You define selection criteria to selectively retrieve the data that you want. Selection criteria refine your query by specifying conditions that the retrieved data must meet. For example, you can specify that the system retrieve only those phone numbers with a certain area code instead of all phone numbers.
This chapter discusses how to:
Choose selection criteria.
Define criteria.
Define prompts.
Define HAVING criteria.
Define expressions.
Drill URL in PeopleSoft Query.
Choosing Selection Criteria
Because your PeopleSoft database stores data in tables, you can identify every individual piece of data by saying what column (field) and row (record) it is in. When you create a query, select the data that you want by specifying which columns and rows you want the system to retrieve.
If you run the query after selecting the fields, the system retrieves all the data in those columns; that is, it retrieves the data from every row in the table or tables. This might be much more data than you want or need. You select which rows of data you want by adding selection criteria to the query.
The selection criteria serves as a test that the system applies to each row of data in the tables that you are querying. If the row passes the test, the system retrieves it; if the row does not pass, the system does not retrieve it. For example, suppose that you needed the names of all PeopleStore customers who were not PeopleSoft employees. You would start by creating a query that retrieved the Name and Company fields from the Customer table. You could then add a selection criterion that enables PeopleSoft Query to scan for rows where the company name is not PeopleSoft.
In most cases, a selection criterion compares the value in one of a row’s fields to a reference value. In the preceding example, you would compare the value in the Company field to the constant value PeopleSoft. In other situations, you might compare the value to the value in another record field or to a value that the user enters when running the query.
Defining Criteria
View and edit selection criteria.
Edit criteria properties.
Select condition types.
Enter comparison values.
Specify effective date criteria.
Relate multiple criteria.
Pages Used to Define Criteria|
Page Name |
Definition Name |
Navigation |
Usage |
Query |
QRY_QUERY |
Reporting Tools, Query, Query Manager Click the Create New Query link on the Query Manager search page. Click the Search button. Click the Add Record link to select a record for the query. |
Select a record for the query criteria. |
Fields |
QRY_FIELDS |
Reporting Tools, Query, Query Manager, Fields Select each field that you want to use in the query, and then click the Add Criteria icon, or click the Check All button to select all the fields associated with the record as criteria. |
Select the fields to be used as criteria for the query. |
Criteria |
QRY_CRITERIA |
Reporting Tools, Query, Query Manager, Criteria |
View and edit selection criteria for your query statement. |
Edit Criteria Properties |
QRY_CRITERIA_SEC |
Reporting Tools, Query, Query Manager, Criteria Click the Add Criteria button on the Criteria page or click the Use As Criteria link on the Fields page. |
Edit selection criteria properties for your query statement. |
Viewing and Editing Selection Criteria
Access the Criteria page by selecting Reporting Tools, Query, Query Manager, Criteria.
This is an example of the Criteria page:
Any rows after the first row must include either an AND or OR logical value in the Logical column to specify whether you want the rows to meet this criterion in addition to other criteria that you have defined or as an alternative criterion. The first criterion that you define does not have a value in this column. The default for subsequent criteria is AND.
To reorder the criteria for your query, click the Reorder Criteria button, enter the new positions for the criteria on the Edit Criteria Ordering page, and click OK. You can also click the Add Criteria button from this Criteria page to add additional criteria, and you can click the Group Criteria button to group your criteria logically.
Editing Criteria Properties
Use these steps to access the Edit Criteria Properties page:
Select Reporting Tools, Query, Query Manager.
Create a new query or search for an existing one.
Access the Criteria page, and click the Add Criteria button.
Alternatively, access the Fields page and click the Use As Criteria link.
This is an example of the Edit Criteria Properties page:
Field |
Select this option if you want to base the selection criterion on another field’s value, usually a field in another record component. To compare the values from fields in two records, you must join the record components. When you select this option, you must then select a condition type. See Selecting Condition Types. Select the appropriate comparison operator from the Condition Type drop-down list box. |
Expression |
Select this option if you want PeopleSoft Query to evaluate an expression that you enter before comparing the result to the value in the selected field. When you select this option and click the New Expression link to create a new expression, you must then select an expression type. If you are entering an aggregate value, select the Aggregate Function check box. You can also enter parameters for length and decimal positions. Also enter the expression in the text box. Query Manager inserts this expression into the SQL. |
Creating Criteria Based on a Field
To create criteria based on a field:
If you accessed the page by clicking the Use As Criteria link on the Fields page, Query Manager displays the Edit Criteria Properties page with the selected field populated in the Expression 1 field.
In the Edit Criteria Properties page, specify the criteria for the field, and click the OK button to return to the Fields or Criteria page.
You can also use a field from a record as criteria even if you have not chosen that field for query output.
Creating Criteria Not Based on a Field
To create criteria that is not based on a field:
Access the Edit Criteria Properties page by clicking the Add Criteria button on the Criteria page.
The Edit Criteria Properties page appears enabling you to edit Expression 1 and Expression 2 fields.
In the Choose Expression 1 Type group box, select the Field or Expression option.
Edit the second (right-hand) Expression column to enter comparison values.
Save your query.
The condition type determines how Query Manager compares the values of the first (left-hand) expression to the second (right-hand) expression.
Query Manager also offers a not option that reverses the effect of each condition type. For example, not equal to returns all rows that equal to would not return.
Note. You should use the not version of an operator rather than the NOT operator on the entire criterion. When you use NOT, PeopleSoft Query cannot use SQL indexes to speed up the data search. When you use the not version of an operator, PeopleSoft Query can translate it into a SQL expression that enables it to use the indexes.
This table describes the available condition types:
Condition Types |
Return Values |
The value in the selected record field falls between two comparison values. The range is inclusive. |
The value in the selected record field exactly matches the comparison value. |
This operator is different from the others, in that it does not compare a record field to the comparison value. The comparison value is a subquery. If the subquery returns any data, PeopleSoft Query returns the corresponding row. |
The value in the record field is greater than the comparison value. |
The value in the selected record field matches one of the comparison values in a list. |
The value in the selected record field appears as a node in a tree created with PeopleSoft Tree Manager. The comparison value for this operator is a tree or branch of a tree that you want PeopleSoft Query to search. Note. PeopleSoft Query should not use trees that contain a combination of dynamic details and range details. The results returned from trees with this combination of details may be inaccurate. |
The selected record field does not have a value in it. You do not specify a comparison value for this operator. Key fields, required fields, character fields, and numeric fields do not allow null values. |
The value in the record field is less than the comparison value. |
The value in the selected field matches a specified string pattern. The comparison value may be a string that contains wildcard characters. The wildcard characters that PeopleSoft Query recognizes are % and _. % matches any string of zero or more characters. For example, C% matches any string starting with C, including C alone. _ matches any single character. For example, _ones matches any five-character string ending with ones, such as Jones or Cones. PeopleSoft Query also recognizes any wild-card characters that your database software supports. See your the documentation for your database management system for details. To use one of the wild-card characters as a literal character (for example, to include a % in your string), precede the character with a \ (for example, percent\%). |
Note. If you have selected the EFFDT field on an effective-dated table, PeopleSoft Query also offers special effective date operators.
Entering Comparison Values
This section provides an overview of comparison values and discusses how to:
Select a constant value.
Build a list of values.
Add prompts to an expression list.
Add comparison values to an expression list.
The procedure for entering comparison values differs depending on what kind of value you are entering. If you are comparing one field to another, select the second record field; if you are comparing the rows to a constant value, enter the constant.
