Skip Navigation Links | |
Exit Print View | |
Sun Ethernet Fabric Operating System OSPFv3 Administration Guide |
Configuration and Testing Topologies
IPv6 Example Topology Interface and Host Addresses
Creating the Base Configuration
Access Global Configuration Mode
Access Interface Configuration Mode
Enabling IPv6 Support and Assigning IPv6 Addresses
Configuring IPv6 Static Routes
Creating the Base Configuration for Example Topologies
Configuring OSPFv3 Interface Parameters
Restore the Default Interface Priority
Configure the Retransmission Interval
Restore the Default Retransmission Value
Restore the Default Transmission Delay
Restore the Default Hello Interval
Restore the Default Dead Interval
Restore the Default OSPF Network Type
Restore the Default Interface Cost
Remove the Demand Circuit Setting
Enable Neighbor Probing on a Demand Circuit
Remove Neighbor Probing on a Demand Circuit
Configuring Neighbor Probe Values
Configure the Neighbor Probe Retransmission Limit
Restore the Default Neighbor Probe Retransmission Limit
Configure the Neighbor Probe Interval
Restore the Default Neighbor Probe Interval
Configuring a Passive Interface
Configure All Interfaces To Be Passive
Configure Specified Interfaces To Be Passive
Restore the Default Routing Updates
Configuring Route Redistribution
Configure Route Redistribution
Configure the Stub Area, ASBR, and Route Distribution
Configuring Attributes for Redistributed Routes
Configure Redistributed Route Attributes
Delete Redistributed Route Attributes
Configuring the Redistribution of Routes
Restore the Default Redistribution Configuration
Configuring Area Route Summarization
Configure Address Range Aggregation
Configure an Internal Address Range
Disable an Internal Address Range
Convert a Stub Area to a Normal Area
Configure a Default Summary Route for a Stub Area
Configure the Default Summary Route Cost for a Stub Area
Configure the Stability Interval for NSSA
Restore the Default Stability Interval
Configure an NSSA Translation Role
Restore the Default Translation Role
Configure Default Summary Route for an NSSA
Configure the Metric Type for an NSSA
Configuring the Capability in an NSSA Internal Border Router
Configure NSSA Type-7/-5 Conversion
Configure Virtual Link and Route Summarization
Configuring External Database Limit
Configure the External Database Limit
Restore the Default External Database Limit
Configuring the Overflow Exit Interval
Configure the Overflow Exit Interval
Configuring a Demand Extension
OSPFv3 adds support for IPv6 in the OSPF routing protocol, as described in RFC 2740. Most configurations and operational commands function essentially the same in OSPFv3 as they do in OSPFv2. For example, OSPFv3 router IDs, area IDs, and LSA link state IDs are 32 bits, just as they are in OSPFv2 IPv4. In addition, all of the optional capabilities of OSPFv2 for IPv4, for example, NSSA, are supported in OSPFv3 for IPv6.
However, there are also many significant changes in OSPFv3 for IPv6, including the following:
Router LSAs and network LSAs no longer carry prefix information. In OSPFv3, these LSAs carry only the topology information.
New and modified LSAs have been created to handle the flow of IPv6 addresses and prefixes in an OSPFv3 network.
OSPFv3 runs on a per-link basis, instead of a per-IP-subnet basis.
IPv6 link-local addresses are used for OSPFv3 neighbor exchanges, except over virtual links.
The flooding scope for LSAs is generalized into three categories for OSPFv3:
Link-local scope. The OSPFv3 packet is flooded only to the members connected on a link.
Area scope. The OSPFv3 packet is flooded to all members of an OSPFv3 area.
AS scope. The OSPFv3 packet is flooded to all members of an AS.
Authentication is removed from the OSPFv3 protocol. Instead, OSPFv3 relies on the AH and ESP portions of the IPSec for all authentication tasks in IPv6.
LSPs and traffic engineering are not supported in OSPFv3.
The 32-bit router ID in OSPFv3 always identifies neighboring routers.
