Sending and Receiving Messages
This chapter discusses how to:
Click to jump to parent topicUnderstanding Sending and Receiving Messages
To send and receive messages you use PeopleCode to:
You can also send messages directly to the integration gateway, thereby bypassing processing on the integration engine.
Note. The code examples in this chapter are for illustrative purposes only and are not intended to be used in a production environment.
Click to jump to top of pageClick to jump to parent topicPrerequisites for Sending and Receiving Messages
Before you can define PeopleCode to generate, send, receive, and process messages, you must define the message in PeopleSoft Internet Architecture.
Note. Once you create PeopleCode, you must also define nodes, services and service operations to implement a complete integration.
See Understanding PeopleSoft Integration Broker Metadata.
Click to jump to top of pageClick to jump to parent topicMessaging Process Flows
The integration engine uses asynchronous request processes and synchronous request processes to manage outbound and inbound messages. These processes examine the messaging elements that you create to determine how to treat each message.
Outbound Message Processing Flow
This section discusses message processing flow for outbound messages. In this section, the term process is used, and refers to either the integration engine's asynchronous request process or its synchronous request process, depending on the type of integration you are preforming.
Outbound messages you send go through the following steps.
  1. The application triggers the sending PeopleCode that you developed.
  2. The PeopleCode program populates and sends the message by using an asynchronous or synchronous method.
  3. The method that the PeopleCode uses to send the message triggers a request process in the application’s integration engine.
  4. The process searches the outbound routings that are associated with that service operation to determine the valid target nodes for the message.
    The asynchronous process examines only asynchronous routings, and the synchronous process examines only synchronous routings. If for synchronous processing, a valid single outbound routing cannot be found, the sending method returns an error.
    Note. Only active routings are considered for processing.
  5. For each outbound routing that it finds, the process submits the message to the local gateway, along with transaction information about the node and the target connector that should be used to send the message.
  6. The local gateway transmits the message to the specified target node through the specified target connector.
  7. If this is a synchronous message, the process waits for the target node to pass a response message back through the gateway, then returns it to the calling PeopleCode method.
Inbound Message Processing Flow
Each received message goes through the following steps:
  1. The application’s gateway receives a request message from a remote node or gateway, which specifies the application as its target node.
  2. The gateway submits the message to the application’s integration engine, which searches for any inbound request routing parameter which has the same alias name as the external operation name passed in.
  3. If a matching routing alias name isn’t found, the integration engine returns an error message through the gateway to the sending node.
    If a routing alias name is found, the integration engine invokes either the asynchronous request process or the synchronous request process, as appropriate, to handle the message.
    Note. Any inbound routing alias that is found must have the proper permissions for that service operation for the process to proceed.
  4. The process accesses the service operation that matches the routing alias name and passes the message to the service operation's handler associated with receiving PeopleCode.
  5. If this is a synchronous transaction, the process waits for the receiving PeopleCode to generate and return a response message, then passes it back to the sending node through the gateway.
Click to jump to parent topicUnderstanding Integration PeopleCode
This section discusses the PeopleCode used for integrations and describes:
Click to jump to top of pageClick to jump to parent topicSending and Receiving PeopleCode
This section discusses the PeopleCode you use for sending messages from PeopleSoft Integration Broker to other systems, and the PeopleCode you use for receiving messages from other systems.
Sending PeopleCode
PeopleCode for sending messages can be located in PeopleCode events associated with records, record fields, and components, and in application engine programs.
The PeopleCode method used to send messages is highlighted in the following table.
Transmission Type
Sending PeopleCode
Comments
Synchronous
SyncRequest method.
The SyncRequest method belongs to the IntBroker class.
Asynchronous
Publish method.
The Publish method belongs to the IntBroker class.
To work with rowset-based messages in SOAP format, transform the SOAP documents into XML documents and then use the IntBroker class SyncRequest or Publish methods. To work with nonrowset-based messages in SOAP format use the SOAPDoc class.
The PeopleCode that you use to receive a message must be associated with the message definition. The transmission type of the message determines the location of the PeopleCode program.
Implement the OnRequest method for synchronous messages. Implement the OnNotify method for asynchronous messages. Both methods are located in the PS_PT application package, in the Integration sub-package, in the IRequestHandler and INotificationHandler classes, respectively.
Transmission Type
Message Structure
Comments
Synchronous
Rowset-based
Message is passed into the method.
Implement the OnRequest method in the IRequestHandler application interface.
Synchronous
Nonrowset-based
Asynchronous
Rowset-based
Implement the OnNotify method in the INotificationHandler application interface.
Asynchronous
Nonrowset-based
To get content data out of a request message, use the following guidelines.
Message Structure
PeopleCode
Comments
Rowset-based
GetRowSet method.
None.
Nonrowset-based
GetXMLDoc method.
You can also use Message class functionality with nonrowset-based messages.
See Using Message Object Functionality With Nonrowset-Based Messages.
Click to jump to top of pageClick to jump to parent topicApplication Classes
Application classes house the processing logic for asynchronous and synchronous messages. By implementing the Integration Broker application classes, you can reuse code and access other benefits of application classes.
The following application classes exist for PeopleSoft Integration Broker. See the individual applicable application class interfaces for more information about the methods contained in an application class.
To access these application classes, in PeopleSoft Application Designer, open the PS_PT application package and open the Integration subpackage.
Note. All of the Integration Broker application classes are defined as interfaces. This means that there is no native implementation of them: you must import them to your program and implement them if you want to use them.
Application Class
Methods Contained in Application Class
Comments
  • OnNotify
  • OnError
This interface is the equivalent of the Subscription Message event PeopleTools releases prior to PeopleTools 8.48.
IReceiver
  • OnAckReceive
  • OnError
This interface is the equivalent of the OnAckReceive Message event in PeopleTools releases prior to PeopleTools 8.48.
IRequestHandler
  • OnRequest
  • OnError
This interface is the equivalent of the OnRequest Message event in PeopleTools releases prior to PeopleTools 8.48.
IRouter
  • OnRouteSend
  • OnRouteReceive
  • OnError
This interface is the equivalent of the OnRouteSend and OnRouteReceive Message events in PeopleTools releases prior to PeopleTools 8.48.
ISend
  • OnRequestSend
  • OnError
This interface is the equivalent of the OnSend Message event in PeopleTools releases prior to PeopleTools 8.48.
Each of the methods contained in these application classes is described in this section.
Click to jump to top of pageClick to jump to parent topicRouting Methods
Routing methods determine how a message is routed to or from PeopleSoft Integration Broker.
OnRouteSend Method
Implement the OnRouteSend method for outbound synchronous and asynchronous service operations to specify to what node PeopleSoft Integration Broker routes a message. The implementation of this method enables you to apply PeopleCode that filters the destination nodes to which PeopleSoft Integration Broker routes messages.
The OnRouteSend method is contained in the IRouter application class, which is contained in the PS_PT application package, in the Integration subpackage.
When the application PeopleCode is invoked to send a message, the routing definitions in the local database provide a list of target nodes to which PeopleSoft Integration Broker can route the message. The integration engine’s request handler invokes the service operation's OnRouteSend event. You can implement the OnRouteSend method in the application package associated with the handler for this service operation, which enables you to apply additional PeopleCode that determines the final target nodes.
You can use OnRouteSend to validate the outbound service operation's target node list, prevent the message from transmitting, or redirect it to a completely different set of targets.
The following table lists the PeopleCode built-in constants that you can use with the OnRouteSend method:
Constant
Description
%IntBroker_ROUTE_NONE
Do not send this operation to any of the possible nodes.
%IntBroker_ROUTE_SOME
Send this operation to a selected list of nodes. The node list should be an array of strings in the property destinationNodes.
%IntBroker_ROUTE_ALL
Send this operation to all nodes that have a valid routing.
OnRouteSend enables you to account for multiple synchronous targets. Only one target node at a time can receive a request message sent with a synchronous transaction. Even though you can define the same outbound synchronous transaction for multiple nodes, you must make sure the transaction resolves to a single target node or the transaction fails.
The following code example shows an implementation of this class:
import PS_PT:Integration:IRouter; class RoutingHandler implements PS_PT:Integration:IRouter method RoutingHandler(); property array of any destinationNodes; method OnRouteSend(&_MSG As Message) Returns integer; end-class; /* constructor */ method RoutingHandler end-method; method OnRouteSend /+ &_MSG as Message +/ /+ Returns Integer +/ /+ Extends/implements PS_PT:Integration:IRouter.OnRouteSend +/ /* Variable Declaration */ Local any &aNodeList; Local any &rootNode; Local any &xmlDoc; /* Check the message for the instructions on how to execute the OnRouteSend.*/ &xmlDoc = &_MSG.GetXmlDoc(); &rootNode = &xmlDoc.DocumentElement; &aNodeList = &rootNode.GetElementsByTagName("OnRouteSend"); If (&aNodeList.Len <> 1) Then /* No Nodes are in the list, therefore exit. */ Exit; Else /* check the value of the node to determine the action to take. */ Evaluate &aNodeList [1].NodeValue When "True" Return (%IntBroker_ROUTE_ALL); Break; When "False" Return (%IntBroker_ROUTE_NONE); Break; When-Other /* assume that this is to be routed to the node given */ Local array &nodeArray; &nodeArray = CreateArray(); &nodeArray.Push(&aNodeList [1].NodeValue); Local string &sIBVariableTest = GetCurrentType(&nodeArray); Evaluate &sIBVariableTest When "Array" &destinationNodes = &nodeArray.Clone(); Return %IntBroker_ROUTE_SOME; When "BooleanTrue" Return %IntBroker_ROUTE_ALL; When "BooleanFalse" Return %IntBroker_ROUTE_NONE; End-Evaluate; Break; End-Evaluate; End-If; end-method;
OnRouteReceive Method
Implement the OnRouteReceive method for inbound synchronous and asynchronous service operations to apply PeopleCode that determines whether the default local node accepts inbound messages.
The OnRouteReceive method is contained in the IRouter application class, which is contained in the PS_PT application package, in the Integration subpackage.
When the integration engine receives a message, the transaction definitions in the local database provide a list of source nodes from which the application can accept the message. The integration engine’s request handler invokes the service operation's OnRouteReceive event. You can implement the OnRouteReceive method in the application package associated with the handler for this service operation, which enables you to apply PeopleCode that determines whether the default local node accepts the inbound message. You can employ this event regardless of the message transmission type.
The following is an example implementation of this method:
import PS_PT:Integration:IRouter; class RoutingHandler implements PS_PT:Integration:IRouter method RoutingHandler(); property array of any destinationNodes; method OnRouteReceive(&_MSG As Message) Returns boolean; end-class; /* constructor */ method RoutingHandler end-method; method OnRouteReceive /+ &_MSG as Message +/ /+ Returns Boolean +/ /+ Extends/implements PS_PT:Integration:IRouter.OnRouteReceive +/ /* Variable Declaration */ Local any &aNodeList; Local any &rootNode; Local any &xmlDoc; /* Check the message for instructions on how to execute the OnRouteReceive.*/ &xmlDoc = &_MSG.GetXmlDoc(); &rootNode = &xmlDoc.DocumentElement; &aNodeList = &rootNode.GetElementsByTagName("OnRouteReceive"); If (&aNodeList.Len <> 1) Then /* A single node must be present. */ Exit; Else /* check the value of the node to determine the action to take. */ Evaluate &aNodeList [1].NodeValue When "True" Return ( True); Break; When "False" Return ( False); Break; When-Other /* don't recognize the value. */ Exit; End-Evaluate; End-If; end-method;
Click to jump to top of pageClick to jump to parent topicMessaging Methods
This section describes methods used in messaging and the application classes in which they are contained.
Outbound Messaging Methods
This section describes methods used on outbound messages from PeopleSoft to other systems.
OnRequestSend
Implement for outbound synchronous and asynchronous service operations to override connector properties before sending a message to the integration gateway.
This method is contained in the ISend application class.
The OnRequestSend method passes in a message to your derived application class method. The returned value needs to be a message.
The following is an example implementation of this method.
import PS_PT:Integration:ISend; class SendHandler implements PS_PT:Integration:ISend method SendHandler(); method OnRequestSend(&_MSG As Message) Returns Message; end-class; /* constructor */ method SendHandler end-method; method OnRequestSend /+ &_MSG as Message +/ /+ Returns Message +/ /+ Extends/implements PS_PT:Integration:ISend. +/ /+ OnRequest Send +/ /* Variable Declaration */ Local any &tempNode; Local any &rootNode; Local any &xmlDoc; Local any &msg; &msg = &_MSG; &xmlDoc = &msg.GetXmlDoc(); /* Add a node to the doc to prove that we can edit it in this event. */ &rootNode = &xmlDoc.DocumentElement; &tempNode = &rootNode.AddElement("OnSend"); &tempNode.NodeValue = "If you see this, then the Sync OnSend PCode has altered the message"; /* and write the data back into the message */ &msg.SetXmlDoc(&xmlDoc); Return (&msg); end-method;
See Setting and Overriding Target Connector Properties at Runtime.
When using the ISend handler with message parts, specifically with rowset-based message parts, the rowsets of the parts must be retrieved in the order that the content data will be sent.
The following is an example that can be used for ISend events that use rowset-based parts (even for the cases where one is just overriding the connectors):
method OnRequestSend /+ &MSG as Message +/ /+ Returns Message +/ /+ Extends/implements PS_PT:Integration:ISend. +/ /+ OnRequestSend +/ If (&MSG.IsPartsStructured) Then Local number &i; Local Rowset &rs; For &i = 1 To &MSG.PartCount &rs = &MSG.GetPartRowset(&i); End-For; End-If; Return &MSG; end-method;
OnAckReceive
Implement for outbound asynchronous service operations to access the body of a message acknowledgement to check for SOAP faults.
This method is contained in the IReceiver application class.
import PS_PT:Integration:IReceiver; class AckReceiveHandler implements PS_PT: Integration:⇒ IReceiver method AckReceiveHandler(); method OnAckReceive(&_MSG As Message) Returns integer; end-class; /* constructor */ method AckReceiveHandler end-method; method OnAckReceive /+ &_MSG as Message +/ /+ Returns Integer +/ /+ Extends/implements PS_PT:Integration:+/ /+ IReceiver.OnAck Receive +/ /* Variable Declaration */ /* /* We return a hardcoded value. In this case, a message error.*/ Return (%Operation_Error); end-method;
See Handling Inbound Asynchronous Transactions.
Inbound Messaging Methods
This section describes methods used on inbound messages to PeopleSoft from other systems.
OnRequest
Implement for inbound synchronous service operations.
This method is contained in the IRequestHandler application class.
class RequestHandler implements PS_PT:Integration: IRequestHandler method RequestHandler(); method OnRequest(&_MSG As Message) Returns Message; end-class; /* constructor */ method RequestHandler end-method; method OnRequest /+ &_MSG as Message +/ /+ Returns Message +/ /+ Extends/implements PS_PT:Integration:+/ /+ IRequestHandler.OnRequest +/ /* Variable Declaration */ Local any &tempNode; Local any &descNode; Local any &rootNode; Local any &xmlDoc; Local any &xmldata; Local any &msg; &msg = CreateMessage(Operation.QE_IB_SYNC_RESP,%Int⇒ Broker_response); &xmldata = "<?xml version='1.0'?> <QE_IB_PeopleCode_Test⇒/>"; &xmlDoc = CreateXmlDoc(&xmldata); &rootNode = &xmlDoc.documentelement; &descNode = &rootNode.AddElement("Description"); &descNode.NodeValue = "Sync test of OnRouteSend."; &tempNode = &rootNode.addelement("OnRequest"); &tempNode.NodeValue = "If you see this, then the On Request PCode created the response message"; &msg.SetXmlDoc(&xmlDoc); Return &msg;
OnNotify
Implement for inbound asynchronous service operations. This method can be used for code that does subscription processing, and for validating and loading message data.
