Skip Navigation Links
Exit Print View
SPARC and Netra SPARC T5 Series Servers
Security Guide
Oracle Technology Network
Library
PDF
Print View
Feedback
search filter icon
search icon
Document Information
Understanding Hardware Security
Access Restrictions
Serial Numbers
Hard Drives
Understanding Software Security
Physical isolation and access control are the foundation on which you should build the security architecture. Ensuring that the physical server is installed in a secure environment protects it against unauthorized access. Likewise, recording all serial numbers helps to prevent theft, resale, or supply chain risk (that is, injection of counterfeit or compromised components into your organization's supply chain).
These sections provide general hardware security guidelines for the SPARC T5-1B, T5-2, T5-4, T5-8, and Netra SPARC T5-1B servers.
