Downloading and Installing
the Host Drivers
These topics describe how to download and install the host drivers for UEK and RHCK.
Oracle virtual networking supports both UEK and RHCK that are distributed with Oracle
Enterprise Linux ISO. The following table describes the installation and configuration
differences between the two kernels.
Oracle virtual networking host drivers are embedded with Oracle
Linux 7.0 OS.
Oracle virtual networking host drivers are unbundled and not
embedded into Oracle Linux 7.0 OS.
Host drivers are not stand-alone RPMs that you need to
install.
Host drivers are a separate, stand-alone package (for example, an
individual RPM) that you must install after the OS is
installed.
Embedded host drivers must be activated. You must install
userspace_RPM to activate the host
drivers.
After the host driver package is installed, you must reboot the
host to load the host driver package into memory.