This method is contained in the INotificationHandler application class.
import PS_PT:Integration:INotificationHandler; class NotificationHandler implements PS_PT:Integration: INotificationHandler method NotificationHandler(); method OnNotify(&_MSG As Message); end-class; /* constructor */ method NotificationHandler end-method; method OnNotify /+ &_MSG as Message +/ /+ Extends/implements PS_PT:Integration: +/ /+ INotificationHandler.OnNotify +/ /* Variable Declaration */ Local Rowset &rs; &rs = &MSG.GetRowset(); /* process data from rowset */ end-method;
OnResponse
Implement for inbound response asynchronous service operations.
This method can be used for code that does response subscription processing. This method is contained in the INotificationHandler application class.
The following is an example implementation of this method and shows how to get the request TransactionID.
import PS_PT:Integration:INotificationHandler; class RESPONSE_NOTIFICATION implements PS_PT: Integration:INotificationHandler method RESPONSE_NOTIFICATION(); method OnNotify(&MSG As Message); end-class; /* constructor */ method RESPONSE_NOTIFICATION %Super = create PS_PT:Integration:INotificationHandler⇒ (); end-method; method OnNotify /+ &MSG as Message +/ /+ Extends/implements PS_PT:Integration:+/ /+ INotification Handler.OnNotify +/ Local Rowset &rs; Local boolean &Ret; Local string &TransactionID; &rs = &MSG.GetRowset(); If &MSG.IsSourceNodeExternal Then /* if the request came from an external non PeopleSoft System then you can get the original TransactionID from the WSA_MessageID from the request message. */ &TransactionID = &MSG.IBInfo.WSA_MessageID; Else /* if the request came from a PeopleSoft System then get the original TransactionID from the nReplyToID */ &TransactionID = &MSG.IBInfo.InReplyToID; End-If; end-method;
Error-Handling Methods
Each application class contained in the Integration application subpackage contains an OnError method that you can use for custom error handling.
Custom error handling can include sending an email notification or entering data in a log when an error occurs.
For the IRequestHandler application class, the OnError function returns a string. This enables you to send back custom error messages, for example SOAP faults, to non-PeopleSoft consumers. If the message consumed was a SOAP message and the custom error message is already wrapped in SOAP, it will not be modified and is sent as-is. However, if the OnError message is not SOAP, it is wrapped as a standard SOAP fault and returned to the sender.
If the message consumer is another PeopleSoft system the message set/message ID framework applies.
If an error occurs the OnError method, if implemented, is automatically invoked. The type of exception can be viewed by using the Message object to retrieve an Exception object populated with information about the error, using the message class IBException property.
The following is an example of the OnError method implementation:
/*On Error Implementation */ method OnError /+ &MSG as Message +/ /+ Returns String +/ /+ Extends/implements PS_PT:Integration:IRequestHandler.OnError +/ Local integer &nMsgNumber, &nMsgSetNumber; Local string &sText; &nMsgNumber = &MSG.IBException.MessageNumber; &nMsgSetNumber = &MSG.IBException.MessageSetNumber; rem &sText = &exception.DefaultText; &sText = &MSG.IBException.ToString(); /* ADD SPECIFIC ERROR INFO HERE */ Return &sText; end-method;
See Exception Class.
See IBException.
Click to jump to top of pageClick to jump to parent topicMessaging PeopleCode
Messaging PeopleCode enables you to manipulate message content. The messaging PeopleCode classes you can use for this are:
Message classes
Use for rowset or nonrowset-based messages.
SOAPDoc class
Use for SOAP-compliant messages.
XMLDoc classes
Use for XML messages.
Document class
Use for Document type messages.
XML and SOAP-compliant messages are nonrowset-based messages. You can use their respective classes to manipulate message content, or use the Message classes.
See Also
Message Classes
SOAPDoc Class
XmlDoc Classes
Click to jump to top of pageClick to jump to parent topicDocument PeopleCode
PeopleSoft provides a Document API for populating and retrieving document data that includes several built-in functions and classes.
The built-in functions are:
CreateDocument
Use this built-in function to instantiate a Document object.
CreateDocumentKey
Use this built-in function to instantiate a Document Key object
The classes are:
The Document API is discussed in the PeopleTools 8.52: PeopleCode API ReferencePeopleBook.
Examples of populating and retrieving document data are provided elsewhere in this chapter.
Click to jump to parent topicGenerating and Sending Messages
This section provides an overview of outbound messaging and discusses how to:
Click to jump to top of pageClick to jump to parent topicUnderstanding Outbound Messaging
Successful outbound messaging relies on sending messages in the proper order and on testing the messages. Messages containing non-XML data have special considerations.
Message Order
PeopleSoft Integration Broker guarantees that messages are delivered in the order in which you send them and that they are single-threaded at the PeopleSoft receiving node. However, message order is not part of the queue definition. You must send messages in the proper order.
Note. You can modify this behavior by using queue partitioning.
See Applying Queue Partitioning.
Message Testing
Make sure that you adequately unit-test and system-test your messages.
Unit-test a message by triggering the PeopleCode that sends the message and then view the message details in Service Operations Monitor. From the Service Operations Monitor, you can view the contents of each field to verify that the message data is formatted correctly.
See PeopleTools 8.52: Integration Broker Service Operations Monitor PeopleBook
You can also test handler code using the Handler Tester utility.
See PeopleTools 8.52: Integration Testing Utilities and Tools PeopleBook
Message Class Outbound PeopleCode
Use the record class SelectByKey method whenever possible to get data that isn’t in the component buffer.
If the record names are the same, use the standard record methods, such as SelectByKey, Insert, and Update, on the message records.
There are no automatic checks for message size. You must do it programmatically. Use the following code at level 0 to control message size when dealing with multiple transactions:
If &Msg.Size > %MaxMessageSize
Note. The OnRouteSend method enables you to apply PeopleCode that filters the destination nodes.
See Record Class.
Non-XML Data
If you’re generating a non-XML outbound message, it’s up to you to insert the message content into a special XML section containing a CDATA tag:
<xml psnonxml="yes"> <![CDATA[nonXML_message_data]]>
Outbound Messaging and Global Variables
When you invoke a SyncRequest method the system clears any declared global variables after OnRouteSend or OnSend PeopleCode events are fired. If a component attempts to access any of the global variables after the SyncRequest method, a context error occurs.
OnRouteSend and OnSend events are primarily used for asynchronous messaging, however they can be use for synchronous messages.
To avoid context errors when using OnRouteSend or OnSend events for synchronous messaging, following these guidelines:
  1. Do not use global variables.
  2. If you must use global variables, save them as temporary variables prior to executing a SyncRequest event, then after the event is fired re-assign them back to the globals.
  3. Run OnRouteSend or OnSend logic prior to the SyncRequest and after the node is obtained use sender-specific routing. In sender-specific routing you pass the node as part of the SyncRequest call. This will send the request to the node as long as there is an active routing. Any connector overrides can be performed prior to the SyncRequest call and set on the message.
Click to jump to top of pageClick to jump to parent topicHandling Outbound Asynchronous Message Transmission
To send a message asynchronously, use the IntBroker class Publish method in:
Message Class Outbound Asynchronous Example
The following example uses the Publish method in the PeopleCode IntBroker class:
Local Message &MSG; Local Rowset &SALES_ORDER, &RS; /*Get a pointer to the component buffer rowset */ &SALES_ORDER = GetLevel0(); /*Create an instance of the SALES_ORDER_ASYNC message object */ &MSG = CreateMessage(OPERATION.SALES_ORDER_ASYNC); /*Copy the rows from the rowset to the message object */ &MSG.CopyRowset(&SALES_ORDER); /*Send the message */ %IntBroker.Publish(&MSG);
XmlDoc Class Outbound Asynchronous Example
The following example uses the Publish method:
Local XmlDoc &xmlRequestDoc; Local Message &MSG; /*Create an XmlDoc Object */ &xmlRequestDoc = CreateXmlDoc(); /* Parse a URL or input XML file into an XmlDoc */ &bool = &xmlRequestDoc.ParseXmlFrom URL("C:\pt\appserv\files\ input.xml"); /* Populate message with XML data */ &MSG = CreateMessage(OPERATION.XmlRequest); &MSG.SetXmlDoc(&xmlRequestDoc); /* Sent request */ %IntBroker.Publish(&MSG);
Identifying SOAP Faults
You can implement the OnAckReceive method to access IBInfo data. This enables you to read the content of acknowledgements returned by recipient systems of asynchronous SOAP messages. The ability to access acknowledgement content is useful when sending SOAP messages, since although there may be no HTTP protocol errors while sending them, SOAP faults may occur.
If the message is nonrowset-based, use the message class GetXmlDoc method to get the response data. This returns an XmlDoc object.
If the message is rowset-based, use the message class GenXMLString method to get the response data. This returns a string object which you can load into an XmlDoc object.
If SOAP faults are found, you can set the status equal to Error so that the errors appear in the Service Operations Monitor for the publication contract.
The following code example shows how to use GetXmlDoc and GenXMLString in an implementation of the OnAckReceive method. Valid status overrides are %Operation_Done, %Operation_Error, and %Operation_Retry:
import PS_PT:Integration:IReceiver; class AckReceiveHandler implements PS_PT:Integration:IReceiver method AckReceiveHandler(); method OnAckReceive(&_MSG As Message) Returns integer; end-class; /* constructor */ method AckReceiveHandler end-method; method OnAckReceive /+ &_MSG as Message +/ /+ Returns Integer +/ /+ Extends/implements PS_PT:Integration:IReceiver.OnAckReceive +/ /* Variable Declaration */ If &MSG.IsStructure Then /* if message is rowset-based */ &str = &MSG.GenXMLString(); Else /* if message is nonrowset-based */ &xmldoc = &MSG.GetXmlDoc(); End-If; Return (%Operation_Done); end-method;
You can also implement the OnAckReceive method to read response content data returned from third-party systems when using the HTTP target connector.
See Also
XmlDoc Classes
Click to jump to top of pageClick to jump to parent topicHandling Outbound Synchronous Transactions
Use the IntBroker class SyncRequest method for handling outbound synchronous transfers. To send a message synchronously, you can employ SyncRequest in:
Note. The OnRequest and OnNotify events are triggered only when an inbound transaction occurs, however, when the receiving PeopleCode runs, it can also send messages.
The response message that is returned from an outbound synchronous transaction is no different from an inbound request message. Once you have it in a Message, XmlDoc, or SoapDoc object, it has the same properties as any other object of that type and can, therefore, be treated exactly the same way.
See Receiving and Processing Messages.
Message Class Outbound Synchronous Example 1
The following example uses the IntBroker class SyncRequest method:
Local Message &MSG, &response; Local Rowset &SALES_ORDER; &SALES_ORDER = GetLevel0(); &MSG = CreateMessage(OPERATION.SALES_ORDER_SYNC); &MSG.CopyRowsetDelta(&SALES_ORDER); /* send the synchronous request; the return value is the response message object */ &response = %IntBroker.SyncRequest(&MSG); /* check the response status; 0 means OK */ If (&response.ResponseStatus = 0) Then /* process the response */ MY_SALES_ORDER_SYNC.ORDER_ID = &response.GetRowset().GetRow(1) .GetRecord(Record.SO_RESPONSE).GetField(Field.ORDER_ID).Value); else /* do error handling */ End-If;
Message Class Outbound Synchronous Example 2
The following example shows the use of CopyTo to get the data back from the response and into the component buffer, and therefore the page:
Local Message &msgZipRequest, &msgZipResponse; Local Rowset &RS, &rsMessageRowset; &RS = GetLevel0(); &msgZipRequest = CreateMessage(OPERATION.ZIP_REQUEST); &msgZipRequest.CopyRowset(&RS); /* send the synchronous request; the return value is the response message object */ &msgZipResponse = %IntBroker.SyncRequest(&msgZipRequest, Node.ZIPTOCITYANDSTATE); /* check the response status; 0 means OK */ If (&msgZipResponse.ResponseStatus = 0) Then /* process the response */ &rsMessageRowset = &msgZipResponse.GetRowset(); &rsMessageRowset.CopyTo(&RS); else /* do error handling */ End-If;
XmlDoc Class Outbound Synchronous Example
Local Message &MSG, &RESP_MSG; Local XmlDoc &flightplan_xmldoc, &xmldocReturn; Local XmlNode &ac_number, &msi_sensor, &ofp; &flightplan_xmldoc = CreateXmlDoc(""); &ac_number = &flightplan_xmldoc.CreateDocumentElement("flightplan"); &msi_sensor = &ac_number.AddElement("msi_sensor"); &msi_sensor.NodeValue = "flir"; &ofp = &ac_number.AddElement("ofp"); &ofp.NodeValue = "8.44"; &MSG = CreateMessage(Message.SYNC_REQUEST_EXAMPLE); &MSG.SetXmlDoc(&flightplan_xmldoc); &RESP_MSG = &MSG.SyncRequest(); &xmldocReturn = &RESP_MSG.GetXmlDoc(); &return_data = &xmldocReturn.GenXmlString();
See Also
XmlDoc Classes
Click to jump to top of pageClick to jump to parent topicReading Exceptions for Outbound Synchronous Integrations
The Routing – Routings Definition page features a User Exception check box that enables you to capture Integration Broker exceptions for outbound synchronous integrations using PeopleCode.
Note. Do not use Try/Catch PeopleCode to attempt to read exceptions on outbound SyncRequest calls.
The following code example shows how to read captured exceptions:
&Return_MSG = %IntBroker.SyncRequest(&MSG); If &Return_MSG.ResponseStatus = %IB_Status_Success Then /* process the response message */ &RS = &MSG.GetPartRowset(); Else /* evauate the error and either throw a PeopleCode exception or continue⇒ processing */ &error_string = &Return_MSG.IBException.ToString()); &nErrorMsgNumber = &Return_MSG.IBException.MessageNumber; &nErrorMsgSetNumber = &Return_MSG.IBException.MessageSetNumber; End-If;
See Also
Defining General Routing Information
Click to jump to top of pageClick to jump to parent topicOverriding Synchronous Timeout Intervals at Runtime
For long-running outbound synchronous transactions, you can override the default timeout period the transaction at runtime using the SyncServiceTimeout property. The default synchronous timeout period is five minutes.
The HTTP header file is modified to take this parameter. The value you set is sent to the integration gateway where it is used for the HTTP timeout.
The SyncServiceTimeout property takes a time (in seconds). The property is read-write.
The following code example shows how to use the property. To use this property, note that you must override and setup the target connector properties for the transaction. As the example demonstrates, there are helper methods that load properties based on node or transaction.
&MSG.SetXmlDoc(&xmlReq); &MSG.IBInfo.LoadConnectorPropFromNode(Node.EAI); &MSG.IBInfo.SyncServiceTimeout = 360000; &MSG.IBInfo.ConnectorOverride = True; &MSG_Resp = %IntBroker.SyncRequest(&MSG, Node.EAI); &xmlResponseDoc = &MSG_Resp.GetXmlDoc();
See Also
PeopleSoft Timeout Settings
Click to jump to top of pageClick to jump to parent topicHandling Cookies
PeopleSoft Integration Broker provides basic cookie handling for exchanges that are initiated by your PeopleSoft application. You can accept a synchronous response message containing cookies, save those cookies in a global variable, and later return them to the remote node in an outbound synchronous or asynchronous request message. This is a typical application of cookies in a web interaction.
