Skip Navigation Links
Exit Print View
Oracle SuperCluster M6-32 HTML Owner’s Guide
search filter icon
search icon
Document Information
Using This Documentation
Product Documentation Library
Feedback
Overview
Determining SuperCluster M6-32 Configurations
Configuration Flowchart
Determine the Number of Compute Servers
Determine the Number of DCUs in Each Compute Server
Determine the Number of CMUs in Each DCU
CMU Overview
Determine the Amount of Memory in Each DCU
Determine the PDomain Configuration on Each Compute Server
Determine the LDom Configuration for Each PDomain
Determining the Best Configuration for Your Situation
Understanding PDomain Configurations
Understanding High Redundancy
Allocating CPU Resources for LDoms
Allocating Memory Resources for LDoms
Understanding PCIe Cards and Slots for LDoms
Understanding Storage for LDoms
Understanding the Hardware
Understanding SuperCluster M6-32
Identifying SuperCluster M6-32 Components
Understanding DCUs
DCU Overview
Understanding DCU Configurations
Understanding Half-Populated DCU Root Complexes
Understanding Fully-Populated DCU Root Complexes
Understanding PDomains
PDomains Overview
PDomain Guidelines
Extended Configuration PDomain Overview
Understanding Extended Configuration PDomains
Base Configuration Overview
Understanding Base Configuration PDomains
Understanding LDoms
Understanding Compute Server Hardware and Networks
Understanding Domains
Understanding LDom Configurations for Extended Configuration PDomains
Understanding LDom Configurations for Base Configuration PDomains
Understanding Clustering Software
Cluster Software Overview
Cluster Software for the Database Domain
Cluster Software for the Oracle Solaris Application Domains
Understanding System Administration Resources
Oracle ILOM Overview
Understanding Platform-Specific Oracle ILOM Features
Oracle Solaris OS Overview
OpenBoot Overview
Oracle ILOM Remote Console Plus Overview
Oracle Hardware Management Pack Overview
Time Synchronization and NTP Service
SNMP Service
Multidomain Extensions to Oracle ILOM MIBs
LDAP/SSL
Active Directory
Hardware Installation
Installing SuperCluster M6-32
Hardware Installation Overview
Weight Specifications
Hardware Installation Task Overview
Hardware Installation Documents
Preparing the Site (Storage Rack and Expansion Racks)
Prepare the Site for the Racks
Storage Rack Components
Physical Specifications
Reviewing Power Requirements
Preparing for Cooling
Preparing the Network
Network Topology
Network Infrastructure Requirements
Compute Server Default Host Names and IP Addresses
Install Cable Drops
Prepare DNS
Cabling SuperCluster M6-32
Compute Server Network Components
Storage Rack Network Components
Cable the ZFS Storage Appliance
ZFS Appliance Power Cord Connection Reference
ZFS Storage Appliance Cabling Reference
Cable IB Switches
Leaf Switch 1 Cabling Reference
Leaf Switch 2 Cabling Reference
IB Switch-to-Switch Cabling Reference
Cable the Ethernet Management Switch
Ethernet Management Switch Cabling Reference
Connect SuperCluster M6-32 to the Facility Networks
Connecting Expansion Racks
Expansion Rack Overview
Expansion Rack Components
Expansion Rack Layouts
Installing Expansion Racks
One Expansion Rack Cabling
Two Expansion Racks Cabling
Three Expansion Racks Cabling
Four Expansion Racks Cabling
Five Expansion Racks Cabling
Six Expansion Racks Cabling
Seven Expansion Racks Cabling
Expansion Rack Default IP Addresses
Understanding Internal Cabling (Expansion Rack)
Administration
Understanding SuperCluster Software
Identify the Version of SuperCluster Software
SuperCluster Tools
Controlling SuperCluster M6-32
Cautions
Power On SuperCluster M6-32
Powering Off SuperCluster M6-32 Gracefully
Power Off SuperCluster M6-32 in an Emergency
Monitoring SuperCluster M6-32 (OCM)
OCM Overview
Access OCM Documentation
Monitoring the System With ASR
ASR Overview
ASR Resources
ASR Installation Overview
Configure ASR on the Compute Servers (Oracle ILOM)
Configure SNMP Trap Destinations for Storage Servers
Configure ASR on the ZFS Storage Appliance
Configuring ASR on the Compute Servers (Oracle Solaris 11)
Approve and Verify ASR Asset Activation
Tuning SuperCluster M6-32
ssctuner Overview
Monitor ssctuner Activity
View Log Files
Change ssctuner Properties and Disable Features
Install ssctuner
Enable ssctuner
Configuring CPU and Memory Resources (osc-setcoremem)
osc-setcoremem Overview
Minimum and Maximum Resources (Dedicated Domains)
Supported Domain Configurations
Plan CPU and Memory Allocations
Display the Current Domain Configuration (osc-setcoremem)
Display the Current Domain Configuration (ldm)
Change CPU/Memory Allocations (Socket Granularity)
Change CPU/Memory Allocations (Core Granularity)
Park Cores and Memory
Access osc-setcoremem Log Files
View the SP Configuration
Revert to a Previous CPU/Memory Configuration
Remove a CPU/Memory Configuration
Obtaining the EM Exadata Plug-in
Confirm System Requirements
Known Issues With the EM Exadata Plug-in
Configuring the Exalogic Software
Exalogic Software Overview
Prepare to Configure the Exalogic Software
Enable Domain-Level Enhancements
Enable Cluster-Level Session Replication Enhancements
Configuring Grid Link Data Source for Dept1_Cluster1
Configuring SDP-Enabled JDBC Drivers for Dept1_Cluster1
Create an SDP Listener on the IB Network
Administering Oracle Solaris 11 Boot Environments
Advantages to Maintaining Multiple Boot Environments
Create a Boot Environment
Mount to a Different Build Environment
Reboot to the Original Boot Environment
Create a Snapshot of a Boot Environment
Remove Unwanted Boot Environments
Administering DISM
DISM Restrictions
Disable DISM
Administering Storage Servers
Monitor Write-through Caching Mode
Shut Down or Reboot a Storage Server
Drop a Storage Server
Glossary
Index
Caution
Caution - Do not perform this procedure without Oracle Support approval. Changing properties or disabling ssctuner features can have unpredictable consequences.
