Use the Properties tab to configure cartridge properties and network element details. See "Project Editor Properties Tab" for more information about fields in this tab that are not specific to ASAP.
In Activation, the Default field is not applicable.| Field | Use |
| Cartridge Type | Displays the cartridge type (Activation Service Cartridge or Activation Network Cartridge) selected on the New Studio Activation Cartridge Project wizard. |
| Vendor, Technology, and Software Load | Displays as specified in the New Studio Activation Cartridge Project wizard. In case of a new network element version you can change the vendor, technology, and software load. This allows you to reuse the cartridge. |
| Supported Hardware Models | Specify which network elements the cartridge supports. |