Cookies are implemented as an IBInfo class property, Cookies. You can access this property only in an inbound synchronous response message or an outbound request message.
Receiving Cookies Example
The following example retains the cookies from a response message to a global variable:
Local Message &SalesRequest, &SalesResponse; Local Rowset &SALES_ORDER; Global string &SalesCookies; &SALES_ORDER = GetLevel0(); &SalesRequest = CreateMessage(OPERATION.SALES_ORDER_SYNC); &SalesRequest.CopyRowsetDelta(&SALES_ORDER); /* Send the synchronous request; the return value is the response message object */ &SalesResponse = ​%IntBroker.SyncRequest(&SalesRequest); /* Retrieve cookies from the response message */ &SalesCookies = &SalesResponse.IBInfo.IBConnectorInfo.Cookies;
Returning Cookies Example
The following example retrieves the previously retained cookies from the global variable and inserts them into a new request message:
Local Message &SalesRequest, &SalesResponse; Local Rowset &SALES_ORDER; Global string &SalesCookies; &SALES_ORDER = GetLevel0(); &SalesRequest = CreateMessage(OPERATION.SALES_ORDER_SYNC); &SalesRequest.CopyRowsetDelta(&SALES_ORDER); /* Insert the cookies in the request message */ &SalesRequest.IBInfo.IBConnectorInfo.Cookies = &SalesCookies; /* Send the asynchronous request */ %IntBroker.Publish(&SalesRequest);
Click to jump to top of pageClick to jump to parent topicSetting and Overriding Target Connector Properties at Runtime
PeopleSoft Integration Broker enables you to dynamically override target connector properties at runtime that have previously been set at the node, connector and transaction levels. To set or override target connectors at runtime, use the PeopleCode IBInfo object, the Connector Info object and implement the OnRequestSend method.
Note. Properties set at the PeopleCode level take precedence over those set at the node, connector and routing level.
IBInfo object
An IBInfo object is instantiated from a message object.
You can use this object in publishing or synchronous request PeopleCode. You can also use it in your implementation of the OnRequestSend method.
ConnectorInfo object
A ConnectorInfo object is instantiated from an IBInfo object. Use this object for reading and writing connector name/value pair information to and from the IBRequest.
OnRequestSend Method
The OnRequestSend method is included in the ISend application class. Use your implementation of this method to override target connector properties at runtime for a subscribing node transaction.
This event associated with the service operation executes before any transformations are processed.
You can use this event for asynchronous and synchronous messages.
Since data is always carried with the message, you can use the IBInfo object, ConnectorInfo object and your implementation of the OnRequestSend method to populate connector information in the publishing PeopleCode and then override it for a specific node.
Setting and Overriding Target Connector Properties Using the OnRequestSend Event
You can use implement the OnRequestSend method to override IBInfo and connector properties at runtime for a subscribing node transaction.
Any content data that is changed on the message or XMLDoc is sent to the subscribing node or used within a transformation.
To override the properties of a target connector, you must set the following statement to true:
&MSG.IBInfo.ConnectorOverride=true
If a publication contract fails as a result of using an implementation of the OnRequestSend method to override connector properties at runtime, correct the PeopleCode in your implementation and resubmit the message.
Example: Setting Target Connector Properties Using the OnRequestSend Method
The following example shows loading all connectors that exist for the node and adding one additional property, Filename.
import PS_PT:Integration:ISend; class SendHandler implements PS_PT:Integration:ISend method SendHandler(); method OnRequestSend(&Msg As Message) Returns Message; end-class; /* constructor */ method SendHandler end-method; method OnRequestSend /+ &MSG as Message +/ /+ Returns Message +/ /+ Extends/implements PS_PT:Integration:ISend.OnRequestSend +/ /* Variable Declaration */ Local Any &Bo; Local Message &Msg; &Bo = &MSG.IBInfo.LoadConnectorPropFromNode("nodename"); &Bo = &MSG.IBInfo.IBConnectorInfo.AddConnectorProperties ("FILENAME", "temp", %Property); &MSG.IBInfo.ConnectorOverride = True; Return (&Msg); end-method;
Example: Overriding Connector Properties Using the OnRequestSend Method
The following example demonstrates overriding target connector properties using an implementation of the OnRequestSend method for a rowset-based asynchronous message.
import PS_PT:Integration:ISend; class SendHandler implements PS_PT:Integration:ISend method SendHandler(); method OnRequestSend(&Msg As Message) Returns Message; end-class; /* constructor */ method SendHandler end-method; method OnRequestSend /+ &MSG as Message +/ /+ Returns Message +/ /+ Extends/implements PS_PT:Integration:ISend.OnRequestSend +/ /* Variable Declaration */ Local Boolean &bRet; &bRet= &MSG.IBInfo.LoadConnectorProp("FILEOUTPUT"); &MSG.IBInfo.ConnectorOverride = True; &bRet= &MSG.IBInfo.IBConnectorInfo.AddConnectorProperties ("sendUncompressed", "Y", %Header); &bRet= &MSG.IBInfo.IBConnectorInfo.AddConnectorProperties ("FilePath", "c:\temp", %Property); Return (&Msg); End-Method;
The following example demonstrates overriding target connector properties using an implementation of the OnRequestSend method for a nonrowset-based asynchronous message.
import PS_PT:Integration:ISend; class SendHandler implements PS_PT:Integration:ISend method SendHandler(); method OnRequestSend(&Msg As Message) Returns Message; end-class; /* constructor */ method SendHandler end-method; method OnRequestSend /+ &MSG as Message +/ /+ Returns Message +/ /+ Extends/implements PS_PT:Integration:ISend.OnRequestSend +/ /* Variable Declaration */ Local XmlDoc &xmldoc; Local Boolean &bRet; // if you have to access the content data for content based // decisions, do this &xmldoc = &MSG.GetXmlDoc(); &bRet= &MSG.IBInfo.LoadConnectorProp("FILEOUTPUT"); &MSG.IBInfo.ConnectorOverride = True; &bRet= &MSG.IBInfo.IBConnectorInfo.AddConnectorProperties ("sendUncompressed", "Y", %Header); &bRet= &MSG.IBInfo.IBConnectorInfo.AddConnectorProperties ("FilePath", "c:\temp", %Property); Return (&MSG); End-Method;
See Also
IBInfo Class
IBConnectorInfo Collection
Message Classes
Click to jump to parent topicReceiving and Processing Messages
This section discusses how to handle:
Note. The OnRouteReceive method can be implemented to apply PeopleCode that determines whether the default local node accepts the inbound message.
Click to jump to top of pageClick to jump to parent topicHandling Inbound Asynchronous Transactions
Implement the OnNotify method in the PS_PT application package, in the Integration sub-package, to handle inbound asynchronous transactions. All the examples in this section are assumed to be implementations of the OnNotify method.
Message Class Inbound Asynchronous Example 1
The following example implements the OnNotify method.
import PS_PT:Integration:INotificationHandler; class FLIGHTPROFILE implements PS_PT:Integration:INotificationHandler method FLIGHTPROFILE(); method OnNotify(&_MSG As Message); end-class; /* constructor */ method FLIGHTPROFILE end-method; method OnNotify /+ &_MSG as Message +/ /+ Extends/implements PS_PT:Integration:INotificationHandler.+/ /+ OnNotify +/ /* Variable Declaration */ Local any &outstring; Local any &i; Local any &CRLF; Local Message &MSG; Local Rowset &rs, &rs1; Local Record &FLIGHTDATA, &REC; Local string &acnumber_value, &msi_sensor_value, &ofp_value, &actype_value, &callsign_value, &squadron_value, &comm1_value, &comm2_value, &ecm_value; Local XmlDoc &xmldoc; Local string &return_string_value; Local boolean &return_bool_value; &CRLF = Char(13) | Char(10); &MSG = &_MSG; &rs = &MSG.GetRowset(); &REC = &rs(1).QE_FLIGHTDATA; &FLIGHTDATA = CreateRecord(Record.QE_FLIGHTDATA); &REC.CopyFieldsTo(&FLIGHTDATA); /* Parse out Message Data */ &acnumber_value = &FLIGHTDATA.QE_ACNUMBER.Value; &msi_sensor_value = &FLIGHTDATA.QE_MSI_SENSOR.Value; &ofp_value = &FLIGHTDATA.QE_OFP.Value; &actype_value = &FLIGHTDATA.QE_ACTYPE.Value; &callsign_value = &FLIGHTDATA.QE_CALLSIGN.Value; &squadron_value = &FLIGHTDATA.QE_SQUADRON.Value; &comm1_value = &FLIGHTDATA.QE_COMM1.Value; &comm2_value = &FLIGHTDATA.QE_COMM2.Value; &ecm_value = &FLIGHTDATA.QE_ECM.Value; &outstring = "Send Async FLight test"; /* Construct Output String */ &outstring = &outstring | &acnumber_value | &CRLF | &msi_sensor_value | &CRLF | &ofp_value | &CRLF | &actype_value | &CRLF | &callsign_value | &CRLF | &squadron_value | &CRLF | &comm1_value | &CRLF | &comm2_value | &CRLF | &ecm_value; /* Log Output String into page record */ &FLIGHTDATA.GetField(Field.DESCRLONG).Value = &outstring; SQLExec("DELETE FROM PS_QE_FLIGHTDATA"); &FLIGHTDATA.Insert(); end-method;
Message Class Inbound Asynchronous Example 2
The following example shows notification PeopleCode that checks the PSCAMA to determine the audit action code and that examines the language code to determine whether related language processing is needed:
method OnNotify /+ &MSG as Message +/ /* Simple PeopleCode Notifcation- - Check the PSCAMA*/ Local Rowset &MSG_RS; Local Record &REC_NAME_PREFIX, &REC, &REC_RL; Local integer &I; Local string &ACTION, &LNG, &BASE_LNG, &RELLNG, &KEY1, &KEY2; &MSG_RS = &MSG.GetRowset(); For &I = 1 To &MSG_RS.RowCount /* Loop through all transactions */ &REC = &MSG_RS.GetRow(&I).GetRecord(Record.NAME_PREFIX_TBL); /* Get Audit Action for this transaction */ &ACTION = &MSG_RS.GetRow(&I).PSCAMA.AUDIT_ACTN.Value; /* Get Language code for this transaction */ &LNG = &MSG_RS.GetRow(&I).PSCAMA.LANGUAGE_CD.Value; &BASE_LNG = %Language; Evaluate &ACTION /*****************************/ /******** Add a Record *******/ /*****************************/ When "A" /* Add the base language record */ &REC_NAME_PREFIX = CreateRecord(Record.NAME_PREFIX_TBL); &REC.CopyFieldsTo(&REC_NAME_PREFIX); &REC_NAME_PREFIX.ExecuteEdits(); If &REC_NAME_PREFIX.IsEditError Then /* error handling */ Else &REC_NAME_PREFIX.Insert(); /* Need error handling here if insert fails */ If &LNG <> %Language Then /* add related language record */ &RELLNG = &REC.RelLangRecName; &REC_RL = CreateRecord(Record.NAME_PREFIX_LNG); &REC.CopyFieldsTo(&REC_RL); &REC_RL.LANGUAGE_CD.Value = &LNG; &REC_RL.Insert(); /* Need error handling here if insert fails */ End-If; End-If; /*****************************/ /***** Change a Record *******/ /*****************************/ /**** Using record objects ***/ When "C" /* Get the Record - insert it */ &KEY1 = &REC.GetField(Field.NAME_PREFIX).Value; &REC_NAME_PREFIX = CreateRecord(Record.NAME_PREFIX_TBL); &REC_NAME_PREFIX.NAME_PREFIX.Value = &REC.GetField(Field. NAME_PREFIX).Value; If &REC_NAME_PREFIX.SelectByKey() Then &REC.CopyFieldsTo(&REC_NAME_PREFIX); &REC_NAME_PREFIX.ExecuteEdits(); If &REC_NAME_PREFIX.IsEditError Then /* error handling */ Else &REC_NAME_PREFIX.Update(); End-If; Else &REC.CopyFieldsTo(&REC_NAME_PREFIX); &REC_NAME_PREFIX.ExecuteEdits(); If &REC_NAME_PREFIX.IsEditError Then /* error handling */ Else &REC_NAME_PREFIX.Insert(); End-If; End-If; /*****************************/ /****** Delete a Record ******/ /*****************************/ /*** Using SQLExec ***********/ When "D" /* Get the Record using SQLExec- error */ &KEY1 = &REC.GetField(Field.NAME_PREFIX).Value; SQLExec("Select NAME_PREFIX from PS_NAME_PREFIX_TBL where NAME_PREFIX = :⇒1", &KEY1, &KEY2); If None(&KEY2) Then /* Send to error log */ Else SQLExec("Delete from PS_NAME_PREFIX_TBL where NAME_PREFIX = :1", &KEY1); SQLExec("Delete from PS_NAME_PREFIX_LNG where NAME_PREFIX = :1", &KEY1); End-If; End-Evaluate; End-For; end-method;
Message Class Inbound Asynchronous Example 3
There’s a practical limit to how large a message can be, and this can be controlled by a system-wide variable called %MaxMessageSize. The system administrator can change this size in the PSOPTIONS settings. This size can be set only for all messages, not for individual definitions.
PeopleCode that populates a Message object should include code that is similar to the following example to check the message size before inserting a new Level 0 row.
Note. Always code the %MaxMessageSize checkpoint at the Level 0 record. A batch of transactions can be split across multiple messages, but do not split a single transaction (logical unit of work) into multiple messages.
Local SQL &hdr_sql, &ln_sql; Local Message &MSG; Local Rowset &hdr_rs, &ln_rs; Local Record &hdr_rec, &ln_rec, &hdr_rec_msg, &ln_rec_msg; /* This PeopleCode will publish messages for a simple Header/ Line record combination. Multiple Header/Lines are copied to the message until the %MaxMessageSize is exceeded at which point a new message is built. This references MSR_HDR_INV (Header) and DEMAND_INF_INV (Line) records */ /* Create an instance of the STOCK_REQUEST message */ &MSG = CreateMessage(OPERATION.STOCK_REQUEST); /* Create an App. Message Rowset that includes the MSR_HDR_INV (Header) and DEMAND_INF_INV (Line)*/ &hdr_rs = &MSG.GetRowset(); /* Create a SQL object to select the Header rows */ &hdr_sql = CreateSQL("Select * from PS_MSR_HDR_INV WHERE BUSINESS_UNIT='M04A1' AND ORDER_NO LIKE 'Z%' ORDER BY BUSINESS_UNIT,ORDER_NO"); &I = 1; /* Create record objects for the Header and Lines */ &ln_rec = CreateRecord(Record.DEMAND_INF_INV); &hdr_rec = CreateRecord(Record.MSR_HDR_INV); /* Loop through each Header row that is fetched */ While &hdr_sql.Fetch(&hdr_rec) /* Publish the message if its size exceeds the MaxMessageSize /* specified in Utilities/Use/PeopleTools Options */ If &MSG.Size > %MaxMessageSize Then %IntBroker.Publish(&MSG); &I = 1; /* Create a new instance of the message object */ &MSG = CreateMessage(OPERATION.STOCK_REQUEST); &hdr_rs = &MSG.GetRowset(); End-If; If &I > 1 Then &hdr_rs.InsertRow(&I - 1); End-If; /* Instantiate the row within the Header portion of the App Message rowset to which data will be copied */ &hdr_rec_msg = &hdr_rs.GetRow(&I).GetRecord(Record.MSR_HDR_INV); /* Copy data into the level 0 (Header portion) of /* &MSG message structure */ &hdr_rec.CopyFieldsTo(&hdr_rec_msg); /* Publish the last message if it has been changed*/ If &hdr_rec_msg.IsChanged Then %IntBroker.Publish(&MSG); End-If; End-While;
Message Class Inbound Asynchronous Example 4
The following code example shows how to get data out of the IBInfo object for a rowset-based message.