The following table describes all the available value types, the pages that appear based on each comparison type, and the fields that you must complete in those pages.
Value Type |
Action |
The value in the selected field is compared to the value in another field, usually a field in another record component. When you select Field as the comparison value, the Choose Record and Field page appears. The Record Alias field lists all the records that are part of the current query. Select the record and the field. The selected field name appears in the second Expression column of that field’s row. |
The value in the selected field is compared to an expression that you enter, which PeopleSoft Query evaluates once for each row before comparing the result to the value in the selected field. When you select Expression as the comparison value, the Define Expression page appears. In the text box, enter a valid SQL expression. To add a field or user prompt to the expression, click the Add Field or Add Prompt link, respectively. These links display the same pages that you see when adding a field or prompt as a comparison value: Add Prompt displays the Run-time Prompt page; Add Field displays the Select a Field page. The only difference is that PeopleSoft Query adds the field or prompt to your expression rather than using it directly as the comparison value. |
The value in the selected field is compared to a single fixed value. When you select Constant as the comparison value, the Define Constant page appears. In the text box, enter the value that you want to compare the first expression to. To add a value by selecting it from a list, click the Look Up button to display the Select a Constant page. Note. A list of constants is available only for fields that have translate values or an assigned prompt table. |
The value in the selected field is compared to a value that you enter when running the query. When you select Prompt as the comparison value, the Define Prompt page appears. Click the New Prompt link to move to the Edit Prompt Properties page. To modify an existing prompt, click the Edit Prompt link. See Defining Prompts. |
The value in the selected field is compared to the data that is returned by a subquery. When you select Subquery as the comparison value, the Define Subquery page appears. Click the Define/Edit Subquery link to move to the Records tab to start a new query. |
The value in the selected field is compared to a list of values that you enter. This value type is available only when the selected operator is in list or not in list. When you select in list as your comparison value, the Edit List page appears. Use the Look Up button to display the Edit List page and search for the desired values. Note. Values will appear here only if you have entered them previously. |
The value in the selected field is compared to the current date on the database server. |
The value in the selected field is compared to a selected set of tree nodes. This value type is available only when the selected operator is in tree or not in tree. When you select Tree Option as the comparison value, the Select Tree Node List page appears. Use this page to create a list of values for PeopleSoft Query to compare to the value from the first expression. |
The value in the selected field enables you to select a tree value as a tree prompt, when the query is run. This value type is available only when the selected operator is in tree or not in tree. When you select the Tree Prompt Option as the comparison value, all options to select tree values at design time are not available. However, you are able to select tree values as tree prompts when you run the query. |
Used on some effective-dated records, the effective sequence is a sequencing number that is provided to further refine the effective date. |
Note. Not all value types are available for all operators. For example, when you select the exists operator, Subquery is the only available value type. After you select an operator, PeopleSoft Query displays only the value types that are available for that operator.
When you select Constant as your comparison value, the Define Constant page appears. In the text box, enter the value to which you want to compare the first expression. To add a value by selecting it from a list, click the Look Up button to display the Select a Constant page.
This is an example of the Select A Constant page:
To select a constant:
Click the Look Up button on the Select A Constant page.
Select the value that you want from the result list by clicking its associated link.
The Select A Constant page appears again with the selected value in the field. If you are working with a date field, you can select a date/constant from a calendar.
If more than one field exists on the Select A Constant page, you must repeat steps 1 and 2 for each field to further narrow your search for the constant.
Click the OK button.
The Edit Criteria Properties page appears with the selected value in the Define Constant page.
Another example of the Select A Constant page:
If this example, to select a constant, click a Select Constant link and the Edit Criteria Properties page reappears with the selected value in the Define Constant section.
When you select In List as your comparison value, the Edit List page appears. Use the Edit List page to build a list of values for PeopleSoft Query to compare to the value from the first expression. (After you have created such a list, you can also use this page to select from the list.)
To add a comparison value to the list, click the Look Up button on the Edit List page.
This is an example of the Edit List page, which dynamically reflects which record is used:
Lists the values that have been selected using the Add Value button. Note. The grid, containing the selected value, appears when a value is selected. To delete a value, select the check box to the left of the appropriate List Members value, and click the Delete Checked Values button. |
Value |
To add a value, enter it into the Value text box and click the Add Value button. The value appears in the List Members grid. To select from a list of values, click the Search button to display the Select a Constant page. Click the Look Up button to display the Look Up page. Enter part of a value in the text box. (The system automatically adds a wild card to the end of the entry, which enables you to do a partial search. For example, if you enter a value of 10, the system returns all values, (up to a total of 300), that begin with 10, such as 10, 100, and 10069.) Click the Look Up button to display the list of values that corresponds to the search criteria. Select the desired value from the list by clicking its associated link. When the Select a Constant page appears again, click the OK button, and the selected value appears in the List Members grid. |
Click to add one or more prompts to the list so that users can enter the comparison values when they run the query. Note. The prompts must be defined before you can select them. If no prompts have been defined, you will receive an error message. |
OK |
Click to accept the values that are listed in the List Members grid. You will return to the Edit Criteria Properties page, where the selected values are displayed in the Edit List page. |
Cancel |
Click to return to the Edit Criteria Properties page without saving selections. |
Adding Prompts to an Expression List
You can add one or more prompts to the expression list so that users can enter comparison values when they run a query.
Note. You must have defined the prompts before you can add them to your expression list.
To add prompts to an expression list:
With the expression list open, click the Add Prompt link in the Edit List page to access the Select a Prompt page.
Click the required prompt.
The prompt appears on the Edit List page.
If you selected the in list operator, you may want to add more than one prompt so that your users can enter more than one value to search for.
To add another prompt, click the Add Prompt link again and select a different prompt.
Because you already have a prompt in place, a different page appears showing the prompt that you have already added.
To add the next prompt, click the New button and complete the Run-time Prompt page.
The settings for this second prompt are the same as those that are used with the first prompt. If you want a different label for this prompt, enter that label in the Heading Text text box.
When you click the OK button, the second prompt appears in the Available Prompts list.
Highlight the second prompt, and click the Select button to add it to the list of comparison values.
The prompt then appears in the Edit List page.
Repeat this process for each prompt that you want to add.
When you finish adding prompts, click the OK button to close the Edit List page.
Adding Comparison Values to an Expression List
When you select the Tree option as the comparison value (available if you select the in tree or not in tree condition type), the Select Tree Node List page appears. Use this page to create a list of values for PeopleSoft Query to compare to the value from the first expression. Click the New Node List link to display the Select Tree page.
If the Selected Nodes List has been previously populated, you can either:
Change the tree by clicking the New Nodes List link.
Open the previously selected tree, bypassing the Tree Selection page, by clicking the Edit Node List link.
Click the name of the tree that you want to display the Display and Select TreeNodes page, which you can use to select which element of the tree PeopleSoft Query will check. If no nodes have been previously selected, the Selected Nodes List grid is collapsed. If you do not know the name of the tree, you can perform a search for the tree.
This is an example of the Select a Tree page:
This example shows how to select tree nodes in the Display and Select TreeNodes page:
In the Display and Select TreeNodes page, highlight the desired tree node, and click the Add Node icon.
If you know the name of the node that you want, enter the name of the node in the Manual Selection list box.
Alternatively, click the Look Up button to select the desired node from a list of available nodes. When you find the node that you’re looking for, click the Add to List button to add it to the list. The nodes that you enter or select from the list appear in the Selected Nodes list box.
