Environmental Specifications
For the Acme Packet 6300/6350 to function properly, Acme Packet recommends that you follow the environmental guidelines in the following table.
Table 7-7 Acme Packet 6300/6350 Environmental Specifications
| Specification | Description |
| Temperature | The
System is required to operate within the temperature range of:
* +0° C to +40° C, 32° F to 104° F (operating) * -20° C to +65° C, -4° F to 149° F (storage) |
| Relative Humidity | Operating conditions of 10% to 85% humidity under non-condensing operating conditions |
| Maximum Altitude | The Acme Packet 6300/6350 System is required to operate below the maximum altitude of 10,000 feet. |
| Air Flow | 300 CFM |
| Power Dissipation | 250W typical 350W maximum (base
system with 2x10 G NIU)
Additional 150W for second 2 x 10GbE NIU Additional 275W for each fully populated transcode carrier card |