Local Rowset &rs, &rs1; Local Record &FLIGHTDATA, &REC; Local string &acnumber_value, &msi_sensor_value, &ofp_value, &actype_value, &callsign_value, &squadron_value, &comm1_value, &comm2_value, &ecm_value, &datetime; Local XmlDoc &xmldoc; Local string &data; Local boolean &return_bool_value; &CRLF = Char(13) | Char(10); /* this is how one would access data from IBinfo and /* IBConnectorInfo objects*/ &return_bool_value = &MSG.IBInfo.ConnectorOverride; For &i = 1 To &MSG.IBInfo.IBConnectorInfo.GetNumberOfConnector Properties() &data = &MSG.IBInfo.IBConnectorInfo.GetQueryStringArgName(&i); &data = &MSG.IBInfo.IBConnectorInfo.GetQueryStringArgValue(&i); End-For; &MSG.IBInfo.IBConnectorInfo.ClearConnectorProperties(); &data = &MSG.IBInfo.IBConnectorInfo.ConnectorName; &data = &MSG.IBInfo.IBConnectorInfo.ConnectorClassName; &data = &MSG.IBInfo.IBConnectorInfo.RemoteFrameworkURL; &data = &MSG.IBInfo.IBConnectorInfo.PathInfo; &data = &MSG.IBInfo.IBConnectorInfo.Cookies; For &i = 1 To &MSG.IBInfo.IBConnectorInfo.GetNumberOfQueryStringArgs() &data = &MSG.IBInfo.IBConnectorInfo.GetConnectorPropertiesName(&i); &data = &MSG.IBInfo.IBConnectorInfo.GetConnectorPropertiesValue (&i); &data = &MSG.IBInfo.IBConnectorInfo.GetConnectorPropertiesType(&i); End-For; &MSG.IBInfo.IBConnectorInfo.ClearQueryStringArgs(); &data = &MSG.IBInfo.MessageType; &data = &MSG.IBInfo.RequestingNodeName; &data = &MSG.IBInfo.OrigUser; &data = &MSG.IBInfo.OrigNode; &data = &MSG.IBInfo.AppServerDomain; &data = &MSG.IBInfo.OrigProcess; &data = &MSG.IBInfo.OrigTimeStamp; &data = &MSG.IBInfo.DestinationNode; &data = &MSG.IBInfo.FinalDestinationNode; &data = &MSG.IBInfo.SourceNode; &data = &MSG.IBInfo.MessageName; &data = &MSG.IBInfo.MessageVersion; &data = &MSG.IBInfo.VisitedNodes; /* get the content data from the message rowset*/ &rs = &MSG.GetRowset(); &REC = &rs(1).QE_FLIGHTDATA; &FLIGHTDATA = CreateRecord(Record.QE_FLIGHTDATA); &REC.CopyFieldsTo(&FLIGHTDATA); /* Parse out Message Data */ &acnumber_value = &FLIGHTDATA.QE_ACNUMBER.Value; &msi_sensor_value = &FLIGHTDATA.QE_MSI_SENSOR.Value; &ofp_value = &FLIGHTDATA.QE_OFP.Value; &actype_value = &FLIGHTDATA.QE_ACTYPE.Value; &callsign_value = &FLIGHTDATA.QE_CALLSIGN.Value; &squadron_value = &FLIGHTDATA.QE_SQUADRON.Value; &comm1_value = &FLIGHTDATA.QE_COMM1.Value; &comm2_value = &FLIGHTDATA.QE_COMM2.Value; &ecm_value = &FLIGHTDATA.QE_ECM.Value; &datetime = &FLIGHTDATA.ACTIONDTTM.Value; &outstring = "Send Async FLight test"; /* Construct Output String */ &outstring = &outstring | &acnumber_value | &CRLF | &msi_sensor_value | &CRLF | &ofp_value | &CRLF | &actype_value | &CRLF | &callsign_value | &CRLF | &squadron_value | &CRLF | &comm1_value | &CRLF | &comm2_value | &CRLF | &ecm_value | &datetime; /* Log Output String into page record */ &FLIGHTDATA.GetField(Field.DESCRLONG).Value = &outstring; SQLExec("DELETE FROM PS_QE_FLIGHTDATA"); &FLIGHTDATA.Insert();
Message Class Inbound Asynchronous Example 5
The following code example shows how to get data out of the IBInfo object for a nonrowset-based message.
Local XmlDoc &xmldoc; Local XmlNode &node, &root, &acct_id_node, &acct_name_node, &address_node, &phone_node; Local string &outstring, &CRLF; Local Record &FLIGHT_DATA_INFO, &REC; Local string &data; Local boolean &return_bool_value; /* this is how one wouild access data from IBinfo and /* IBConnectorInfo objects*/ &return_bool_value = &MSG.IBInfo.ConnectorOverride; For &i = 1 To &MSG.IBInfo.IBConnectorInfo.GetNumberOfConnector Properties() &data = &MSG.IBInfo.IBConnectorInfo.GetQueryStringArgName(&i); &data = &MSG.IBInfo.IBConnectorInfo.GetQueryStringArgValue(&i); End-For; &MSG.IBInfo.IBConnectorInfo.ClearConnectorProperties(); &data = &MSG.IBInfo.IBConnectorInfo.ConnectorName; &data = &MSG.IBInfo.IBConnectorInfo.ConnectorClassName; &data = &MSG.IBInfo.IBConnectorInfo.RemoteFrameworkURL; &data = &MSG.IBInfo.IBConnectorInfo.PathInfo; &data = &MSG.IBInfo.IBConnectorInfo.Cookies; For &i = 1 To &MSG.IBInfo.IBConnectorInfo.GetNumberOfQueryStringArgs() &data = &MSG.IBInfo.IBConnectorInfo.GetConnectorPropertiesName(&i); &data = &MSG.IBInfo.IBConnectorInfo.GetConnectorPropertiesValue (&i); &data = &MSG.IBInfo.IBConnectorInfo.GetConnectorPropertiesType(&i); End-For; &MSG.IBInfo.IBConnectorInfo.ClearQueryStringArgs(); &data = &MSG.IBInfo.MessageType; &data = &MSG.IBInfo.RequestingNodeName; &data = &MSG.IBInfo.OrigUser; &data = &MSG.IBInfo.OrigNode; &data = &MSG.IBInfo.AppServerDomain; &data = &MSG.IBInfo.OrigProcess; &data = &MSG.IBInfo.OrigTimeStamp; &data = &MSG.IBInfo.DestinationNode; &data = &MSG.IBInfo.FinalDestinationNode; &data = &MSG.IBInfo.SourceNode; &data = &MSG.IBInfo.MessageName; &data = &MSG.IBInfo.MessageVersion; &data = &MSG.IBInfo.VisitedNodes; &xmldoc = &MSG.GetXmlDoc(); &CRLF = Char(13) | Char(10); &root = &xmldoc.DocumentElement; /* Get values out of XMLDoc */ &node_array = &root.GetElementsByTagName("actype"); &ac_type_node = &node_array.Get(1); &ac_type_value = &ac_type_node.NodeValue; &node_array = &root.GetElementsByTagName("msi_sensor"); &msi_sensor_node = &node_array.Get(1); &msi_sensor_value = &msi_sensor_node.NodeValue; &node_array = &root.GetElementsByTagName("callsign"); &callsign_node = &node_array.Get(1); &callsign_value = &callsign_node.NodeValue; &node_array = &root.GetElementsByTagName("ofp"); &ofp_node = &node_array.Get(1); &ofp_value = &ofp_node.NodeValue; &outstring = "GetDataout of xmldoc Test"; &outstring = &outstring | &CRLF | &ac_type_value | &CRLF | &msi_sensor_node | &CRLF | &callsign_value | &CRLF | &ofp_value; /* Write out the result string */ SQLExec("DELETE FROM PS_QE_FLIGHT_DATA"); &FLIGHT_DATA_INFO = CreateRecord(Record.QE_FLIGHT_DATA); &FLIGHT_DATA_INFO.GetField(Field.DESCRLONG).Value = &outstring; &FLIGHT_DATA_INFO.Insert();
Message Class Inbound Asynchronous Example 6
The following example show a notification that could be an implementation of the OnNotify method, using a component interface in the notification. This example shows error trapping and has multilanguage support:
Component string &PUBNODENAME; /* save pubnodename to prevent circular publishes */ Local Message &MSG; Local Rowset &MSG_ROWSET, &cur_rowset; Local ApiObject &oSession; Local ApiObject &CONTACT_CI; Local number &I; Local string &KEY1; Local Record &REC; Local boolean &BC_CREATE, &ADD; Local boolean &TRANSACTION_ERROR, &MSG_ERROR; /** Transaction/Message Error Flags**/ Function errorHandler() Local ApiObject &oPSMessageColl; Local ApiObject &oPSMessage; Local string &strErrMsgSetNum, &strErrMsgNum, &strErrMsgText, &strErrType; &oPSMessageColl = &oSession.PSMessages; For &I = 1 To &oPSMessageColl.Count &oPSMessage = &oPSMessageColl.Item(&I); &strErrMsgSetNum = &oPSMessage.MessageSetNumber; &strErrMsgNum = &oPSMessage.MessageNumber; &strErrMsgText = &oPSMessage.Text; &LogFile.WriteLine(&strErrType | " (" | &strErrMsgSetNum | "," | &strErrMsgNum | ") - " | &strErrMsgText); End-For; rem ***** Delete the Messages from the collection *****; &oPSMessageColl.DeleteAll(); End-Function; Function DO_CI_SUBSCRIBE() &oSession = %Session; &CONTACT_CI = &oSession.GETCOMPONENT(CompIntfc.CONTACT); If (&CONTACT_CI = Null) Then /* Replace this message with Tools message set when available */ Error MsgGet(91, 58, " Unable to get the Component Interface."); Exit (1); End-If; /** Set Component Interface Properties **/ &CONTACT_CI.GetHistoryItems = True; &CONTACT_CI.Interactivemode = False; /** set this to True while debugging **/ rem Send messages to the PSMessage Collection; &oSession.PSMessagesMode = 1; &MSG_ERROR = False; For &I = 1 To &MSG_ROWSET.ActiveRowCount /** Set Session Language Code Property **/ &REGIONALSETTINGS = &oSession.RegionalSettings; &REGIONALSETTINGS.LanguageCd = &MSG_ROWSET(&I).PSCAMA. LANGUAGE_CD.Value; &TRANSACTION_ERROR = False; &BC_CREATE = False; /** Instantiate Component Interface **/ &KEY1 = &MSG_ROWSET(&I).CONTACT_TBL.PERSON_ID.Value; &CONTACT_CI.PERSON_ID = &KEY1; Evaluate &MSG_ROWSET(&I).PSCAMA.AUDIT_ACTN.Value When = "A" When = "N" &ADD = True; /* Check if Keys already exist. */ &CONTACT_CIColl = &CONTACT_CI.Find(); /*If None(&EXISTS) Then*/ If &CONTACT_CIColl.Count = 0 Then If &CONTACT_CI.Create() Then &BC_CREATE = True; Else /* Replace this message with Tools message set when available */ Warning MsgGet(18022, 56, "Error creating Component Interface for transaction %1", &I); &TRANSACTION_ERROR = True; End-If; Else If Not &CONTACT_CI.Get() Then /* Replace this message with Tools message set when available */ Warning MsgGet(18022, 59, "Could not Get Component Interface for transaction %1", &I); &TRANSACTION_ERROR = True; End-If; End-If; Break; When = "C" &ADD = False; If Not &CONTACT_CI.Get() Then /* Replace this message with Tools message set when available */ Warning MsgGet(18022, 59, "Could not Get Component Interface for transaction %1", &I); &TRANSACTION_ERROR = True; End-If; Break; When = "D" When = "K" When-Other /* delete and old key action codes not allowed at this time */ &TRANSACTION_ERROR = True; Warning MsgGet(18022, 61, "Audit Action 'D' not allowed on transaction %1", &TRANSACTION); Break; End-Evaluate; &CONTACT_CI.CopyRowset(&MSG_ROWSET, &I); If Not &TRANSACTION_ERROR Then If Not &CONTACT_CI.save() Then /* Replace this message with Tools message set when available */ Warning MsgGet(18022, 57, "Error saving Component Interface for transaction %1", &TRANSACTION); &TRANSACTION_ERROR = True; End-If; End-If; /** close the last Component Interface in preparation for getting the next **/ If Not &CONTACT_CI.Cancel() Then /* Replace this message with Tools message set when available */ Warning MsgGet(18022, 58, "Error Canceling Component Interface for transaction %1", &TRANSACTION); Exit (1); End-If; /* Reset &TRANSACTION_ERROR to "False" for &BusComp.Save() to execute if no /* Transaction Error found in the next Transaction. */ &TRANSACTION_ERROR = False; End-For; If &TRANSACTION_ERROR Then &MSG_ERROR = True; End-If; End-Function; /**** Main Process ****/ &MSG.ExecuteEdits(%Edit_Required + %Edit_TranslateTable); If &MSG.IsEditError Then &MSG_ERROR = True; Else &PUBNODENAME = &MSG.PubNodeName; &MSG_ROWSET = &MSG.GetRowset(); /* Do Component Interface subscribe */ DO_CI_SUBSCRIBE(); End-If; If &MSG_ERROR Then Exit (1); End-If;
XmlDoc Class Inbound Asynchronous Example
The following example uses the GetXmlDoc method.
Local XmlDoc &Document; Local XmlNode &node, &root; Local string &outstring; Local Rowset &LEVEL0; Local Record &SALES_ORDER_INFO, &REC; &CRLF = Char(13) | Char(10); & Document = &MSG.GetXmlDoc(); &root = & Document.DocumentElement; &child_count = &root.ChildNodeCount; /* Get values out of XmlDoc */ &node_array = &root.GetElementsByTagName("QE_ACCT_ID"); &acct_id_node = &node_array.Get(2); &account_id_value = &acct_id_node.NodeValue; &node_array = &root.GetElementsByTagName("QE_ACCOUNT_NAME"); &acct_name_node = &node_array.Get(2); &account_name_value = &acct_name_node.NodeValue; &node_array = &root.GetElementsByTagName("QE_ADDRESS"); &address_node = &node_array.Get(2); &address_value = &address_node.NodeValue; &node_array = &root.GetElementsByTagName("QE_PHONE"); &phone_node = &node_array.Get(2); &phone_value = &phone_node.NodeValue; &outstring = "GetMessageXmlDoc Test"; &outstring = &outstring | &CRLF | &account_id_value | &CRLF | &account_name_value | &CRLF | &address_value | &CRLF | &phone_value; &SALES_ORDER_INFO = CreateRecord(Record.QE_SALES_ORDER); &SALES_ORDER_INFO.GetField(Field.QE_ACCT_ID).Value = &account_id_value; &SALES_ORDER_INFO.GetField(Field.DESCRLONG).Value = &outstring; &SALES_ORDER_INFO.Update();
Click to jump to top of pageClick to jump to parent topicHandling Inbound Synchronous Transactions
Implement the OnRequest method in the PS_PT application package, in the Integration subpackage, to handle inbound synchronous transactions. All the examples in this section are assumed to be implementations of the OnRequest method.