Remove nodes from the list by clicking the Remove from List icon corresponding to the node to be deleted.
Display the selected tree branch by clicking the corresponding icon.
When you are done selecting nodes, click OK.
The selected tree setID, tree name, effective date, and nodes appear in the Select Tree Node List page.
Defining a Criteria with Tree Prompt in PeopleSoft Query
In addition to the option of selecting the tree value at design time for a criteria, Tree Prompts option will allow the user an option to select the tree and node value at run time. This allows the user to reuse the same query to get various organizational reports.
Note. In both web-based Query Manager and Windows client [psqed.exe], while creating a query you have the option of selecting to enter the tree details either at the design time or at the runtime. There is a Tree Prompt Option (an expression type) and a Tree Option when you select the condition type as In Tree or Not In Tree. Based on your selection, the tree option is handled to execute the query accordingly in the specified modules.
When you select the Tree Prompt Option as the comparison value, all options to select tree values at design time are not available. However, you are able to select tree values as criteria prompts when you run query.
This is an example of the Edit Criteria Properties with the Tree Prompt Option is selected:
After the Tree Prompt Option is selected:
The Criteria page has a same criteria prompt entry.
The View SQL page displays the viewable SQL for the in tree prompt.
Note. Since tree information at query design time is not known yet, the SQL in the View SQL page is different from the SQL that actually runs in the database. When query is finally executed, based on the user's selection of tree and nodes when prompted, the SQL is modified accordingly with tree info in order to fetch rows of data.
When you access the Run page, you are prompted for selecting the tree for the specified field and its node list.
Based on the tree node list that you selected, and after collecting the other prompt values, if any, the results are displayed on the Run page.
Note. Query that has a criteria with tree prompts cannot be run as part of any process, either via Process Scheduler or from command line. For example, a crystal process which might need a query that has tree prompt to be executed to fetch data is not allowed (either by scheduling a process in Process Scheduler or using psccrun.exe at the command line). Although, you can execute the query with tree prompts from schedule query.
Specifying Effective Date Criteria
Effective-dated tables have record definitions that include the Effective Date (EFFDT) field. This field, used throughout the PeopleSoft applications, provides a historical perspective enabling you to see how the data has changed over time. Whenever users add a row of data to the table, they specify the date on which that data becomes effective; whenever users change a row of data, they specify a new effective date and the system retains the previous version of the row as history.
When you use a PeopleSoft application for day-to-day processing, you usually want the system to give you the currently effective rows of data—the rows where the effective date is less than or equal to today’s date. You do not want to see the history rows, which are no longer accurate, nor do you want to see future-dated rows, which are not yet in effect.
When you query an effective-dated table, however, you may want to see some rows that are not currently in effect. You might want to see all the rows, regardless of their effective dates. Or you might want to see the rows that were effective as of some date in the past.
To specify effective date criteria:
When you choose the record that has EFFDT as a key field, Query Manager automatically creates default criteria and adds that criteria to the Criteria page.
This criteria is used to specify which row of data PeopleSoft Query retrieves for each item in the table. The default is the currently effective row. Defaults are:
Expression 1 |
Record Alias.EFFDT |
EffDt <= |
Expression 2 |
Current Date |
Last |
If you select one of the comparison options, choose to compare each row’s effective date against today’s date or a date other than today.
Select Current Date to compare each row’s effective date against today’s date.
Select Constant to display the Define Constant box so that you can enter a date.
Select this option when you want to see the rows that were effective as of a past date or that will be effective on some future date.
Select Expression to display the Define Expression page so that you can enter a SQL expression that evaluates to a date.
Select this option if you want to prompt users for an effective date when they run the query. You can add a prompt to the expression that you define in the Define Expression page.
Select Field to display the Select Field box so that you can select the record field that holds the date to which you want to compare effective dates.
Select this option when you want to see the rows that were effective at the same time as some other record. For example, if you’re reviewing the list of products on a customer order, you will want to see the products that were effective on the date of the order.
Select First Effective Date to return the row with the oldest effective date, usually the first row that is entered for an item.
Select Last Effective Date to return the row with the latest effective date, even if that date is still in the future.
Removing the Effective Date criterion is equivalent to selecting No Effective Date. The query returns all rows, regardless of their effective dates.
Note. All options (except No Effective Date) return a single row for each item on the table. If you want a subset of the rows (for example, all future-dated rows or all history rows), enter a selection criterion in the Effective Date field. Use the standard comparison operators rather than the Effective Date comparison operators.
Remember that the effective date operators work differently than the standard comparison operators: they always return a single effective-dated row. For example, Eff Date <= returns the one row for which the EFFDT value is most recent, whereas not greater than would return the currently active row and all history rows.
See Also
Relating Multiple Criteria
Using PeopleSoft Query, you can relate multiple criteria in specific ways that you define using the AND, AND NOT, OR, and OR NOT operators. You can also group criteria using parentheses.
Use AND and OR logical operators.
Group criteria with parentheses.
Using AND and OR Logical Operators
When you specify two or more selection criteria for a query, you must tell PeopleSoft Query how to coordinate the different criteria. For example, suppose you are querying your list of customers and you have defined two criteria: one selects customers from the state of Washington and another selects customers who have purchased airplanes. You may want PeopleSoft Query to return only those rows that meet both conditions (customers in Washington who have purchased airplanes), or you may want the rows that meet either one of the conditions (all Washington customers plus all customers who have purchased airplanes).
This diagram illustrates the rows that are returned by AND and OR:
Rows returned by AND and OR
When your query includes multiple criteria, link them using either AND, AND NOT, OR, or OR NOT. When you link two criteria with AND, a row must meet the first and the second criterion for PeopleSoft Query to return it. When you link two criteria with OR, a row must meet the first or the second criterion, but not necessarily both.
By default, PeopleSoft Query assumes that you want rows that meet all of the criteria that you specify. When you add a new criterion, PeopleSoft Query displays AND in the Logical column on the Criteria tab. To link the criterion using one of the other options instead, select the required option from the drop-down list box.
Grouping Criteria with Parentheses
When your query includes multiple criteria, PeopleSoft Query checks the criteria according to the rules of logic: it evaluates criteria that are linked by ANDs before those that are linked by ORs. When all the criteria are linked by ANDs, this order always returns the correct results. When you include one or more ORs, however, this is not always what you want.
For example, suppose you want a list of customers who are not friends and reside in either California (CA) or Florida (FL), you would enter the following criteria:
The set of criteria that was entered in the previous sample page returns a list of customers in California (except for those who are friends) and all customers in Florida (including those who are friends). This list results because PeopleSoft Query evaluates criteria in the order of appearance. It looks for rows where the customer is not friend and where the state is California or rows where the state is Florida.
What you really want PeopleSoft Query to search for are rows where the state is California or Florida, and where the customer type is not friend. That is, you want PeopleSoft Query to evaluate the OR before the AND. To accomplish this task, add parentheses to the list of criteria. When a list of criteria includes parentheses, PeopleSoft Query evaluates the criteria inside the parentheses before the criteria outside the parentheses.
Using the Group Criteria button on the Criteria page to access the Edit Criteria Grouping page where you can insert the opening parenthesis just before the field name and the closing parenthesis just after the comparison value. For example, the following settings of criteria return the results that you want:
To group criteria:
Click the Group Criteria button on the Criteria tab.
The Edit Criteria Grouping page appears.
Use the edit boxes to enter parentheses for the criteria as needed.
