Skip Navigation Links
Exit Print View
Sun Ethernet Fabric Operating System
RMON Administration Guide
search filter icon
search icon
Document Information
Using This Documentation
Product Notes
Related Documentation
Acronyms and Abbreviations
CLI Command Modes
Feedback
Support and Accessibility
RMON Overview
Protocol Description
Topology Example
Configuring RMON
Enabling the RMON Module
Enable the RMON Module
Disable the RMON Module
Configuring the Ethernet Statistics Group
Enable the Ethernet Statistics Group
Disable the Ethernet Statistics Group
Configuring the Ethernet History Group
Enable the Ethernet History Group
Disable the Ethernet History Group
Configuring Events
Create an Event
Disable an Event
Configuring Alarms
Create an Alarm
Disable an Alarm
Create an Alarm
To create an alarm, you must configure these parameters:
You must create an event table entry before you can create an alarm. For instructions on how to create an event, see Create an Event.
  1. Create an alarm for absolute samples.
    SEFOS(config)# rmon alarm 1 1.3.6.1.2.1.16.1.1.1.6.1 20 absolute rising-threshold 500 1 falling-threshold 200 2 owner myTest
  2. Create an alarm for delta samples.
    SEFOS(config)# rmon alarm 2 1.3.6.1.2.1.16.1.1.1.7.1 25 delta rising-threshold 200 falling-threshold 100 owner system
  3. Review the alarm configuration.
    SEFOS# show rmon alarms
    RMON is enabled
    Alarm 1 is active,  owned by myTest
     Monitors 1.3.6.1.2.1.16.1.1.1.6.1 every 20 second(s)
     Taking absolute samples, last value was 837
     Rising threshold is 200, assigned to event 1
     Falling threshold is 100, assigned to event 2
     On startup enable rising alarm
     Alarm 2 is active,  owned by system
     Monitors 1.3.6.1.2.1.16.1.1.1.7.1 every 25 second(s)
     Taking delta samples, last value was 201
     Rising threshold is 100, assigned to event 1
     Falling threshold is 50, assigned to event 2
     On startup enable falling alarm