Message Class Inbound Synchronous Example
The following example implements both the OnRequest method and the OnError method
import PS_PT:Integration:IRequestHandler; class RequestMan implements PS_PT:Integration:IRequestHandler method RequestMan(); method OnRequest(&MSG As Message) Returns Message; method OnError(&MSG As Message) Returns string; end-class; /* constructor */ method RequestMan %Super = create PS_PT:Integration:IRequestHandler(); end-method; method OnRequest /+ &MSG as Message +/ /+ Returns Message +/ Local Message &response; &response = CreateMessage(Operation.SYNC_REMOTE, %IntBroker_Response); &response.GetRowset().GetRow(1).GetRecord(Record.QE_FLIGHTDATA). GetField (Field.DESCRLONG).Value = &MSG.GenXMLString(); Return &response; end-method; method OnError /+ &MSG as Message +/ /+ Returns String +/ /+ Extends/implements PS_PT:Integration:IRequestHandler.OnError +/ Local integer &nMsgNumber, &nMsgSetNumber; Local string &sText; &nMsgNumber = &MSG.IBException.MessageNumber; &nMsgSetNumber = &MSG.IBException.MessageSetNumber; rem &sText = &exception.DefaultText; &sText = &MSG.IBException.ToString(); /* ADD SPECIFIC ERROR INFO HERE */ Return &sText; end-method;
XmlDoc Class Inbound Synchronous Example
The following example uses the GetXmlDoc method:
Local XmlDoc &xmlRequestDoc; Local XmlDoc &xmlResponseDoc; Local XmlNode &select; Local Message &Return_MSG; Local array of XmlNode &whereClause; Local string &recordName; Local string &fieldName; Local string &fieldValue; Local Rowset &outputRowset; Local boolean &return_bool_value; &xmlRequestDoc = &MSG.GetXmlDoc(); &select = &xmlRequestDoc.DocumentElement; &recordName = &select.GetAttributeValue("record"); &outputRowset = CreateRowset(@("Record." | &recordName)); &whereClause = &select.GetElementsByTagName("where"); If &whereClause <> Null And &whereClause.Len <> 0 Then &fieldName = &whereClause.Get(1).GetAttributeValue("field"); &fieldValue = &whereClause.Get(1).GetAttributeValue("value"); &outputRowset.Fill("WHERE " | &fieldName | "= :1", &fieldValue); Else &outputRowset.Fill(); End-If; &Return_MSG = CreateMessage(OPERATION.EXAMPLE, %Int⇒ Broker_Response); &xmlResponseDoc = &Return_MSG.GetXmlDoc(); &b = &xmlResponseDoc.CopyRowset(&outputRowset); Return &Return_MSG;
SoapDoc Class Inbound Synchronous Example
Note. Because GetXmlDoc returns an XmlDoc object, you must receive the inbound request message as an XmlDoc object, then convert it to a SoapDoc object to process it with SOAP methods.
Local XmlDoc &request, &response; Local string &strXml; Local SoapDocs &soapReq, &soapRes; Local Message &Response_Message; &soapReq = CreateSoapDoc(); &request = &MSG.GetXmlDoc(); &soapReq.XmlDoc = &request; &OK = &soapReq.ValidateSoapDoc(); &parmN = &soapReq.GetParmName(1); &parmV = &soapReq.GetParmValue(1); &Response_Message = CreateMessage(OPERATION.SoapExample, %IntBroker_Response); &response = &Response_Message.GetXmlDoc(); &soapRes = CreateSoapDoc(); &soapRes.AddEnvelope(0); &soapRes.AddBody(); &soapRes.AddMethod("StockPrice", 1); &soapRes.AddParm(&parmN, &parmV); &soapRes.AddParm("Price", "29"); &OK = &soapRes.ValidateSoapDoc(); &response = &soapRes.XmlDoc; Return &Response_Message;
Click to jump to top of pageClick to jump to parent topicSimulating Receiving Messages from External Nodes
You can use PeopleCode to simulate receiving asynchronous messages from external nodes, including running transformations.
Use can use the IntBroker class InboundPublish method to work with rowset-based and nonrowset-based messages.
The following example shows an inbound publish as part of an OnNotify method implementation with a rowset-based message:
Local Message &MSG_REMOTE; Local Rowset &rs; &rs = &MSG.GetRowset(); /*create the message to be re-published from a simualted remote node*/ &MSG_REMOTE = CreateMessage(OPERATION.QE_FLIGHTPLAN); &MSG_REMOTE.IBInfo.RequestingNodeName = "QE_IBTGT"; &MSG_REMOTE.IBInfo.ExternalOperationName = &MSG_REMOTE.OperationName | "." | &MSG_REMOTE.OperationVersion; &MSG_REMOTE.CopyRowset(&rs); &Ret = %IntBroker.InBoundPublish(&MSG_REMOTE);
The following example shows an inbound publish as part of an OnNotify implementation with a nonrowset-based message:
Local Message &MSG_REMOTE; Local XmlDoc &xmldoc; Local Rowset &rs; &xmldoc = &MSG.GetXmlDoc(); /*create the message to be re-published from a simualted remote node*/ &MSG_REMOTE = CreateMessage(OPERATION.QE_FLIGHTPLAN); /* populate the Remote Message with data to be re-published*/ &MSG_REMOTE.SetXmlDoc(&xmldoc); %IntBroker.InBoundPublish(&MSG_⇒ REMOTE, Node.REMOTE_NODE);
Click to jump to parent topicProcessing Inbound Errors
Click to jump to top of pageClick to jump to parent topicValidating Data
You validate data differently depending on the PeopleCode class that you’re using to receive the message.
XMLDoc Class Validation
You can validate incoming XML DOM-compliant messages by using the XmlDoc document type definition (DTD) that is delivered with your PeopleSoft application.
See XmlDoc Classes.
SoapDoc Class Validation
You can validate SOAP-compliant messages by using the ValidateSoapDoc method in the PeopleCode SoapDoc class.
See SOAPDoc Class.
Message Class Validation
Have a message receiving process validate incoming data by:
The ExecuteEdits method uses the definitional edits to validate the message. You can specify the following system variables alone or in combination. If you don’t specify a variable, all of the edits are processed.
The following example processes all edits for all levels of data in the message structure:
&MYMSG.ExecuteEdits();
The following example processes the Required Field and Prompt Table edits:
&RECPURCHASEORDER.ExecuteEdits(%Edit_Required + %Edit_PromptTable);
ExecuteEdits uses set processing to validate data. Validation by using a component interface or a PeopleCode built-in function is usually done with row-by-row processing. If a message contains a large number of rows per rowset, consider writing the message to a staging table and calling an Application Engine program to do set processing if you want additional error checking.
ExecuteEdits sets several properties on several objects if there are any errors:
If you don’t want to use ExecuteEdits, you can set your own errors by using the field properties. Setting the EditError property to True automatically sets the IsEditError message property to True. You can also specify your own message number, message set number, and so on, for the field. If you use the Exit(1) built-in function, the message status changes to Error when you finish setting the fields that are in error.
Click to jump to top of pageClick to jump to parent topicUsing the Exit Built-in Function
Use the Exit built-in function to invoke a messaging error process when the application finds an error. This works only when you use the PeopleCode Message class to process inbound transactions. The same error processing is invoked automatically if PeopleTools finds an unexpected error, such as a Structured Query Language (SQL) error. The Exit built-in function has an optional parameter that affects how the error is handled.
To handle error processing in application tables, use the Exit built-in function with no parameter, or just let the notification process finish normally. This marks the message receipt as successful and commits the data.
To handle the error tracking and correction with PeopleSoft Integration Broker, use the Exit built-in function with 1 as a parameter to log the errors, perform a rollback, and stop processing.
Using the Exit Built-in Function Without Parameters
In the Exit( ) form (that is, Exit without any parameters specified), all data is committed and the message is marked as complete. Use this to indicate that everything processed correctly and to stop program processing. Note, though, that the message status is set to Complete; therefore, you can’t detect or access errors in the Service Operations Monitor. If errors did occur, the subscription code should write them to a staging table, and then you must handle all of the error processing.
The Exit built-in function:
Following is an example of using Exit without a parameter:
&MSG.ExecuteEdits(); If &MSG.IsEditError then App_Specific_Error_Processing(); Exit(); Else Specific_Message_Processing(); End-if;
Using the Exit Built-in Function with Parameters
When you supply a 1 as a parameter for the Exit built-in function, the function:
You can view all errors that have occurred for this message in the Service Operations Monitor, even those errors that are detected by ExecuteEdits.
Following is an example of using the Exit function with 1 as a parameter:
&MSG.ExecuteEdits(); If &MSG.IsEditError then Exit(1); Else Process_Message(); End-if;
See Also
Click to jump to parent topicUsing Message Object Functionality With Nonrowset-Based Messages
Prior to the PeopleTools 8.44 release, there were two distinct paths for writing and executing PeopleCode for PeopleSoft Integration Broker which were based on whether you were working with rowset-based XML messages or nonrowset-based XML messages.
For rowset-based XML messages, you could use a rowset and all the properties and methods associated with the Message class. For nonrowset-based XML messages, you could not use the Message class, but instead used built-in functions such as PublishXmlDoc and GetMessageXmlDoc. In addition, when working with nonrowset-based messages and these built-in functions, you could only access content data.
Effective with the PeopleTools 8.44 release, when working with nonrowset-based XML messages you can use all of the functionality of the Message object using two new methods, SetXMLDoc and GetXMLDoc.
SetXMLDoc
Use this method to load and pass nonrowset-based data into the Message object.
GetXMLDoc
Use this method to get nonrowset-based data out of the message object.
Click to jump to top of pageClick to jump to parent topicUsing the SetXMLDoc Method
The following example shows how to use SetXMLDoc to use the Message object to publish a nonrowset-based message.
//&XmlDoc holds the nonrowset-based data as before. // create an instance of the Message object &MSG = CreateMessage(OPERATION.QE_F18_ASYNC_XMLDOC); // Load the Message object with the xmldoc data. &MSG.SetXmlDoc(&XmlDoc); // perform a publish for the nonrowset-based message %IntBroker.Publish(&MSG);
Click to jump to top of pageClick to jump to parent topicUsing the GetXMLDoc Method
The following code example shows how to use GetXMLDoc to get nonrowset-based XML out of the Message object.
Local XMLDOC &XmlDoc; // get an xmldoc object loaded with the content data. &XmlDoc = &MSG.GetXmlDoc();
See Also
Message Classes
Click to jump to parent topicGenerating Test Messages
Use the Handler Tester utility to generate test messages.
Click to jump to parent topicWorking With Message Segments
This section provides an overview of message segments and discusses how to:
See Also
Sending and Receiving Large Segmented Messages Using Parallel Processing
Click to jump to top of pageClick to jump to parent topicUnderstanding Message Segments
When you create message segments, you can divide rowset-based and nonrowset-based messages into multiple data containers, or segments, for sending. Depending on the order in which you send a message that contains message segments, the receiving system can process the message as a whole, or process one segment at a time while the others are compressed in memory or held in the application database.
As a result creating message segments can enhance system performance and message exchange, especially when you are working with large messages that exceed one gigabyte (1 GB).
To create and manage message segments, you use several methods and properties of the PeopleCode Message class.
Click to jump to top of pageClick to jump to parent topicUnderstanding PeopleCode used to Work with Message Segments
This section discusses:
Methods Used with Message Segments
The following table lists the PeopleCode methods you can use when you work with message segments.
Method
Class
Description
CreateNextSegment
Message
Designates the end point of one segment and the beginning of a new segment.
DeleteOrphanedSegments
IntBroker
Used to delete segments that might have been orphaned if you were processing message segments using a PeopleSoft Application Engine program that had to be restarted.
DeleteSegment
Message
Deletes a segment.
GetSegment
Message
Gets the segment specified by the passed value. The passed value is the segment number.
UpdateSegment
Message
Use this method to update data within the current segment.
Note. Use the DeleteSegment and UpdateSegment methods only when storing segments data in memory. These methods do not function when segment data is stored in the database.
Properties Used with Message Segments
The following table lists PeopleCode properties that you can use when you work with message segments.
Property
Class
Description
CurrentSegment
Message
Returns a number, indicating which segment is the current segment.
SegmentsUnOrder
IBInfo
Determines whether to process message segments in order or unordered. This property pertains to asynchronous messages only.
The values are:
  • True: Process message segments unordered.
  • False: Process message segments in order. (Default.)
SegmentCount
Message
Returns the total number of segments in a message.
SegmentsByDatabase
Message
Enables you to override where message segment data is stored for a message.
The values are:
  • True: Store message segments awaiting processing in the application database.
  • False: Store message segments awaiting processing in memory. (Default.)
See Also
PeopleTools 8.52: PeopleCode API Reference PeopleBook
Click to jump to top of pageClick to jump to parent topicConfiguring Nodes to Handle Segmented Messages
This section describes how to configure nodes to handle segmented messages.
Understanding Configuring Nodes to Handle Segmented Messages
Before you can send segmented messages, you must configure the remote node defined on the local system to handle segmented messages by setting the Segment Aware option on the Node Definitions page in the PeopleSoft Pure Internet Architecture.
Warning! Do not set the Segment Aware option for remote PeopleSoft 8.45 or earlier nodes, or for third-party systems. If you do so, the receiving system will consume only the first segment of the messages and ignore any subsequent segments.
Configuring a Node to Handle Segmented Messages
To configure a node to handle segmented messages:
  1. Select PeopleTools, Integration Broker, Integration Setup, Node Definitions.
  2. Select a node with which to work and click OK.
    The Node Definitions page appears.
  3. Select the Segment Aware box.
  4. Click the Save button.
Click to jump to top of pageClick to jump to parent topicCreating Message Segments
This section provides an overview of creating message segments and message segment numbers and discusses how to:
Understanding Creating Message Segments
By default every message has one segment.
To create multiple message segments use the CreateNextSegment method in the location in the message where you want one segment to end and next segment to begin. Continue this process until you have created the desired number of segments for the message.
Segments can contain any number of rowsets of data (rowset-based messages) or rows of data (nonrowset-based messages).
Understanding Message Segment Numbers
When you create a message segment, PeopleSoft Integration Broker assigns a message segment number to the segment.
The first message segment has a message segment number or 1, and message segment numbers are increment by one sequentially thereafter. As an example, if you break a message into three segments, the first segment number is 1, the second segment number is 2, and the third segment number is 3.
The following example shows using the CreateNextSegment method to create three segments in the message QE_FLIGHTPLAN, populating each segment with data from the component buffer.
&MSG = CreateMessage(OPERATION.QE_FLIGHTPLAN); &rs=&MSG.GetRowset(); //Now populate rowset // End of first segment. Beginning of second segment. &MSG.CreateNextSegment(); &rs=&MSG.GetRowset(); //Now populate rowset //End of second segment. Beginning of third segment. &MSG.CreateNextSegment(); &rs=&MSG.GetRowset(); //Now populate rowset %IntBroker.Publish(&MSG);
Counting the Number of Segments in Messages
You might have the need to determine the number of segments in a message. Use the SegmentCount property to determine this information.
Storing Message Segments Awaiting Processing
By default, message segments awaiting processing are stored in memory until all segments are processed. Once all segments are processed, PeopleSoft Integration Broker sends all data as one message.
Use the MessageSegmentFromDB parameter in PSAdmin to specify the number of segments to keep in memory before writing segmented messages to the database. The default value is 10.
For synchronous messages, if the number of segments sent for processing exceeds the set for the MessageSegmentsFromDB parameter, an error occurs.
Overriding Where to Store Message Segments Awaiting Processing
You can override the number of segments to keep in memory before writing segmented messages to the database for a single message using the SegmentsByDatabase property of the Message class.