A parenthesis appears at the beginning of the Expression1 column for the first row that you selected and at the end of the Expression2 column for the last row that you selected. In the previous example, notice that the AND operator precedes the parentheses, while the OR operator is located within the parentheses.
You can add as many parentheses as needed.
Defining Prompts
This section provides an overview of prompts and discusses how to edit prompt properties.
Understanding Prompts
Adding a prompt lets you further refine a query when you run it. For example, suppose that you want to change a query so that you could prompt the user to enter a value for the duration of a vacation. Before you add the prompt, the query always retrieves rows for employees who had taken vacation based on a defined constant value on which to make a comparison. Adding a prompt to the query enables the user to enter any duration, and then the query can return employees based on the value provided when running the query.
When you run a query with a prompt, a prompt page requests the required value. All date, time, and datetime prompt fields are required fields when running Query. Enter the value into the field. The query uses the value that you enter as the comparison value for the criterion that included the prompt.
If the field for which you are prompting has an associated prompt table (even if it is the Translate table), the Edit Table drop-down list box shows its name.
Pages Used to Define Prompts|
Page Name |
Definition Name |
Navigation |
Usage |
Prompts |
QRY_PROMPT |
Reporting Tools, Query, Query Manager, Prompts |
Add or edit a prompt. |
Edit Prompt Properties |
QRY_PROMPT_SEC |
Reporting Tools, Query, Query Manager, Prompts Click the Add Prompt button or the Edit button on the Prompts page. |
Edit the prompt properties. |
Viewing and Editing PromptsAccess the Prompts page by selecting Reporting Tools, Query, Query Manager, Prompts.
This is an example of the Prompts page:
Editing Prompt PropertiesUse these steps to access the Edit Prompt Properties page:
Add a new query or search for an existing one.
Access the Prompts page.
The Edit Prompt Properties page appears.
This is an example of the Edit Prompt Properties page:
To define prompts:
From the Prompts page, click the Add Prompt button to add a new prompt, or click the appropriate Edit button to edit an existing prompt.
Click the Look Up button next to the Field Name field to select a prompt field.
After you select a prompt field, the name of the field appears. PeopleSoft Query looks to the record definition for information about this field and completes the rest of the page based on its properties.
Note. When using a prompt table on a field from a record definition with multiple keys, you must prompt for all higher-level keys before lower-level keys. PeopleSoft Query needs values for the higher-level keys to generate the correct prompt list. Because of this complication, you should not use multikey prompt tables.
See Also
Adding Fields to Query Content
Defining HAVING Criteria
SQL does not support the use of aggregate functions in WHERE clauses. Therefore, after you have applied an aggregate function to a field, you cannot use that field in your selection criteria, which corresponds to a SQL WHERE clause. When you want to select rows based on the results of an aggregate function, Query Manager enables you to create HAVING criteria. You might use such criteria, for example, when you want a list of the departments whose minimum salary is greater than 100,000.00 USD.
In SQL, a HAVING clause is similar to a WHERE clause for rows of data that have been aggregated into a single row of output. The system evaluates WHERE clauses by looking at the individual table rows before they are grouped by the aggregate function, and then it evaluates HAVING clauses after applying the function. So if you want to check the value that is returned by the function, you must define a HAVING criterion.
When you click the Add Criteria icon from the Fields or Query pages for an aggregate field, new criteria is added to the Having page instead of the Criteria page. Add selection criteria using the Having page in the same way that you add selection criteria using the Criteria page.
Keep in mind that PeopleSoft Query compares the result of applying the aggregate function to the comparison value.
Pages Used to Define HAVING Criteria|
Page Name |
Definition Name |
Navigation |
Usage |
Having |
QRY_HAVING |
Reporting Tools, Query, Query Manager, Having |
Add or edit a having criteria. |
Edit Having Criteria Properties |
QRY_CRITERIA_SEC |
Reporting Tools, Query, Query Manager, Having Click the Add Having Criteria button or the Edit button on the Having page. |
Edit the having criteria properties. |
Viewing and Editing Having CriteriaAccess the Having page by selecting Reporting Tools, Query, Query Manager, Having.
This is an example of the Having page:
Editing Having Criteria Properties Use these steps to access the Edit Prompt Properties page:
Access the Having page.
The Edit Having Criteria Properties page appears.
This is an example of the Edit Having Criteria Properties page:
Defining Expressions
This section provides an overview of expressions and discusses how edit expression properties.
Understanding Expressions
Expressions are calculations that PeopleSoft Query performs as part of a query. Use them when you must calculate a value that PeopleSoft Query does not provide by default—for example, to add the values from two fields together or to multiply a field value by a constant.
You can work with an expression as if it were a field in the query: select it for output, change its column heading, or choose it as an “order by” column.
In Query Manager, you can use expressions in two ways:
As comparison values in selection criteria.
As columns in the query output.
Pages Used to Define Expressions|
Page Name |
Definition Name |
Navigation |
Usage |
Expressions |
QRY_EXPRESSIONS |
Reporting Tools, Query, Query Manager, Expressions |
Add or edit an expression. |
Edit Expression Properties |
QRY_EXPR_SEC |
Reporting Tools, Query, Query Manager, Expressions Click the Add Expression button or the Edit button on the Expressions page. |
Edit the expression properties. |
Viewing and Editing ExpressionsAccess the Expressions page by selecting Reporting Tools, Query, Query Manager, Expressions.
This is an example of the Expressions page:
Editing Expression Properties
Use these steps to access the Edit Expression Properties page:
Access the Expressions page.
Click the Add Expression button or the Edit button.
The Edit Expression Properties page appears.
This is an example of the Edit Expression Properties page:
To add or edit expressions for queries:
Select Reporting Tools, Query, Query Manager, then click the Create New Query link, and then select the Expressions tab to open the Expressions page.
The query name appears in the Query Name field.
The default for this field is New Unsaved Query until you change it on the Properties page.
Click the Add Expression button to open the Edit Expression Properties page, where you can select expression types.
Select an option from the Expression Type drop-down list box.
If you select Character, enter the maximum length of the expression result in the Length field.
If you select Number or Signed Number, enter the total number of digits in the Length field and the number of digits after the decimal point in the Decimal field.
Note. For Number and Signed Number, expression types, the Length field defines the total length of the number (integer portion + decimals portion). For example, if Length = 10 and Decimals = 3, then this means that the integer portion = 7 (Length - Decimals = Integer).
If you are entering an aggregate value, such as SUM, AVG, or COUNT, select the Aggregate Expression check box.
In the Expression Text field, enter the expression (for example, A. Total * .1, where A represents the first record.)
Query Manager inserts the expression into the SQL for you. You can include Oracle hints in PeopleSoft Query expressions as long as you adhere to the following rules:
Expressions containing a hint must begin with /*+ .
Expressions can contain only one hint.
For example, only one set of /*+ */ is allowed.
Expressions must contain a complete hint.
For example, an expression can't have only /*+ or */ . Both must be in the same expression.
Click the Add Prompt button to add prompt properties for this expression; click the Add Field button to add another field to this expression.
Note. You must define a prompt, as described in the next section, before you can add it to your expression.
MetaSQL enables you to enter an expression that can be used across any supported database. For example, to concatenate strings, use the MetaSQL %CONCAT, and Oracle's PeopleTools will convert it to the appropriate database string concatenation function. To create a substring, use %SUBSTRING.
Note. You need to make sure that the expression type and length are set correctly for the data that is going to be returned. Only the MetaSQL functions that are valid for dynamic views will work with PeopleSoft Query.
