Configuring the RIP Topology Example
Configuring the RIP Packet Retransmission Interval and Retry Count
Set the RIP Packet Retransmission Interval and Retry Count
Reset the Retransmission Interval and Retry Count
Configuring the RIP Passive Interface
Enable the RIP Passive Interface
Disable the RIP Passive Interface
Configuring the Default Metric
Managing the auto-summary Option
Disable the auto-summary Option
Enable the auto-summary Option
Configuring Interface-Specific RIP Parameters
Enable Interface-Specific Authentication
Enable Authentication on Both Switches
Disable Interface-Specific Authentication
Configuring the RIP Default Route Propagation
Set the Default Route Propagation
Test the Default Route Origination and Installation
Configuring the Version for Receiving RIP Advertisement
Configuring the Summary Address
Test the Summary Address Configuration
Configuring the split-horizon Option
Configure the split-horizon Option
Enable the split-horizon Option With Poison Reverse
Disable the split-horizon Option
