Skip Navigation Links | |
Exit Print View | |
Oracle Solaris Cluster Software Installation Guide Oracle Solaris Cluster 4.1 |
1. Planning the Oracle Solaris Cluster Configuration
2. Installing Software on Global-Cluster Nodes
3. Establishing the Global Cluster
4. Configuring Solaris Volume Manager Software
Creating Disk Sets in a Cluster
How to Add Drives to a Disk Set
How to Repartition Drives in a Disk Set
Configuring Dual-String Mediators
Requirements for Dual-String Mediators
How to Check For and Fix Bad Mediator Data
5. Creating a Cluster File System
The following table lists the tasks that you perform to configure Solaris Volume Manager software for Oracle Solaris Cluster configurations. Complete the procedures in the order that is indicated.
Table 4-1 Task Map: Configuring Solaris Volume Manager Software
Perform this procedure on each node in the global cluster.
# pkg publisher PUBLISHER TYPE STATUS URI solaris origin online solaris-repository
For information about setting the solaris publisher, see Set the Publisher Origin to the File Repository URI in Copying and Creating Oracle Solaris 11.1 Package Repositories.
# pkg install system/svm
Use the physical name (cNtXdY sZ), not the device-ID name (dN), to specify the slices to use.
phys-schost# metadb -af slice-1 slice-2 slice-3
Tip - To provide protection of state data, which is necessary to run Solaris Volume Manager software, create at least three replicas for each node. Also, you can place replicas on more than one device to provide protection if one of the devices fails.
See the metadb(1M) man page and Creating State Database Replicas in Solaris Volume Manager Administration Guide for details.
phys-schost# metadb
The metadb command displays the list of replicas.
Example 4-1 Creating State Database Replicas
The following example shows three state database replicas. Each replica is created on a different device.
phys-schost# metadb -af c0t0d0s7 c0t1d0s7 c1t0d0s7 phys-schost# metadb flags first blk block count a u 16 8192 /dev/dsk/c0t0d0s7 a u 16 8192 /dev/dsk/c0t1d0s7 a u 16 8192 /dev/dsk/c1t0d0s7
Next Steps
Go to Creating Disk Sets in a Cluster to create Solaris Volume Manager disk sets.