See Also
Drilling URL in PeopleSoft Query
This section provides an overview of drilling URL in PeopleSoft Query, lists common terminology used in this section, and discusses how to:
View and edit expression properties.
Define Query URL widgets.
Define Component URL widgets.
Define External URL widgets.
Define Attachment URL Widgets.
Define Free Form URL widgets.
View query results with drilling URLs.
Schedule queries with drilling URLs.
Understanding Drilling URLs
Drilling URLs are the URLs that you define by selecting the menu, component, page, portal object, or URL of choice.
When you build a query using Query Manager, you can define drilling URLs that are associated with this query. These settings are saved into the database, along with prompt, criteria, and so on, as part of the metadata for this query. When you execute this query through Query Manager or Query Viewer, the query results page shows results as links, which you can click to be redirected to a different page in a new browser. Depending on how drilling URLs are defined, the new browser is either a PeopleSoft Pure Internet Architecture page, another query result page, or an external page.
Note. Drilling URLs that were created in earlier PeopleTools releases will work properly in PeopleTools 8.52.
Common Terminology Used in This Section|
Source Query |
A query that defines a Drilling URL. |
Destination Query |
A query that was defined as a Drilling URL. |
Destination Component |
A component that was defined as a Drilling URL. |
Pages Used to Define Drilling URLs|
Page Name |
Definition Name |
Navigation |
Usage |
QRY_QRYURL_SELECT |
Reporting Tools, Query, Query Manager Click the Create New Query link on the Query Manager search page, or click the Search button and open an existing one. If you create a new query, click the Search button and click the Add Record link to select a record for the query. Select the Expressions tab, and click the Add Expression button. |
Edit expression properties for your query statement. |
Select a Query |
QRY_FIELDS |
Reporting Tools, Query, Query Manager Click the Create New Query link on the Query Manager search page, or click the Search button and open an existing one. If you create a new query, click the Search button and click the Add Record link to select a record for the query. Select the Expressions tab, and click the Add Expression button. Select the Drilling URL option from the Expression Type list, and click the Query URL link. |
Select a query to build drilling URLs in a query URL format. |
Query Search Page |
QUERY_URL_SRCH_SPG |
Reporting Tools, Query, Query Manager Click the Create New Query link on the Query Manager search page, or click the Search button and open an existing one. If you create a new query, click the Search button and click the Add Record link to select a record for the query. Select the Expressions tab, and click the Add Expression button. Select the Drilling URL option from the Expression Type list, and click the Query URL link. Click the Prompt Key button next to the Query Name field. |
Searching for a prompt criteria of the query to build URLs. |
Select a Component |
QRY_COMPURL_SELECT |
Reporting Tools, Query, Query Manager Click the Create New Query link on the Query Manager search page, or click the Search button and open an existing one. If you create a new query, click the Search button and click the Add Record link to select a record for the query. Select the Expressions tab, and click the Add Expression button. Select the Drilling URL option from the Expression Type list, and click the Component URL link. |
Select a component to build drilling URLs in a component URL format. |
Select a Content Reference or Content Reference Link |
QRY_CREFURL_SELECT |
Select a content reference or content reference link. |
Enter an External URL |
QRY_URL_SELECT |
Reporting Tools, Query, Query Manager Click the Create New Query link on the Query Manager search page, or click the Search button and open an existing one. If you create a new query, click the Search button and click the Add Record link to select a record for the query. Select the Expressions tab, and click the Add Expression button. Select the Drilling URL option from the Expression Type list, and click the External URL link. |
Enter an external URL to build drilling URLs in external URL format. |
Enter an Attachment URL |
QRY_ATTURL_SELECT |
Reporting Tools, Query, Query Manager Click the Create New Query link on the Query Manager search page, or click the Search button and open an existing one. If you create a new query, click the Search button and click the Add Record link to select a record for the query. Select the Expressions tab, and click the Add Expression button. Select the Drilling URL option from the Expression Type list, and click the Attachment URL link. |
Enter an attachment URL to build drilling URLs in attachment URL format. |
Define a Free Form URL |
QRY_FREEURL_SELECT |
Reporting Tools, Query, Query Manager Click the Create New Query link on the Query Manager search page, or click the Search button and open an existing one. If you create a new query, click the Search button and click the Add Record link to select a record for the query. Select the Expressions tab, and click the Add Expression button. Select the Drilling URL option from the Expression Type list, and click the Free Form URL link. |
Manually enter URLs that will be used to build drilling URLs in report results. |
Viewing and Editing Expression Properties
Drilling URLs are a special type of expression that you can define using the Edit Expression Properties page in Query Manager.
To access the Edit Expression Properties page:
Expression type |
To define drilling URLs, you must select the Drilling URL option from the Expression type list. |
Expression text |
Optionally, type the URL in the Expression text text box. Note. You have two options: type the URL in this Expression Text box or click the Query URL, Component URL, or External URL links to allow the appropriate system building URLs. If you type the URL directly into the Expression text box, the system does not validate against a value for the correct format. |
Query URL |
Click to access the Query URL definition widget, where you can select a query to build URLs in a query URL format. |
Component URL |
Click to access the Component URL definition widget, where you can select a component to build URLs in a component URL format. |
External URL |
Click to access the External URL definition widget, where you can enter external URL to build URLs in an external URL format. |
Attachment URL |
Click to access the Attachment URL definition widget, where you can enter attachment URL to build URLs in an attachment URL format. |
Free Form URL |
Click to access the Free Form URL definition widget, where you can manually enter URLs that will be used to build drilling URLs in report results. |
Note. Drilling URLs are saved into database as an expression, so you can access the Expressions page and add the defined drilling URLs as fields. However, you cannot add drilling URLs as criteria because drilling URLs are special type of expressions. You can add drilling URLs as query fields or columns, and then on the query results page, values in that fields or columns will be expanded to fully qualified URLs, which you can click to either run query, access a PeopleSoft Pure Internet Architecture page, or access an external URL.
See Defining Expressions.
Defining Query URL Widgets
The Query URL widget enables you to use the Select a Query page to build drilling URLs in a query URL format. You can click the Query URL link in the Edit Expression Properties page to access the Select a Query page.
To access the Select a Query page:
Select the Expressions tab and click the Add Expression button.
Select the Drilling URL option from the Expression Type list.
The Select a Query page appears.
This is an example of the Select a Query page:
Portal Name |
Optionally, enter or select a portal that is used to build drilling URLs at the report runtime. Note. If the Portal Name field has no value, PeopleSoft Query uses value %PORTAL to form a drilling URL at the report runtime. |
Node Name |
Optionally, enter or select a node that is used to build drilling URLs at the report runtime. If the Node Name field has no value, PeopleSoft Query uses value %NODE to form a drilling URL at the report runtime. |
Used to define the content type that is used to build drilling URLs.
Query Name |
Type a query name in the text box or click the query lookup icon to search for an existing query. |
Used to select the format of report results that will be generated from the drilling URLs. Available options are:
Prompt Keys |
Click to access the Query Search Page where you can search for the prompt criteria of the query that you entered in the Query Name field. If the entered query has prompt criteria, a list of those fields appears in the URL Keys section. If the entered query has no prompt criteria, a message appears saying “Query does not contain any prompt key(s)”. Note. This step is optional. If you do not map any prompt keys to the source query column field, then when you click a drilling URL link in query result column page, you will be directed to the Prompt page, where you can enter prompt key values before retrieving query result. |
Select Field |
Click to access the Select Query Column section. |
Click to display the Map URL to Query Columns section.