Storage Location
Description
Memory
When message segments are stored in memory, PeopleSoft Integration Broker writes all segments as one message to the database when you send the message.
To store message segment data in memory, set the SegmentsByDatabase property to False. (Default.)
Application database
When message segments are stored in the database, PeopleSoft Integration Broker writes the segments to the database individually. When you store message segments in the database you can have an infinite number of segments in a message.
To store message segment data in the application database, set the SegmentsByDatabase property to True.
When you store message segments in memory, the number of segments is limited by the value set in the MessageSegmentFromDB parameter in PSAdmin in the Setting for PUB/SUB servers section of the file.
When working with asynchronous messages, if you create more message segments then the value set, all segments are written to the database automatically and the SegmentsByDatabase property will automatically be set to True.
For synchronous messages, attempting to create more segments then the specified value will result in an error message.
Specifying the Order in Which to Process Message Segments
When you work with segmented asynchronous messages you can specify that PeopleSoft Integration Broker process the segments in order or unordered, using the SegmentsUnOrder property of the Message class.
Message Segment Processing
Description
In order
When Integration Broker processes message segments in order, it decompresses all message segments sequentially and then processes the message as a whole. In this situation, only one publication or subscription contract is created.
To process message segment in order, set the SegmentsUnOrder property to False.
Unordered
When Integration Broker processes message segments unordered, it decompresses and processes all segments in parallel. In this situation, the system creates one publication or subscription contract for each message segment.
To process message segment unordered, set the SegmentsUnOrder property to True.
If you attempt to send ordered segmented messages to a node that is not segment aware an error message will be created and can be viewed on the Message Errors tab on the Message Details page in Service Operations Monitor.
Chunking Asynchronous Segmented Messages
Chunking asynchronous segmented messages sends message in blocks to the receiving node.
When using chunking, message instances display in Hold status in the Service Operations Monitor until all chunks are received. Once all chunks are received, the message status switches to New.
Note. Chunking applies to ordered asynchronous messages only.
The number of segments to chunk for an asynchronous message is determined by the value you set for the MessageSegmentByDatabase parameter in PSAdmin. The default value is 10.
As an example, if a message has 20 segments and you set MessageSegmentByDatabase to 5, PeopleSoft Integration Broker will send four groups (array of messages) of segments to the integration gateway, and each group will contain five segments.
Click to jump to top of pageClick to jump to parent topicDeleting Message Segments
You can delete message segments in a message only before you publish the message.
Use the DeleteSegment method of the Message class to perform the action.
You cannot delete the first segment in a message.
The following example demonstrates using the DeleteSegment method in an implementation of the OnRequestSend method.
import PS_PT:Integration:ISend; class Send implements PS_PT:Integration:ISend method Send(); method OnRequestSend(&message As Message) Returns Message; method OnError(&message As Message) end-class; /* constructor */ method Send %Super = create PS_PT:Integration:ISend(); end-method; method OnRequestSend /+ &message as Message +/ /+ Returns Message +/ /+ Extends/implements PS_PT:Integration:ISend.OnRequestSend +/ Local integer &segment_number, &i; Local Rowset &rs; For &i = 1 To &message.SegmentCount &rs = Null; &message.GetSegment(&i); &rs = &message.GetRowset(); /* determine that segment 3 needs to be deleted. */ &segment_number = &i; End-For; &message.DeleteSegment(&segment_number); Return &message; end-method; method OnError /+ &message as Message +/ /+ Extends/implements PS_PT:Integration:ISend.OnError +/ end-method;
Click to jump to top of pageClick to jump to parent topicSending and Receiving Segmented Messages between PeopleSoft Systems
Sending Segmented Messages to PeopleSoft Systems
To send a segmented message, use sending PeopleCode and events as you would with any other message.
Use the PeopleSoft target connector when the receiving node is a PeopleSoft system. The PeopleSoft target connector automatically handles message segments, and no additional configuration is required on the connector.
Before sending a transaction with message segments, on the sending PeopleSoft system, be sure that the Segment Aware box is selected for the remote node that represents the receiving system.
Receiving Segmented Messages from PeopleSoft Systems
To receive segmented message from PeopleSoft systems, use notification PeopleCode or implement the OnRequest method.
Use the PeopleSoft listening connector to receive transactions that contain message segments from other PeopleSoft systems. The PeopleSoft listening connector automatically handles message segments, and no additional configuration is required on the connector.
Click to jump to top of pageClick to jump to parent topicSending and Receiving Segmented Messages to/from Third-Party Systems
Understanding DataChunkCount and DataChunk Properties
PeopleSoft Integration Broker uses two properties to communicate to sending and receiving systems the number of message segments that are contained in a transaction:
DataChunkCount
Indicates the total number of data chunks or message segments contained in the transaction.
DataChunk
Indicates the number of the data chunk or message segment that you are sending.
For example, if there are a total of seven data chunks in the transaction, and the current segment is the third chunk, the DataChunk value for the current message is 3.
Note that when you are sending and receiving message segments between PeopleSoft systems these properties are not used. The PeopleSoft target and listening connectors perform all necessary processing.
Sending Segmented Messages to Third-Party Systems
To send segmented messages from PeopleSoft systems to third-party system, use one of the following target connectors:
No additional target connector configuration is required to send segmented messages. These connectors read the messaging PeopleCode on the integration gateway and determine the number of segments contained in the transaction. They then populate the DataChunkCount and DataChunk parameters and include this information with each outbound segment sent. All of these connectors except for the HTTP target connector send the DataChunkCount and DataChunk information in the message header of each outbound message segment. The HTTP target connector includes the DataChunkCount and DataChunk parameter information in the HTTP header of each outbound message segment.
Before sending a transaction with message segments, on the PeopleSoft system, be sure that the Segment Aware box is selected for the remote node that represents the third-party integration partner.
Receiving Segmented Messages from Third-Party Systems
At this time, only the HTTP listening connector can be used to receive message segments from third-party systems.
To receive segmented messages with third-party integration partners, the third-party must specify the following DataChunkCount and DataChunk parameters in the HTTP properties, query arguments, or SOAP header:
The receiving PeopleSoft system must use the HTTP listening connector as only this connector monitors transactions for these parameters.
After the third party sends in the first segment, the PeopleSoft system sends an acknowledgement to the third-party system. The acknowledgment contains a transaction ID that the third-party integration partner must include with all subsequent segments.
The following bullet points describe sample processing for a third-party integration partner sending a transaction to a PeopleSoft system that contains three segments:
  1. First segment processing:
    1. The third-party integration partner prepares the first message/segment of the transaction. In the HTTP properties, query string, or SOAP header, it sets the DataChunk equal to 1 indicating the first chunk, and sets the DataChunkCount equal to 3 indicating total number of chunks to be sent for the transaction.
    2. When the request is received by the PeopleSoft system the data chunk is saved in the database as a segment.
    3. In the Service Operations Monitor the transaction displays a status of Hold.
    4. The PeopleSoft system sends an acknowledgement to the third-party system, which includes a transaction ID.
      Note. The third-party integration partner must include the transaction ID as part of all subsequent requests for the transaction. The PeopleSoft system uses the transaction ID to identify the segments that belong to the transaction.
  2. Second segment processing:
    1. The third-party integration partner prepares the second message/segment of the transaction. In the HTTP properties, query string, or SOAP header, it sets the DataChunk equal to 2 indicating that the message is the second chunk, and sets the DataChunkCount equal to 3 indicating total number of chunks to be sent for the transaction. It also specifies the transaction ID sent by the PeopleSoft system in the acknowledgement for the first segment.
  3. Third segment processing:
    1. The third-party integration partner prepares the third message/segment of the transaction. In the HTTP properties, query string, or SOAP header, it sets the DataChunk equal to 3 indicating that the message is the third chunk, and sets the DataChunkCount equal to 3 indicating total number of chunks to be sent for the transaction. It also specifies the transaction ID sent by the PeopleSoft system in the acknowledgement for the first segment.
    3. Since the PeopleSoft system has received all of the segments in the transaction, in the Service Operations Monitor the transaction displays a status of New.
    4. The PeopleSoft system processing the transaction like any other transaction at this point.
The PeopleCode to read the data chunks/segments is the Message Segment API.
Click to jump to top of pageClick to jump to parent topicSending, Receiving, and Correlating Multiple Segmented Messages
Previous sections in this chapter have discussed sending one message that contains multiple message segments. For very large messages this can have performance impact due to the large number of segments.
PeopleSoft provides PeopleCode that allows you to send multiple messages with multiple segments and then correlate them into one transaction on the receiving system. So instead of sending one message with 50 message segments, you can send 10 messages with 5 message segments using parallel processing, and then correlate the 10 messages on the receiving system.
The InitializeConversationId property on the Message object, provides the correlation between messages. The FirstCorrelation method on the Message object ensures that the database table is truncated after receipt of the first message only.
On the first message to be published set the InitializeConversationId property to True. After the message is published retrieve the transaction ID from the message. For all subsequent messages, set the CorrelationID property to the value of the transaction ID returned from the first message. As a result, when the messages arrive at the receiving system they have different transaction IDs, but all have the same correlation ID.
On the receiving system when the first message is received the database table is truncated. To prevent a destructive load from occurring with the receipt and processing of each subsequent message, use the PreNotify event. You can use the PreNotify event to truncate the database table upon receipt of the first message. In subsequent messages use the FirstCorrelation method in the event, setting the method to True, to determine if a prior message with the same correlation ID has already run the event.
The following example shows an example of how the sending system uses the InitializeConversationId property:
/*First Message to Publish */ &MSG. InitializeConversationId = true; %IntBroker.Publish(&MSG); &strCorrelationID = &MSG.TransactionId; /* all subsequent message to correlate*/ &MSG. IBInfo.ConversationID = &strCorrelationID; %IntBroker.Publish(&MSG);
The following example shows an example of how the receiving system uses the FirstCorrelation method in the PreNotify event:
PreNotify Event: If &MSG.FirstCorrelation() = true Then /* process the event logic */ End-If;
Accessing message segments is described elsewhere in this section.
See Accessing Segments in Messages.
See Also
FirstCorrelation
Click to jump to top of pageClick to jump to parent topicAccessing Segments in Messages
After you receive a segmented message, use the GetSegment method of the Message class to access message segment data.
After you access a message segment, use the Message class GetRowset or GetXmlDoc methods to work with the contents of the segment.
Warning! You can access only one segment in a message at a time. When you access a message segment, PeopleSoft Integration Broker removes the previously accessed message segment from memory.
When you access a message segment, set the existing rowset to null to eliminate storing multiple rowsets in the data cache.
The following example shows using the GetSegment method to access a message segment in the message QE_FLIGHTDATA.
For &i = 1 To &MSG.SegmentCount &rs = Null; //Null the rowset to remove it from memory &MSG.GetSegment(&i); &rs = &MSG.GetRowset(); &REC = &rs(1).QE_FLIGHTDATA; &FLIGHTDATA = CreateRecord(Record.QE_FLIGHTDATA); &REC.CopyFieldsTo(&FLIGHTDATA); /* Parse out Message Data */ &acnumber_value = &FLIGHTDATA.QE_ACNUMBER.Value; &msi_sensor_value = &FLIGHTDATA.QE_MSI_SENSOR.Value; &ofp_value = &FLIGHTDATA.QE_OFP.Value; &actype_value = &FLIGHTDATA.QE_ACTYPE.Value; &callsign_value = &FLIGHTDATA.QE_CALLSIGN.Value; &squadron_value = &FLIGHTDATA.QE_SQUADRON.Value; &comm1_value = &FLIGHTDATA.QE_COMM1.Value; &comm2_value = &FLIGHTDATA.QE_COMM2.Value; &ecm_value = &FLIGHTDATA.QE_ECM.Value; &outstring = "Send Async Flight test"; /* Construct Output String */ &outstring = &outstring | &acnumber_value | &CRLF | &msi_sensor_value | &CRLF | &ofp_value | &CRLF | &actype_value | &CRLF | &callsign_value | &CRLF | &squadron_value | &CRLF | &comm1_value | &CRLF | &comm2_value | &CRLF | &ecm_value; /* Log Output String into page record */ &FLIGHTDATA.GetField(Field.DESCRLONG).Value = &outstring; SQLExec("DELETE FROM PS_QE_FLIGHTDATA"); &FLIGHTDATA.Insert(); End-For;
Click to jump to top of pageClick to jump to parent topicViewing Message Segment Data
The Service Operations Monitor Message Details page provides information about messages that contain segments.
See Also
PeopleTools 8.52: Integration Broker Service Operations Monitor PeopleBook
Click to jump to top of pageClick to jump to parent topicUsing Restartable Processing for Publishing Large Messages in Batch
This section provides an overview, prerequisites and setup steps for using restartable processing for publishing large asynchronous segmented messages in batch.
Understanding Using Restartable Processing
PeopleSoft provides a PeopleSoft Application Engine library module, IB_SEGTEST, that you can use as a template to create a module to aid in processing large messages and messages in batch for outbound asynchronous PeopleSoft Integration Broker segment data with restart capability.
With restart capability, if there is an abnormal program termination, you can correct any data errors and continue processing from the point of the last commit without having to reload message segment data from the beginning.
Understanding the IB_SEGTEST Application Engine Library Module
This section provides overview information for using the IB_SEGTEST
The IB_SEGTEST library module consists of three sections:
Prerequisites
To use the information provided in this section, you should have a thorough understanding of PeopleSoft Application Engine.
Using the IB_SEGTEST Library Module
This section provides an overview of the high-level list of tasks to perform to set up a PeopleSoft Application Engine program to perform restartable message processing.
  1. Make a copy of IB_SEGTEST, including all sections and PeopleCode.
    From here on, the copy of the application engine library module is referred to as IB_SEGTEST1, but you can use any name you choose.
  2. In the State Records tab of IB_SEGTEST1, verify that PSIBSEGRSTR_AET is the default state record. Replace PT_EIP_ERR_AET with whatever state record is used in the main application engine program that will be calling the Library module.
    Note that IB_SEGTEST1 is flagged as not restartable. Since database commits will be performed in the middle of PeopleCode processing, the only way the commits can take effect is if the module is flagged as not restartable.
  3. The application engine program used to call IB_SEGTEST1 should be restartable.
    Always issue a commit in the step prior to calling the library module IB_SEGTEST1.
  4. In the application engine program that will be calling IB_SEGTEST1, insert a step to call IB_SEGTEST1, section Section1. Insert the step at the point in time when you want to do the message publish. You must issue a commit prior to calling this section, otherwise there will be a ‘Unable to Process Commit’ error issued from within IB_SEGTEST1.
  5. Add PSIBSEGRSTR_AET as an additional state record to the calling application engine program.
  6. Since both programs now share state records, when IB_SEGTEST1 is called, all state record values will be passed on to the called module. Presumably all application values needed to extract application data would be stored in the application state record.
  7. Modify the PeopleCode in IB_SEGTEST1.Section1. Several comments have been added to the code to aid in the modifications. Note the following:
See Also
PeopleTools 8.52: PeopleSoft Application Engine PeopleBook
Click to jump to parent topicPopulating and Retrieving Document Data
Click to jump to top of pageClick to jump to parent topicUnderstanding Populating and Retrieving Document Data
This section provides guidelines for instantiating Document objects, and populating and retrieving document data from document message types.