Changing certain ssctuner properties such as EMAIL_ADDRESS and disk or memory usage warning levels might be advantageous in some environments.
  1. List the ssctuner properties to identify the property you want to change.
    # svccfg -s ssctuner listprop 'ssctuner_vars/*'
    ssctuner_vars/CRIT_THREADS_FIX          boolean     true
    ssctuner_vars/CRIT_THREADS_NONEXA       boolean     false
    ssctuner_vars/DISK_SPACE_CHECK          boolean     true
    ssctuner_vars/DISK_USAGE_CRIT           integer     90
    ssctuner_vars/DISK_USAGE_WARN           integer     85
    ssctuner_vars/DISM_CHECK                boolean     true
    ssctuner_vars/EMAIL_ADDRESS             astring     root@localhost
    ssctuner_vars/EMAIL_MESSAGES            boolean     true
    ssctuner_vars/FORCELOAD_VDC             boolean     false
    ssctuner_vars/INTRD_DISABLE             boolean     true
    ssctuner_vars/ISCSI_TUNE                boolean     true
    ssctuner_vars/MAJOR_INTERVAL            integer     120
    ssctuner_vars/MEM_USAGE_CRIT            integer     97
    ssctuner_vars/MEM_USAGE_WARN            integer     94
    ssctuner_vars/MINOR_INTERVAL            integer     2
    ssctuner_vars/NDD_TUNE                  boolean     true
    ssctuner_vars/NFS_CHECK                 boolean     true
    ssctuner_vars/NFS_EXCLUDE               astring
    ssctuner_vars/NFS_INCLUDE               astring
    ssctuner_vars/NTPCONF_TUNE              boolean     true
    ssctuner_vars/POWERADM_DISABLE          boolean     true
    ssctuner_vars/SDCONF_TUNE               boolean     true
    ssctuner_vars/SERD_THRESHOLD_TUNE       boolean     true
    ssctuner_vars/SSDCONF_TUNE              boolean     true
    ssctuner_vars/SYSLOG_DUP_SUPPRESS_HOURS integer     8
    ssctuner_vars/SYSTEM_TUNE               boolean     true
    ssctuner_vars/ZPOOL_FIX                 boolean     true
    ssctuner_vars/ZPOOL_NAME_CUST           astring
  2. Use the svccfg command to change property settings.
    These are examples of properties you might need to change:
    • Configure the system so that critical messages are sent to your email address.
      ~# svccfg -s ssctuner setprop ssctuner_vars/EMAIL_ADDRESS="my_name@mycorp.com"
    • Change the disk (/ and zone roots) usage warning level to 80%.
      ~# svccfg -s ssctuner setprop ssctuner_vars/DISK_USAGE_WARN=80
    • Enable thread priority changing for non-exa Oracle DB domains:.
      ~# svccfg -s ssctuner setprop ssctuner_vars/CRIT_THREADS_NONEXA=true
    • Enable zpool check and repair of vdisk zpools that are not generated by the SuperCluster installer.
      ~# svccfg -s ssctuner setprop ssctuner_vars/ZPOOL_NAME_CUST=my_vdisk_pool
    • Exclude NFS mounts from warning mechanisms.
      ~# svccfg -s ssctuner setprop ssctuner_vars/NFS_EXCLUDE='mount_name_or_device'
    • Include NFS mounts in warning mechanism (overrides exclude).
      ~# svccfg -s ssctuner setprop ssctuner_vars/NFS_INCLUDE='mount_name_or_device'
    • Disable all NFS mount warnings (not recommended).
      ~# svccfg -s ssctuner setprop ssctuner_vars/NFS_CHECK=false
    The NFS_EXCLUDE, NFS_INCLUDE and ZPOOL_NAME_CUST properties must be simple strings but you can use simple regular expressions.
    If you need the flexibility of regular expressions, be extremely careful to double quote the expressions. Also verify that the ssctuner service comes back after restarting and no errors are in the SMF log file.
  3. Restart the SMF service for changes to take effect.
    # svcadm restart ssctuner
  4. Ensure that the ssctuner service is enabled and no error messages are reported.
    If you changed a property using an incorrect syntax, the service does not come back. If this happens, identify the offending property that you must fix:
    # grep -i parameter /var/svc/log/site-application-sysadmin-ssctuner:default.log
    After making any corrections or changes, repeat Step 3.
Related Information