Note. This step is required for the drilling URLs to be
available in a query results page. |
The URL Keys section is available only after you define the Query field and click the Prompt Keys button. In this URL Keys section, you define value mapping between Drilling URL destination query prompt fields and Drilling URL source query result column fields. To map these fields, select the key field by selecting the check box adjacent to a prompt key field, and then click the lookup icon to select the source query column field to map to it. Note. This step is optional. If you do not map any prompt keys to a source query column field, then when you click a drilling URL link on the query result column page, you will be directed to the Prompt page, where you can enter prompt key values before you retrieve query results. |
Select Query Column |
Select query result columns to form field name and value pairs and to define the order of the appended value pair in the URL. Note. The Select Query Column section is available after you click the Select Field button. |
Map URL to Query Columns |
The Map URL to Query Columns section is available only after you define the component values and click the Map Columns button.
available in the query results page. |
OK |
Click to finish defining the Query URL widget and return to the Edit Expression Properties page. |
Access the Query Search page (from the Select a Query page, click the Prompt Keys button).
Use this page to search for the prompt criteria of the query that you entered in the Query Name field of the Select a Query page. If the entered query has prompt criteria, a list of those fields appears in the URL Keys section. If the entered query has no prompt criteria, a message appears saying “Query does not contain any prompt key(s)”.
Selecting Query Columns for Existing Drilling URLs
Using the Select Query Column section, you can append field name and value pairs to the end of existing Drilling URL types. The format of the appended field name and value pair is &FIELDNAME=VALUE.
For example:
'/c/QE_SAMPLE_APPS.QE_DEPT_TBL.GBL?Action=U&DEPTID=%A.DEPTID%&SETID= %A.SETID%EMPLID=00001:A.SETID'
In this example, the appended field name and value is formed using a static field name, EMPLID, and the static value 00001. At runtime, the drilling URL is expanded as:
http://rtdc79579vmc:8080/psp/ps/EMPLOYEE/QE_LOCAL/c/QE_SAMPLE_APPS.QE_DEPT_TBL.GBL? Action=U&DEPTID=10300&SETID=QEDMOEMPLID=00001
'/c/QE_SAMPLE_APPS.QE_DEPT_TBL.GBL?Action=U&DEPTID=%A.DEPTID%&SETID= %A.SETID%&A.SETID=%A.SETID%&A.DEPTID=%A.DEPTID%:A.SETID'
In this example, the appended field name and value pairs are from two query result columns, A.SETID and A.DEPTID. At runtime, the actual values that are returned in the query results for the A.SETID and A.DEPTID columns replace the %A.SETID% and %A.DEPTID%, as in this URL:
http://rtdc79579vmc:8080/psp/ps/EMPLOYEE/QE_LOCAL/c/QE_SAMPLE_APPS.QE_DEPT_TBL.GBL?Action=U&DEPTID=10300&SETID=QEDMO&A.SETID=QEDMO&A.DEPTID=10300
Note. The Expression Text field in the Edit Expression Properties page is not editable. You can modify existing drilling URLs or define new drilling URLs using available drilling URL widgets.
Processing Existing Drilling URLs at Runtime
At runtime, the query drilling URL feature is able to process all drilling URLs that are created in PeopleTools releases later than 8.50. For example, when you define the same drilling URL:
PeopleTools 8.50 forms the drilling URL as
'/q/?ICAction=ICQryNameURL=PUBLIC.QE_EMP_DESTINATION&BIND1=A.DEPTID:A.DEPTID' '/c/QE_SAMPLE_APPS.QE_DEPT_TBL.GBL?Action=U&DEPTID=A.DEPTID&SETID=A.SETID:A.SETID'
PeopleTools 8.51 forms the drilling URL as
'/q/?ICAction=ICQryNameURL=PUBLIC.QE_EMP_DESTINATION&BIND1=%A.DEPTID%:A.DEPTID' '/c/QE_SAMPLE_APPS.QE_DEPT_TBL.GBL?Action=U&DEPTID=%A.DEPTID%&SETID=%A.SETID%: A.SETID'
PeopleTools 8.52 forms the drilling URL as
'psp/EMPLOYEE/QE_LOCAL/q/?ICAction=ICQryNameURL=PUBLIC.QE_EMP_DESTINATION&BIND1= %A.DEPTID%: A.DEPTID' 'psp/EMPLOYEE/QE_LOCAL/c/QE_SAMPLE_APPS.QE_DEPT_TBL.GBL?Action=U&DEPTID= %A.DEPTID%&SETID=%A.SETID%:A.SETID’
Note. Oracle PeopleSoft introduced query drilling URL in
PeopleTools 8.50 and added more features in later releases, so drilling URLs
created in different releases will look slightly different. However, runtime
processing is backward compatible and drilling URLs that have been defined
in previous release will be expanded correctly in newer release without the
user's need to redefine them.
In PeopleTools 8.50, drilling URLs must be expanded correctly. When
you modify a drilling URL that was created in PeopleTools 8.51 or later and
then save it in PeopleTools 8.50, the system uses new format and syntax to
form the URL. In PeopleTools 8.51 or later, when you run a query with the
drilling URLs that were directly upgraded from PeopleTools 8.50, the runtime
converts the format differences between the different releases.
Steps Used to Select a Query to Build Drilling URLs
To select a query to build drilling URLs:
The Query Manager search page appears.
Click the Create New Query link on the Query Manager search page to create a source query, or click the Search button and open an existing one.
If you create a new source query, click the Search button and click the Add Record link to select a record for the query.
The Fields page appears.
Click the Query URL link to define drilling URL for the source query that you just created.
Optionally, define the portal name, node name, or content type.
Type a query name in the Query Name text box, or click the lookup icon to search for one from existing queries.
Select the format of report results that will be generated from the drilling URLs.
Optionally, define value mapping in the URL Keys section.
Click the Prompt Keys button to bind the prompt keys of the destination query with the columns of the source query.
Note. If the destination query has prompt criteria, the URL Keys section appears with a list of key fields.
Define value mapping in the URL Keys section by selecting the check box adjacent to a prompt key field, and then clicking the lookup icon to select a source query column field to map to it.
Optionally, define query result columns for existing drilling URLs:
Click the Select Field button to display the Select Query Column section.
Select query result columns to form fieldname and value pairs and to define the order of the appended value pair in the URL.
Optionally, define the column mapping in the Map URL to Query Columns section:
Click the Map Columns button to map the drilling URL to a source query selected column.
Select appropriate values from the Map URL to Query Columns section.
The Edit Expression Properties reappears with query drilling URLs in the Expression Text field.
This is an example of a drilling URL with the Use psc option is not selected, and the Portal Name and Node Name fields have no values. Notice that, %PORTAL and %NODE values will be used to build URLs at the report runtime:
'psp///q/?ICAction=ICQryNameURL=PUBLIC.DESTINATION&BIND1=A.DEPTID:A.DEPTID'
In this example, 'psc// is your selected portal name, node name, and content type; the standard query URL format is /q/?ICAction=ICQryNameURL=PUBLIC.DESTINATION&BIND1=A.DEPTID, and the binding column is A.DEPTID. Thus, this drilling URL is binding with column A.DEPTID.
