Configuring the RIP Topology Example
Configuring the RIP Packet Retransmission Interval and Retry Count
Set the RIP Packet Retransmission Interval and Retry Count
Reset the Retransmission Interval and Retry Count
Configuring the RIP Passive Interface
Enable the RIP Passive Interface
Disable the RIP Passive Interface
Configuring the Default Metric
Managing the auto-summary Option
Disable the auto-summary Option
Enable the auto-summary Option
Configuring Interface-Specific RIP Parameters
Configuring Interface-Specific Authentication
Configuring the RIP Default Route Propagation
Configuring the Version for Receiving RIP Advertisement
Configuring the Summary Address
Configuring the split-horizon Option
SEFOS# configure terminal
SEFOS(config)# router rip SEFOS(config-router)# network 10.0.0.1 SEFOS(config-router)# exit
SEFOS# show ip rip statistics RIP Global Statistics: ---------------------- Total number of route changes is 0 Total number of queries responded is 0 Total number of dropped packets is 0 RIP Interface Statistics: ------------------------- Interface Periodic BadRoutes Triggered BadPackets Admin IP Address Updates Sent Received Updates Sent Received Status ----------- ------------ --------- ------------ ---------- ------ 10.0.0.1 11 0 0 0 Enabled
SEFOS# show ip rip database 10.0.0.0/8[1] summary route 10.0.0.0/16 directly connected, vlan1
