Go to main content
Oracle® ILOM Quick Reference for CLI Commands Firmware Release 3.2.x
Exit Print View
Updated: May 2016
Host and System Control
Table 2  Host and System Control Commands
Task
CLI Command
Power on the server
start /System
Power off the server
stop [-force] /System
Power cycle the server
reset /System
Redirect host console stream to Oracle ILOM
start /HOST/console
Force PXE boot on next boot (x86 only)
set /HOST boot_device=pxe
Force boot to CD-ROM or DVD on the next boot (x86 only)
set /HOST boot_device=cdrom
Setting diagnostic tests to run.
Use the /HOST/diag target to set diagnostic tests.
Use the help command to determine the host diagnostic properties supported on the server.
help /HOST/diag