This is an example of a drilling URL with the Use psc option is selected, portal CUSTOMER, and node QE_LOCAL:
'psc/EMPLOYEE/QE_LOCAL/q/?ICAction=ICQryNameURL=PUBLIC.QE_EMP_DESTINATION:A.QE_ EMPLOYEE_NAME'
In this example, 'psc/EMPLOYEE/QE_LOCAL is your selected portal name, node name, and content type.
Note that, a query drilling URL:
Always includes /q/.
Is saved as part of expression metadata for the query.
Contains two parts: query URL format and query result columns binding with the Drilling URL.
Save your query.
Alternatively, select Reporting Tools, Query, Query Viewer.
Click the HTML link or the Download to Excel link.
The query results page displays results as links. When you click these links, the destination query is run using prompt key values that are defined using the source query.
Defining Component URL Widgets
The Component URL widget enables you to use the Select a Component page to build drilling URLs in component URL format. When you click the Component URL link in the Edit Expression Properties page to access the Select a Component page, a PeopleSoft Pure Internet Architecture page is launched.
Note. The Component URL widget is only used for pages that have the Action field set to Update/Display.
To access the Select a Component page:
Select the Expressions tab.
Click the Add Expression button.
The Select a Component page appears.
This is an example of the Select a Component page:
Portal Name |
Optionally, enter or select a portal that is used to build drilling URLs at the report runtime. Note. If the Portal Name field has no value, PeopleSoft Query uses the value %PORTAL to form a drilling URL at the report runtime. |
Node Name |
Optionally, enter or select a node that is used to build drilling URLs at the report runtime. If the Node Name field has no value, PeopleSoft Query uses the value %NODE to form a drilling URL at the report runtime. |
Use psc (content servlet) |
Content Reference |
Enter the name of a content reference or use the Add Content Reference Link link to select a content reference from an existing list. |
Add Content Reference Link |
Click to access the Select a Content Reference or Content Reference Link page, where you can select a content reference or content reference link. Note. The values of the Menu Name, Market, and Component fields are populated if you select a content reference or content reference link using the Add Content Reference Link link. |
Menu Name |
Enter a menu name or click the lookup icon and select one menu name from an existing list. Otherwise, the menu name value is populated if you select a content reference or content reference link using the Add Content Reference Link link. |
Market |
Enter a market code or click the lookup icon and select one market code from an existing list. The market code is populated automatically if you select a content reference or content reference link using the Add Content Reference Link link. |
Component |
Enter a component name or click the lookup icon and select one component name from an existing list. Otherwise, the component name value is populated if you select a content reference or content reference link using the Add Content Reference Link link. |
Search Keys |
Click to select mapping between component search keys and source query result columns. If the entered component has a search key, a list of those search keys appears in the URL Keys section. If the entered component has no search key, a message appears saying “Component does not contain any search keys”. Note. This step is optional. If you do not map any search keys to the source component, then when you click a drilling URL link in the query result column page, you will be directed to a component search page, where you can select search key values. |
Select Field |
Click to display the Select Query Column section. |
Map Columns |
available in query results page. |
URL Keys |
The URL Keys section is available only after you define the component and click the Search Keys button. In this URL Keys section, you define value mapping between Drilling URL destination component search keys and Drilling URL source query result column fields. To map these fields, you can either select the key field and then click the lookup icon to select source query column field to map to it, or enter static values as mapping value directly into the Field Value field. Similarly, in the Key Value field, you can either manually enter the key name or search for existing keys from the component. You can also add or delete key values using the Add or Delete button. Note. This step is optional. If you do not map any search keys to the source component, then when you click a drilling URL link in query result column page, you will be directed to a component search page, where you can enter search key values before you launch the component. |
Select query result columns to form fieldname and value pairs and to define the order of the appended value pair in the URL. |
OK |
Click to finish defining a Component URL widget and return to the Edit Expression Properties page. |
Selecting a Content Reference or Content Reference Link
Access the Select a Content Reference or Content Reference Link page (from the Select a Component page, click the Add Content Reference Link link).
Use this page to select a content reference or content reference link.
Steps Used to Select a Component to Build Drilling URLs
To select a component to build drilling URLs:
Click the Component URL link to define a drilling URL for the source query that you just created.
Type a content reference in the text box or click the Add Content Reference Link link to select one from existing components.
If needed, define the values for the Menu Name, Market, and Component fields.
In the Field Value and Key Name fields, either use the lookup icon to select a source query column field to map to it, or enter static values as mapping value directly into the fields.
Note. If the selected component has a search key, the URL Keys section appears with a list of search key fields after you click the lookup icon.
Optionally, define the map columns in the Map URL to Query Columns section.
The Edit Expression Properties page appears with a component drilling URL in the Expression Text field.
This is an example of a component drilling URL with the Use psc option is not selected, and the Portal Name and Node Name fields have no values. Notice that, %PORTAL and %NODE values will be used to build URLs at the report runtime:
'psp///c/QE_SAMPLE_APPS.QE_DEPT_TBL.GBL?Action=U&DEPTID=%A.DEPTID%&SETID =PLEASANTON:A.EMPLID'
This is an example of a component drilling URL with the Use psc option is selected, portal CUSTOMER, and node QE_LOCAL:
'psc/CUSTOMER/QE_LOCAL/c/QE_SAMPLE_APPS.QE_DEPT_TBL.GBL?Action=U&DEPTID= %A.DEPTID%&CITY=PLEASANTON:A.EMPLID'
In this example, 'psc/CUSTOMER/QE_LOCAL is your selected portal name, node name, and content type; &DEPTID=%A.DEPTID is your static value as key value; and &CITY=PLEASANTON is your entered key name and key value.
Note that, a component drilling URL:
Always includes /c/.
Contains two parts: component URL format and query result columns binding with the drilling URL.
Save your query.
The query results page displays results as links. When you click these links, destination query is run using the prompt key value that is defined using the source query.
Defining External URL Widgets
The External URL widget enables you to use the Enter an External URL page to build drilling URLs in an external URL format; when you click the External URL link in the Edit Expression Properties page to access the Enter an External URL page, you are directed to an external page.
To access the Enter an External URL page:
The Enter an External URL page appears.
This is an example of the Enter an External URL page:
Note. Query URL and component URL have a certain format for key list values in the URL. However, external URL has no key mapping widget because external URL is free-format URL.
Portal Name |
Node Name |
URL |
Enter the value of the external URL. Note. There is no format restriction. |
Select Field |
Map Columns |
After you enter URL value, click this button to display the Map URL to Query Columns section.
OK |
Click to complete defining External URL widget and return to the Edit Expression Properties page. |
Steps Used to Enter External URLs to Build Drilling URLs
To enter an external URL to build drilling URLs:
Select Reporting Tools, Query, Query Manager.
Click the External URL link to define drilling URL for the source query that you just created.
Type a valid URL in the External URL edit box.
Optionally, define the column mapping in the Map URL to Query Columns section.
Click the Map Columns button to map the drilling URL to source query selected column.
This is an example of an external drilling URL with the Use psc option is not selected, and the Portal Name and Node Name fields have no values. Notice that, %PORTAL and %NODE values will be used to build URLs at the report runtime: 'psp///e/?url=[http://www.yahoo.com]:A.DEPTID'.
This is an example of an external drilling URL with the Use psc option is selected, portal EMPLOYEE, and node QE_LOCAL: 'psp/EMPLOYEE/QE_LOCAL/e/?url=[http://www.yahoo.com]:A.DEPTID'. In this example, 'psc/EMPLOYEE/QE_LOCAL is your selected portal name, node name, and content type
Note. An external drilling URL always includes /e/.
Save your query.
