Connector Specifications
Refer to the following table for information about the connector specifications for the Acme Packet 6300/6350.
Table 7-8 Acme Packet 6300/6350
| Specification | Description |
| RJ45/Management Ethernet Ports | The 3 x 8-pin RJ45 10/100/1000BaseT Ethernet ports are compliant with IEEE's 802.3, 802.3u, and 802.3ab. |
| RJ45/Alarm Contact Port | Any alarms generated by the system are accessible via the 8-pin RJ45 alarm contact port. |
| RS232/Serial Port | The RS232 serial port uses an 8-pin RJ45 connector that supports RS232-C protocol. |
| 10GbE Port(s) | The 10GbE fiber optic connection ports use duplex LC connectors. |
| IEC Connector Ports | The IEC connector ports accept a 3-lead IEC-320 connector for AC power installations. |