Memory Management in Message Segments that Use Documents
Following these guidelines when populating or retrieving document data from message segments:
Click to jump to top of pageClick to jump to parent topicInstantiating Document Objects
This section discusses and provides examples for how to:
Instantiating Document Objects Using Package, Name, and Version
You can instantiate a Document object using the CreateDocument built-in function. Using this approach, you use the Create Document built-in function, and then specify the document package name, the document name, and the document version, as shown in the following example:
&DOC = CreateDocument("Purchasing", "PurchaseOrder", "v1");
Instantiating Document Objects Using Document Keys
The following code example shows instantiating a Document object using the a document key. This approach uses the CreateDocumentKey and CreateDocument built-in functions.
First you instantiate a Document Key object, using the CreateDocumentKey built-in function and passing in the document package name, document name, and document version. You then instantiate a Document object using the CreateDocument built-in function, and pass in the document key.
&DOCKEY = CreateDocumentKey("Purchasing", "PurchaseOrder", "v1"); &DOC = CreateDocument(&DOCKEY);
Instantiating Document Objects for Document Message Types
The following example shows how to instantiate a document object when the document is being used as a message type.
&DOC = &MSG.GetDocument();
Click to jump to top of pageClick to jump to parent topicPopulating Document Data
Populating Documents from Messages
The following example shows how to use the CreateMessage built-in function to populate a document from a message:
&MSG = CreateMessage(Operation.PURCHASE_ORDER); &DOC = &MSG.GetDocument();
Populating Documents Using Rowsets
The following example shows using the CreateMessage built-in function and the Document class to populate a document using a rowset:
Local Message &MSG; Local Document &DOC; &MSG = CreateMessage(Operation.PURCHASE_ORDER); &DOC = &MSG.GetDocument(); /* Get Rowset */ &Rowset = &DOC.GetRowset(); /* populate rowset like any other rowset /* update document with popualted rowset * / &nRet = &DOC.UpdateFromRowset(&Rowset); If (&nRet) = True Then %IntBroker.Publish(&MSG); End-If;
Populating Message Segments with Documents
The following example shows code for populating message segments with documents.
After you code to populate a segment, set the following statement to NULL to release memory:
&DOC = null;
Then, set the following statement to TRUE to manage memory and guarantee that only one segment is in memory at a given time:
&DOC = &MSG.GetDocument(true);
If you do not following these coding guidelines, memory will get filled with data from all segments in the message.
The previous statements are in emphasis in the following example:
Declare Function PopulateDocument PeopleCode QE_FLIGHTDATA.QE_ACNUMBER Field⇒ Formula; Local Document &DOC; &MSG = CreateMessage(Operation.FLIGHTPLAN_DOC); /*pass in true to get ownership of the object*/ / ​&DOC = &MSG.GetDocument(true); /*popualte the docment with data */ PopulateDocument(&DOC, 1); /*create a new segment */ &MSG.CreateNewSegment(); /* null out object to release memory */ ​&DOC = null; ​&DOC = &MSG.GetDocument(true); PopulateDocument(&DOC, 2); &MSG.CreateNewSegment(); ​&DOC = null; ​&DOC = &MSG.GetDocument(true); ​PopulateDocument(&DOC, 3); /* publish segmented Message (3 segments) */ %IntBroker.Publish(&MSG);
Click to jump to top of pageClick to jump to parent topicRetrieving Document Data
This section discusses and provides code examples for how to:
Retrieving Document Data from the Message Object
The following code provides an example of how to retrieve a document from the Message object:
Local Message &MSG; Local Document &DOC; Local Primitive &PRIM; Local Compound &COM, &COM_ID, &COM_BILL, &COM_SHIP, &COM_ITEM; Local Collection &COL_ITEM; &MSG = CreateMessage(Operation.PURCHASE_ORDER); &DOC = &MSG.GetDocument(); &COM = &DOC.DocumentElement; &COM.GetPropertyByName("LanguageCode").Value = "ENG"; /* Populate TransactionID Compound */ &COM_ID = &COM.GetPropertyByName("TransactionId"); &COM2.GetPropertyByIndex(1).value = "KAC"; &COM2.GetPropertyByIndex(1).value = "12345678"; /* Populate BillTo Compound */ &COM_BILL = &COM.GetPropertyByName("BillTo"); &COM5.GetPropertyByName("name").Value = "RobbyNash"; &COM5.GetPropertyByName("number").Value = 713; &COM5.GetPropertyByName("street").Value = "High Wind"; &COM5.GetPropertyByName("unit").Value = ""; &COM5.GetPropertyByName("city").Value = "Paia"; &COM5.GetPropertyByName("state").Value = "Maui HI"; &COM5.GetPropertyByName("zipcode").Value = "96779"; /* Populate item_collection Collection (2 rows) */ &COL_ITEM = &COM.GetPropertyByName("item_collection"); &COM_ITEM = &COL_ITEM.CreateItem(); &PRIM = &COM_ITEM.GetPropertyByName("item"); &PRIM.Value = "mast"; &PRIM = &COM_ITEM.GetPropertyByName("sku"); &PRIM.Value = "123322"; &PRIM = &COM_ITEM.GetPropertyByName("price"); &PRIM.Value = 300; &PRIM = &COM_ITEM.GetPropertyByName("quantity"); &PRIM.Value = 12; &nRet = &COL_ITEM.AppendItem(&COM_ITEM); &COM_ITEM = &COL_ITEM.CreateItem(); &COM5.GetPropertyByName("item").Value = "boom"; &COM5.GetPropertyByName("sku").Value = "123334"; &COM5.GetPropertyByName("price").Value = 270; &COM5.GetPropertyByName("quantity").Value = 10; &nRet = &COL_ITEM.AppendItem(&COM_ITEM); %IntBroker.Publish(&MSG);
Retrieving Document Data from Message Segments
The following code example shows an example of retrieving document data from message segments. As discussed elsewhere in this section, the example shows setting the following statement to NULL :
&DOC = Null;
Setting the statement to NULL clears memory between segment loops:
import PS_PT:Integration:INotificationHandler; class DOCUMENT_TESTER implements PS_PT:Integration:INotificationHandler method FLIGHTDATA(); method OnNotify(&MSG As Message); end-class; /* constructor */ method FLIGHTDATA end-method; method OnNotify /+ &MSG as Message +/ /+ Extends/implements PS_PT:Integration:INotificationHandler.OnNotify +/ /* Variable Declaration */ Local Rowset &rs; Local Document &DOC; Local Record &FLIGHTDATA, &REC; Local integer &i; /* get each segment of data via a Document and proces it */ For &i = 1 To &MSG.SegmentCount /* null out object to release memory */ ​&DOC = Null; &MSG.GetSegment(&i); /* pass true to GetDocument method to take ownership of object */ ​&DOC = &MSG.GetDocument( True); /* process Document data for each segment */ End-For; end-method;
Retrieving Document Data within a Notification Event Using Message Segments
The following code example demonstrates how to retrieve document data within an Notification event using message segments.
&DOC = Null;
For &i = 1 To &MSG.SegmentCount ​ &DOC = Null; ​ &MSG.GetSegment(&i); &DOC = &MSG.GetDocument(); &COM = &DOC.DocumentElement; &str = &COM.GetPropertyByName("LanguageCode").Value; &COM_ID = &COM.GetPropertyByName("TransactionId"); &str = &COM_ID.GetPropertyByIndex(2).Value; &COM_BILL = &COM.GetPropertyByName("BillTo").Value; &str = &COM_BILL.GetPropertyByName("name").Value; &COL_ITEM = &COM.GetPropertyByName("item_collecion"); For &j = 1 To &COL_ITEM.count &COM_ITEM = &COL_ITEM.GetItem(&j); &str = &COM_ITEM.GetPropertyByName("item").Value; End-For; End-For;
Click to jump to parent topicSending and Receiving Binary Data
Click to jump to top of pageClick to jump to parent topicUnderstanding Sending and Receiving Binary Data
PeopleSoft supports the MTOM protocol for sending and receiving binary data using service operations. While you can send and receive binary data using SOAP, doing so requires that you Base64-encode the data, which can increase message size by 33 percent or more. The MTOM protocol enables you to send and receive binary data in its original binary form, without any increase in size due to encoding.
Whether sending or receiving MTOM-encoded binary data, you use message segments to store the data. The SegmentContentType property of the Message object is used to set or read the content type of each message segment.
Click to jump to top of pageClick to jump to parent topicSending MTOM-Encoded Binary Data
This section discusses how to send MTOM-encoded binary data and discusses how to:
Setting Target Connector Properties to Send MTOM-Encoded Binary Data
When sending MTOM-encoded binary data, you must use the HTTP target connector. The HTTP target connector features an MTOM property that you must set to Y for MTOM encoding to occur. When you set the MTOM property to Y, the HTTP target connector attempts to convert all outgoing message to the MTOM wire format.
See Using the HTTP Target Connector.
Developing Messages to Send MTOM-Encoded Binary Data
An outgoing MTOM message is composed of a SOAP message and one or more sets of binary data. Segments are used to add the binary data to the outgoing request.
For each chunk of data, use a single segment as follows:
  1. Create the segment.
  2. Copy the data to the segment.
  3. Add the MIME type that is to appear for the MIME part containing the binary in the outgoing MTOM wire message.
  4. Set the content transfer encoding to binary.
In PeopleCode this appears as:
&theMessage.CreateNextSegment(); If (&theMessage.SetContentString(&dataString)) Then &theMessage.SegmentContentType = "image/jpeg"; &theMessage.SegmentContentTransfer = %ContentTransfer_Binary; End-If;
The SetContentString method requires character data, and is not capable of passing binary data. For MTOM, pass in a Base64–encoded string that contains the binary data. The File object method GetBase64StringFromBinary allows a binary file to be read in and captured as a string; use this string to set the data for the newly created segment.
See SetContentString, GetBase64StringFromBinary.
When seen on the wire, the SOAP XML in the MIME multipart message contains xop:Include references. These references point to the MIME parts that contain the binary data. In order to be able to construct these references, Integration Broker requires that a specific XML element, PsftXopInclude, is present in the outgoing message.
Each PsftXopInclude element corresponds directly to an xop:include in the outgoing wire message, and therefore each PsftXopInclude element logically corresponds to an instance of binary data. Placement of the PsftXopInclude element in the XML is application-specific; Integration Broker does not require any particular location.
In the following example the first instance of the PsftXopInclude element corresponds to the logical point to include an image and the second PsftXopInclude element corresponds to the logical point to include a binary document:
<?xml version='1.0'?> <JobApplication> <Photo name='JohnSmith'> <PsftXopInclude SegmentNumber='1'/> </Photo> <Resume name='JohnSmithCV'> <PsftXopInclude SegmentNumber='2'/> </Resume> </JobApplication>
The value of the SegmentNumber attribute is used by Integration Broker to link the PsftXopInclude entry to a specific segment used to add the data. For the purposes of MTOM, the first segment used to add binary data is considered to be number 1, the second segment, number 2, and so on. Care should be taken when setting these values as Integration Broker does not check to ensure that they are correct; they are used as-is to build the xop:include references in the wire message.
In the previous example, the message data is not SOAP-wrapped. You can choose to build your own SOAP wrapper or elect to have Integration Broker SOAP-wrap the message. If Integration Broker is to SOAP wrap the message, you must set the HTTP target connector property SOAPUpContent to Y.
An example of XML to use this feature is as follows:
<?xml version="1.0"?> <flt:process xmlns:flt=" http://xmlns.oracle.com/Enterprise/ Tools/schemas/flightdata.v1"> <PsftXopInclude/> <flt:input1>515</flt:input1> <PsftXopInclude/> <flt:input2>664</flt:input2> </flt:process>
You would include the previous XML in the XmlDoc object and add it to the first segment of the message.
The additional segments include the binary data associated with each declaration. For example:
&MSG = CreateMessage(Message.FLIGHTDATA); &MSG.SetXmlDoc(&xmldoc); &MSG.CreateNextSegment(); &MSG.SetContentString("your encoded image data"); &MSG.SegmentContentType = "image/gif"; &MSG.SegmentContentTransfer = %ContentTransfer_Binary; &MSG.CreateNextSegment(); &MSG.SetContentString("your encoded video here") &MSG.SegmentContentType = "video/mp4"; &MSG.SegmentContentTransfer = %ContentTransfer_Binary; %IntBroker.Publish(&MSG);
The following code example provides another XML example that demonstrates using this feature:
Local File &theFile; Local XmlDoc &theXmlDoc; Local Message &theMessage; Local string &theBase64encodedString; /* note: this example does not have any error handling, in */ /* order to keep the code relatively short and concise. */ /* create the message, and add the basic XML message data */ /* ------------------------------------------------------ */ &theMessage = CreateMessage(Operation.QE_FLIGHTPLAN_UNSTRUCT); Local string &xml; /* this example requires the SOAPUPContent HTTP Target */ /* connector property to be set to "Y", so that the */ /* outbound XML will be SOAP wrapped. */ &xml = &xml | "<?xml version='1.0'?>"; &xml = &xml | "<JobApplication>"; &xml = &xml | "<Photo name='JohnSmith'>"; &xml = &xml | "<PsftXopInclude SegmentNumber='1'/>"; &xml = &xml | "</Photo>"; &xml = &xml | "<Resume name='JohnSmithCV'>"; &xml = &xml | "<PsftXopInclude SegmentNumber='2'/>"; &xml = &xml | "</Resume>"; &xml = &xml | "</JobApplication>"; &theXmlDoc = CreateXmlDoc(&xml); &theMessage.SetXmlDoc(&theXmlDoc); /* add an image to the outgoing message */ /* ------------------------------------ */ &theFile = GetFile("D:\output\smallPicture.jpg", "R", %FilePath_Absolute); If &theFile.IsOpen Then &theBase64encodedString = &theFile.GetBase64StringFromBinary(); &theFile.Close(); End-If; &theMessage.CreateNextSegment(); If (&theMessage.SetContentString(&theBase64encodedString)) Then &theMessage.SegmentContentType = "image/jpeg"; &theMessage.SegmentContentTransfer = %ContentTransfer_Binary; End-If; /* add a PDF file to the outgoing message */ /* -------------------------------------- */ &theFile = GetFile("D:\output\smallDocument.pdf", "R", %FilePath_Absolute); If &theFile.IsOpen Then &theBase64encodedString = &theFile.GetBase64StringFromBinary(); &theFile.Close(); End-If; &theMessage.CreateNextSegment(); If (&theMessage.SetContentString(&theBase64encodedString)) Then &theMessage.SegmentContentType = "application/pdf"; &theMessage.SegmentContentTransfer = %ContentTransfer_Binary; End-If; /* send the message */ /* ---------------- */ %IntBroker.Publish(&theMessage);
See Also
SetContentString
SegmentContentType
Click to jump to top of pageClick to jump to parent topicReceiving Binary Data
This section discusses receiving MTOM-encoded binary data requests and discusses how to:
Understanding Receiving MTOM-Encoded Binary Data
To receive MTOM-encoded binary data from integration partners, you must use the PeopleSoft services listening connector or the HTTP listening connector.
When a message is received by an MTOM-enabled connector, the gateway first determines if the message is using MTOM. If it is not, the message is processed normally. If MTOM is detected, the gateway extracts the SOAP message from the MIME and then encodes the binary data in the MIME parts. This is effectively a pre-processing step and is done first, before normal processing can occur. Once complete, the SOAP message is then treated no differently from any other SOAP message received. The binary data is Base64 encoded, and is attached to the message in the form of segments.
Enabling Listening Connectors to Receive MTOM-Encoded Binary Data
The following listening connectors can receive and process MTOM-encoded messages:
You must enable these connectors for receiving and processing MTOM messages for any MTOM processing to occur. You enable these properties in the integration gateway properties file. The properties appear the MTOM Enable ListeningConnectors section as shown in the following example:
# MTOM Enable ListeningConnectors # #ig.MTOM.enablePeopleSoftServiceListeningConnector=true #ig.MTOM.enableHttpListeningConnector=true
By default the properties are not enabled and are commented out.