The query results page displays results as links. When you click these links, destination query is run using prompt key value that is defined using the source query.
Defining Attachment URL Widgets
The Attachment URL widget enables you to use the Enter an Attachment URL page to build drilling URLs in an attachment URL format.
Note. Currently, PeopleTools supports attachment drilling URLs for SES (Security Enterprise Search). If you use SEC and belong to theHTTP File View role, you can view the attachment URL file. Otherwise, a message appears that says you are not authorized for viewing attachments from database using HTTP.
To access the Enter an Attachment URL page:
The Enter an Attachment URL page appears.
This is an example of the Enter an Attachment URL page:
URL Type |
Available options are Internal URL and External URL. |
Portal Name |
If the attachment URL is internal, optionally enter or select a portal that is used to build drilling URLs at the report runtime. Note. If the Portal Name field has no value, PeopleSoft Query uses the value %PORTAL to form a drilling URL at the report runtime. |
Node Name |
If the attachment URL is internal, optionally enter or select a node that is used to build drilling URLs at the report runtime. If the Node Name field has no value, PeopleSoft Query uses the value %NODE to form a drilling URL at the report runtime. |
If the attachment URL is internal, define the content type that is used to build drilling URLs.
URL ID |
Select a query field that will be used for attachment file name. Note. The URL IDs are set in this folder: PeopleTools\Utilities\Administration\URLs. |
Select Field |
Map Columns |
Select query result columns to form field name and value pairs and to define the order of the appended value pair in the URL. |
This section is available only after you define the component values and click the Map Columns button.
OK |
Steps Used to Enter Attachment URLs to Build Drilling URLs
To enter an attachment URL to build drilling URLs:
Click the Attachment URL link to define drilling URL for the source query that you just created.
Select an URL type.
Note. The Portal Name field, Node Name field, and Use psc option are not active if the URL type is set to External URL.
If the attachment URL is internal, optionally define the portal name, node name, or content type for internal URL.
Select an URL ID and a file name field.
If URL type is external, its attachment drilling URL always begins with '%URLID:. For example: '%URLID:FILEDB%%A.SETID%:A.EFFDT'.
At runtime, this external URL is expanded to record://PSFILE_ATTDET1.
Notice that drilling URL runtime replaces %A.SETID% with actual query field column value of 1. Drilling URL runtime also replace FILEDB with record://PSFILE_ATTDET. FILEDB is defined as record://PSFILE_ATTDET in the URL page that can be set using this navigation path: PeopleTools, Utilities, Administration, URLs.
If URL type is internal, its attachment drilling URL always includes '/s/. For example: 'psc/EMPLOYEE/QE_LOCAL/s/WEBLIB_FILEHTTP.ISCRIPT1.FieldFormula.IScript_GetAttachment?urlid=FILEDB&filename=%A.SETID%:A.QE_JOBCODE'.
At runtime, this internal URL is expanded to:
http://buffy.us.oracle.com:8920/psc/QEDMO/EMPLOYEE/QE_LOCAL/s/WEBLIB_FILEHTTP.ISCRIPT1.FieldFormula.IScript_GetAttachment?urlid=FILEDB&filename=%25A.SETID%25
Notice that drilling URL runtime replaces %A.SETID% with actual query field column value 25.
Save your query.
Defining Free Form URL Widgets
The Free Form URL widget enables you to use the Define a Free Form Drilling URL page to build drilling URLs using the values that you manually enter into the URL field.
To access the Define a Free Form Drilling URL page:
The Define a Free Form Drilling URL page appears.
This is an example of the Define a Free Form Drilling URL page:
You can define free-form drilling URLs using the following elements:
Static text; for example, http://www.yahoo.com.
Query result columns; for example, %A.EMPLID%, %B.DEPID%.
Portal system variable.
Note. Application engine program may not recognize portal
system variable if query API is called from an undetermined context.
Portal system variables is case-sensitive.
This table lists the portal system variables that PeopleSoft Query supports:
%AuthenticationToken |
%ClientDate |
%ClientTimeZone |
%ContentID |
%ContentType |
%Copyright |
%Currency |
%Date |
%DateTime |
%DbName |
%DbServerName |
%DbType |
%EmailAddress |
%EmployeeId |
%HPTabName |
%IsMultiLanguageEnabled |
%Language |
%Language_Base |
%LocalNode |
%Market |
%MaxMessageSize |
%NavigatorHomePermissionList |
%Node |
%PasswordExpired |
%Portal |
%PrimaryPermissionList |
%ProcessProfilePermissionList |
%RowSecurityPermissionList |
%RunningInPortal |
%ServerTimeZone |
%Time |
%UserDescription |
%UserId |
Note. Unlike other type of drilling URLs, PeopleSoft Query uses portal service (psp) to construct free-form drilling URLs during the report runtime. PeopleSoft recommends you to include the portal name and the node name as part of the URL. At the report runtime, query processing manager (QPM) uses current running context to determine protocol, host, and port, and then concatenates those values with drilling URL itself to form a full URL.
Viewing Query Results with Drilling URLs
When you access the Run page of a query that has a Drilling URL defined, its query results are shown as links. Clicking these result links either:
Runs the destination query with prompt key values if the source query has prompt criteria defined and prompt keys are mapped to source query result columns.
Launches the component with the search key values if the source query has search keys defined and search keys are mapped to source query result columns.
Redirects the external URL.
This is an example of the Run page with query results as links:
On the Run page, when you click the Download to Excel link to download query results to a Microsoft Excel spreadsheet, an Excel spreadsheet is launched with links to respective cells. When you click the Excel link from Query Manager or the Query Viewer search results page, you get similar query results.
This is an example of query results in Microsoft Excel when you click the Excel link in Query Manager or Query Viewer. Note that the URL appears when you hover the mouse over a cell:
You can also view the query results of a query that has drilling URL defined using the HTML links in Query Manager or Query Viewer.
This is an example of query results as links when you click the HTML links in Query Manager or Query Viewer:
In this query result page:
You can click the Excel Spreadsheet link to download query results to Microsoft Excel.
Note. The Excel Spreadsheet link in this query result page has the same usage as the Excel link in Query Manager or the Query Viewer search result page.
You can click the CSV Text File link to download query results into a CSV format file.
Note. Because CSV file is opened using a text editor such as Notepad and links do not apply to text editors, unlike HTML and Excel, no links exist in the CSV format file. However, if you select drilling URL as query selected field, then the drilling URL appears in a fully expanded version.
This is an example of CSV file content:
"QEDM1","10900","10900","http://buffy-lap1.peoplesoft.com:8080/psp/ps_2/EMPLOYEE /QE_LOCAL/c/QE_SAMPLE_APPS.QE_DEPT_TBL.GBL?Action=U&DEPTID=10900&SETID=QEDM1"
Scheduling Queries with Drilling URLs
The Schedule Query page has five different output types: HTM, PDF, TXT, XLS, and XML. Result files from a successful schedule query run contain links for respective columns using HTM, PDF, and XLS formats.
This is an example of query results in PDF format. Note that the URL appears when you hover the mouse over a cell:
If drilling URL is defined in the query, then no links exist in the result file for TXT and XML formats. However, if you select drilling URLs as a query selected field, drilling URLs are shown in a fully expanded version.
This is an example of TXT file content:
Note. Theoretically, one query can have multiple drilling URLs defined; however, the number of URLs for each query should be limited to enhance performance. For queries that return a large number of results, having multiple URLs defined would slow query execution time.
