Run a baseline update to remove promoted dimensions from auto-generated state files.
After you promote auto-generated dimension values, you must run a baseline update with Forge's
--pruneAutoGen
flag. The flag cleans out any promoted dimensions from the auto-generated state files. This step is necessary in order to avoid any potential duplicate dimensions in your output records.
To clean up after promoting auto-generated dimensions:
