Skip Headers
Oracle® Communications Design Studio Modeling Activation
Release 7.2.4
Go to Design Studio Help Home
Go to Table of Contents
Go to Feedback page
Go to previous page
Go to next page
Mobi · ePub
Defining Action Processor Properties
You can configure action processor properties using the Action Processor editor.
To define properties and parameters for action processors:
  1. In the Studio Projects view, double-click an action processor entity.
    The Action Processor editor appears.
  2. In the Description field, enter a description for the editor.
  3. From the list, select the type.
    Java Action Processor (with Code Generation) is the default value.
  4. Depending on the type you selected, define the remaining parameters.
    For example, if you select the Java Action Processor, define the class and method.
  5. Select File, then select Save.
Related Topics
Creating Model Elements
Creating Activation Run-Time Type Parameters in the Data Dictionary
Configuring Element Properties
Modeling ASAP Services
Action Processor Editor
