| Skip Navigation Links | |
| Exit Print View | |
Sun Ethernet Fabric Operating System IEEE DCBX Administration Guide |
Verifying DCB and LLDP Configurations
Determine Whether Interfaces Are Active
Determine Whether LLDP is Running and Recognizing Peers
Disable DCB for Each Interface
Enable and Disable a Specific DCB Feature
Configure the Mode for the DCB Feature
Show DCBX Feature Statistics and Control Information
For late-breaking information and known issues about the following products, refer to the product notes at:
Oracle Switch ES1-24:
http://www.oracle.com/goto/ES1-24/docs
Sun Network 10GbE Switch 72p:
http://www.oracle.com/goto/SN-10GbE-72p/docs
Sun Blade 6000 Ethernet Switched NEM 24p 10GbE:
