a file.
    From the File menu, select Export Image and then select a filename and image format to save the image to disk.
  5. Use a graphics editor to modify the saved image file and update the translation.
  6. From the Edit menu, select Update Image.
    A standard Open dialog box appears.
  7. Open the file with the translated image.
    The new graphic replaces the original graphic in the image.
  8. Save the image.
    The translated image is saved into the related language table under the language that you selected in the Configuration Manager in the first step.