To enable a given connector, remove the comment (#) and ensure that the property is set to true.
Note. When these properties are enabled there is a slight performance degradation to all non-MTOM requests sent to the connectors. The degradation is a result of system process that takes place to determine if requests are MTOM-encoded messages.
Using PeopleCode to Process Inbound MTOM–Encoded Binary Data
MTOM messages are processed in the form of message segments. The system processes inbound MTOM requests in two general steps:
The first segment contains the XML data. The xop:include references in the XML are replaced with PsftXopInclude elements, and each instance will point to the segment containing the associated binary data.
The structure of this XML is application-specific, and therefore processing of this XML cannot be easily generalized. You may be able to use the location of the PsftXopInclude elements in the XML to derive information about the binary data segments.
Consider the following inbound MTOM request example:
<?xml version='1.0'?> <JobApplication> <Photo name='JohnSmith'> <PsftXopInclude SegmentNumber='2'/> </Photo> <Resume name='JohnSmithCV'> <PsftXopInclude SegmentNumber='3'/> </Resume> </JobApplication>
In this example, the XML has been structured such that the parent element contains a name value for the associated binary content. A more complete XML might also contain information such as file type, size, or creation date. Again, the structure of this XML is not necessarily determined by Integration Broker, but rather by the design of the application itself.
All segments after the first contain the Base64–encoded binary data. This data is accessible as a string. Processing of this is also application-specific. Some applications may decide to store the encoded string for later use, while others may wish to decode it immediately.
To process the string immediately, use the PeopleCode File object method WriteBase64StringToBinary to decode the string and to write it out as a byte array to a file. Once the method has completed and the file closed, the file can be accessed as any other file on the file system.
See WriteBase64StringToBinary.
The following code example shows how to use PeopleCode to process and inbound MTOM request:
import PS_PT:Integration:INotificationHandler; class MTOM_CLASS implements PS_PT:Integration:INotificationHandler method MTOM_CLASS(); method OnNotify(&MSG As Message); method getFileExtensionForContentType(&contentType As string) Returns string; end-class; /* constructor */ method MTOM_CLASS end-method; method getFileExtensionForContentType /+ &contentType as String +/ /+ Returns String +/ Evaluate &contentType When = "image/jpeg" Return "jpg" When = "application/pdf" Return "pdf" When-Other Return "unk" End-Evaluate; end-method; method OnNotify /+ &MSG as Message +/ /+ Extends/implements PS_PT:Integration:INotificationHandler.OnNotify +/ /* note: this example does not have any error handling, in */ /* order to keep the code relatively short and concise. */ /* Variable Declaration */ Local integer &i, &j; Local string &contentSectionData, &contentSectionType; Local File &theFile; Local XmlDoc &theXml; /* the first section will be XML */ /* ----------------------------- */ &MSG.GetSegment(1); &contentSectionData = &MSG.GetContentString(1); &theXml = CreateXmlDoc(&contentSectionData); Local array of XmlNode &nodeList; /* get all PsftXopInclude nodes, ignore namespaces */ &nodeList = &theXml.DocumentElement.FindNodes("//*[local-name()= 'PsftXopInclude']"); /* all subsequent sections will be binary data */ /* ------------------------------------------- */ For &i = 2 To &MSG.SegmentCount &MSG.GetSegment(&i); &contentSectionData = &MSG.GetContentString(&i); /* get the type information directly from the segment */ /* we'll use this to determine the file extension */ &contentSectionType = &MSG.SegmentContentType; Local string &theFileName = "D:\output\"; For &j = 1 To &nodeList.Len If (&nodeList [&j].GetAttributeValue("SegmentNumber") = String(&i)) Then rem we've found the entry that matches this content section; rem use the 'name' attribute from the parent XML element to rem get the file name rem NOTE - this assumes a particular XML format that may not rem be the same for most applications; &theFileName = &theFileName | &nodeList [&j].ParentNode. GetAttributeValue("name"); End-If; End-For; rem build the complete filename, including the extension; &theFileName = &theFileName | "." | %This.getFileExtensionForContentType (&contentSectionType); &theFile = GetFile(&theFileName, "W", %FilePath_Absolute); If &theFile.IsOpen Then &theFile.WriteBase64StringToBinary(&contentSectionData); &theFile.Close(); End-If; End-For; end-method;
See Also
Using the integrationGateway.properties File
Click to jump to parent topicUsing PeopleCode to Manage REST Service Operations
Click to jump to top of pageClick to jump to parent topicUsing PeopleCode to Manage Provider REST Service Operations
Reading Document Template Data and Populating Response Messages
To read document template data and populate provider response messages, use the OnRequest method. You implement the OnRequest method using an application class, specifically using the IRequestHandler application interface.
When the OnRequest event is fired the document template is populated with the values based on the corresponding URI template. You can use the populated primitive values along with the URI Template index to determine the proper response message data to send back to the client. The code snippet below shows a simple example of reading the document template data and populating the response message. Note that one can override the HTTP return code that is sent as part of the response to the client.
import PS_PT:Integration:IRequestHandler; class WeatherData implements PS_PT:Integration:IRequestHandler method WeatherData(); method OnRequest(&MSG As Message) Returns Message; method OnError(&request As Message) Returns string; end-class; /* constructor */ method WeatherData end-method; method OnRequest /+ &MSG as Message +/ /+ Returns Message +/ /+ Extends/implements PS_PT:Integration:IRequestHandler.OnRequest +/ /* Variable Declaration */ Local Document &Doc; Local Compound &COM; Local Message &response; Local XmlDoc &weather_xmldoc; Local XmlNode &info, &country, &state, &city, &day, &data, &flightdata; Local Rowset &RS; /* get populated Document Template */ &Doc = &MSG.GetURIDocument(); &COM = &Doc.DocumentElement; &weather_xmldoc = CreateXmlDoc(""); /* populate xmldoc with data from the Document Template */ &info = &weather_xmldoc.CreateDocumentElement("WeatherInformation"); &country = &info.AddElement("Country"); &country.NodeValue = &COM.GetPropertyByName("country").Value; &state = &info.AddElement("State"); &state.NodeValue = &COM.GetPropertyByName("state").Value; &city = &info.AddElement("City"); &city.NodeValue = &COM.GetPropertyByName("city").Value; &day = &info.AddElement("Day"); &day.NodeValue = &COM.GetPropertyByName("day").Value; /* determine HTTP method that was invoked to determine proper response /* message */ If &MSG.HTTPMethod = %IntBroker_HTTP_GET Then &data = &info.AddElement("Forecast"); &data.NodeValue = "55 degrees and raining"; &response = CreateMessage(Operation.WEATHERSTATION_GET, %IntBroker_Response); &response.SetXmlDoc(&weather_xmldoc); End-If; If &MSG.HTTPMethod = %IntBroker_HTTP_DELETE Then &data = &info.AddElement("Forecast"); &data.NodeValue = "deleted"; &response = CreateMessage(Operation.WEATHERSTATION_DELETE, %IntBroker_Response); &response.SetXmlDoc(&weather_xmldoc); End-If; Return &response; end-method; method OnError /+ &request as Message +/ /+ Returns String +/ /+ Extends/implements PS_PT:Integration:IRequestHandler.OnError +/ Local Message &Fault_Msg; Local Document &fault_doc; Local Compound &COM; If &request.HTTPMethod = %IntBroker_HTTP_GET Then &Fault_Msg = CreateMessage(Operation.WEATHERSTATION_GET, %IntBroker_Fault); &fault_doc = &Fault_Msg.GetDocument(); &COM = &fault_doc.DocumentElement; &COM.GetPropertyByName("fault_data").Value = &request.IBException. ToString(); Return &fault_doc.GenXmlString(); End-If; Return ""; end-method;
Setting HTTP Reponse Headers
Use the LoadRESTHeaders method of the IBInfo class to load the response headers defined on the routing for a REST-based service operation. Once loaded, the headers can be modified without specifying the connector override property.
The code snippet below shows how to add HTTP response headers to the any REST based service operation response within the OnRequest event.
&response = CreateMessage(Operation.WEATHERSTATION_GET, %IntBroker_Response); &bRet = ​&response.IBInfo.LoadRESTHeaders(); ​ /* any/ modify additional Headers not defined on Routing */ &bRet = &response.IBInfo.IBConnectorInfo.AddConnectorProperties ("Content-Language ", "eng ", %HttpHeader); Return &response;
Retrieving Response HTTP Header Data
You can use the REST method type Head to retrieve meta-information written in response HTTP headers, without having to transport the entire content.
The REST-based service operation created with a method of HEAD does not have a request or response message.
You can assign the OnRequest handler used for the GET method to the service operation to check if the method type is HEAD and, if so, simply send back the HTTP response headers.
The following code snippet shows how to use the OnRequest method to retrieve HTTP response headers
Note. HTTP response headers can be sent back to the client for all REST method types.
If &MSG.HTTPMethod = %IntBroker_HTTP_HEAD Then &response = CreateMessage(Operation.WEATHERSTATION_HEAD, %IntBroker_Response); &bRet = &response.IBInfo.LoadRESTHeaders(); /* any additional Headers not defined on Routing */ &bRet = &response.IBInfo.IBConnectorInfo.AddConnectorProperties ("Content-Language ","eng ", %HttpHeader); &bRet = &response.IBInfo.IBConnectorInfo.AddConnectorProperties ("WWW-Authenticate", "Basic", %HttpHeader); Return &response; End-If;
Click to jump to top of pageClick to jump to parent topicUsing PeopleCode for Consumer REST Service Operations
Invoking a Consumer REST Service Operations
To invoke a consumer REST service operation, the message is instantiated and then the document template is retrieved and populated. The URI index is selected and a SyncRequest method is invoked. The response message contains the HTTP return code. Processing of the data is the same as any other SyncRequest method. In the case of an error, if the User Exception option is selected on the routing, you can attempt to read the fault if defined on the service operation. If the HTTP response code is the same as that defined on the fault message, then the fault message is created and returned. You can read the fault in the document, if the fault message is a Document message type. The message property IsFault is read to determine if a fault message was created.
The code example shows a simple example of populating the document template data and entering the URI resource index to use and invoking the SyncRequest method.
The GetURIDocument method of the Message class is used to retrieve the URI for the REST based on the specified index. The URIResourceIndex property of the Message class is used to set or return the index for the URI as an integer. This index corresponds to the row number in the URI grid of the REST Resource Definition section of the service operation definition.
Declare Function out_BI_results PeopleCode QE_FLIGHTDATA.QE_ACNUMBER FieldFormula; &MSG = CreateMessage(Operation.MAPS_GET); /* Get URI Document and populate with data */ &DOC = &MSG.GetURIDocument(); &COM = &DOC.DocumentElement; &COM.GetPropertyByName("MapType").Value = "topographic"; &COM.GetPropertyByName("Scale").Value = "1:63"; &COM.GetPropertyByName("Planet").Value = "Earth"; &COM.GetPropertyByName("Country").Value = "USA"; &COM.GetPropertyByName("City").Value = "WhiteSalmon"; &COM.GetPropertyByName("Name").Value = "MainSteet"; /* Set URI Resource Index to be used */ &MSG.URIResourceIndex = 1; &return_message = %IntBroker.SyncRequest(&MSG); /* Get return data and display */ If &return_message.ResponseStatus = %IB_Status_Success Then &xmldocReturn = &return_mesage.GetXmlDoc(); out_BI_results(&xmldocReturn.GenXmlString()); /* Read Response Headers if set */ For &i = 1 To &MSG.IBInfo.IBConnectorInfo.GetNumberOfConnectorProperties() If &MSG.IBInfo.IBConnectorInfo.GetConnectorPropertiesType(&i) = %HttpHeader Then &name = &MSG.IBInfo.IBConnectorInfo.GetConnectorPropertiesName(&i); &value = &MSG.IBInfo.IBConnectorInfo.GetConnectorPropertiesValue(&i); End-If; End-For; Else If &return_message.IsFault = True Then &Fault_Doc = &return_message.GetDocument(); &COM = &Fault_Doc.DocumentElement; out_BI_results(&COM.GetPropertyByName("fault_data").Value); Else out_BI_results(&return_message.IBException.ToString()); End-If; End-If;
Adding REST HTTP Connector Headers
Use the LoadRESTHeader method of the Message class to add HTTP header properties not defined on the routing for the service operation.
The code snippet below shows how to modify HTTP headers using PeopleCode
Note. The connector override flag in PeopleCode does not need to be set in this case.
No HTTP properties are currently applicable for REST and will be removed by the Integration Broker framework.
&request = CreateMessage(Operation.MAPS_GET); &bRet = &request.LoadRESTHeaders(); /* add any additional Headers not defined on Routing */ &bRet = &request.IBInfo.IBConnectorInfo.AddConnectorProperties ("Content-Language ", "eng ", %HttpHeader);
Click to jump to top of pageClick to jump to parent topicGenerating Fully-Qualified URLs for REST Resources
In most REST-based services, representations are hypermedia documents that contain not just data, but links to other resources.
Use the GetUrl method contained in the %IntBroker class to generate fully-qualified URLs for REST service operation resources. You can use the URLs with defined HTML definitions to dynamically add REST-based web service URL links.
Note. A provider or a consumer REST based Service Operation representations can be used to generate the fully-qualified link(s).
The syntax of the GetUrl method is:
string &str = ​%IntBroker.GetURL( string <Service Operation>, integer <Resource Index of Service Operation>, document <Document object defined for document Template> , <optional> bool <secure/ unsecure REST tgt location>, <optional> bool <add encoding for unsafe characters >
The following example shows within an implementation (OnRequest event) of a REST-based provider service, HTML is generated using links defined from other REST-based service operations.
method OnRequest Local Document &Doc_Tmpl, &DOC; Local Compound &COM_Tmpl, &COM; Local Message &response; Local string &STR, &STR1, &STR2, &STR3, &STR4, &strHTML; Local boolean &bRet; &response = CreateMessage(Operation.WEATHERSTATION_GET, %IntBroker_Response); /* read URI Document to get parms out from the request*/ &Doc_Tmpl = &MSG.GetURIDocument(); &COM_Tmpl = &Doc_Tmpl.DocumentElement; /* Instantiate a Document object based on the REST based Service */ /* Operations Document Template for which to create a link. */ &DOC = CreateDocument("Weather", "WeatherTemplate", "v1"); &COM = &DOC.DocumentElement; /* based off the data from the request populate the Document object */ If &COM_Tmpl.GetPropertyByName("state").Value = "Washington" Then &COM.GetPropertyByName("state").Value = "Washington"; /* call new method to create fully qualified URL(s) */ &COM.GetPropertyByName("city").Value = "WhiteSalmon"; &STR = %IntBroker.GetURL("WEATHERSTATION_GET", 2, &DOC); &COM.GetPropertyByName("city").Value = "Troutlake"; &STR1 = %IntBroker.GetURL("WEATHERSTATION_GET", 2, &DOC); &COM.GetPropertyByName("city").Value = "Yakima"; &STR2 = %IntBroker.GetURL("WEATHERSTATION_GET", 2, &DOC); &COM.GetPropertyByName("city").Value = "Lyle"; &STR3 = %IntBroker.GetURL("WEATHERSTATION_GET", 2, &DOC); /* use these URLs as bind variables for the HTML definition */ &strHTML = GetHTMLText(HTML.WEATHER_CITIES, &STR, &STR1, &STR2, &STR3); /* set the data in the response message */ &bRet = &response.SetContentString(&strHTML); End-If; Return &response; end-method;
