This host driver release supports Oracle HCAs as well as third-party manufacturers' HCAs with the requirement that the HCAs use the required version of firmware. Refer to the HCA's product notes for latest firmware versions.
Supported Oracle HCAs include:
Sun InfiniBand Dual Port 4x QDR PCIe Low Profile Host Channel Adapter M2. Refer to http://docs.oracle.com/cd/E19241-01/index.html for documentation.
Sun InfiniBand Dual Port 4x QDR PCIe ExpressModule Host Channel Adapter M2. Refer to http://docs.oracle.com/cd/E19157-01/index.html for documentation.
Oracle Dual Port QDR InfiniBand Adapter M3. Refer to http://docs.oracle.com/cd/E40985_01/index.html for documentation.
For third-party HCAs, consult the manufacturer's documentation for the required firmware version.
