Skip Headers
Oracle® Fusion Middleware Man Page Reference for Oracle Directory Server Enterprise Edition
11g Release 1 (11.1.1.7.0)
Part Number E28967-01
Go to Documentation Home
Home
Go to Table of Contents
Contents
Go to Index
Index
Go to Feedback page
Contact Us
Go to previous page
Previous
Go to next page
Next
PDF · Mobi · ePub
max-simultaneous-operations-per-connection
Directory Proxy Server configuration property
Description
Characteristic Value
Syntax
integer
Default value
unlimited
Must be set
No
Is modifiable
Yes
Is multivalued
No
Requires restart
No
This property specifies the maximum number of simultaneous operations per connection that is allowed by the associated connection handlers.
This property takes an integer.
The value of this property must be at least 1.
The default behavior for this property is as follows: No limit
This property is used to configure the following features:
resource-limits-policy
Resource limit policies define the maximum resources that Directory Proxy Server can process for a given connection handler.
Attributes
ATTRIBUTE TYPE ATTRIBUTE VALUE
Availability
SUNWdsee7
Stability Level
Evolving
See Also
dpconf(1M)
