INTERFACE Menu
The INTERFACE menu allows you to scroll through a list of all configured physical interfaces. The management and media physical interfaces appear in the list, as does the loopback interface.
The following information is displayed for each configured interface to which you scroll:
- Interface slot and port: interface status
- Input packets, output packets
- Input error packets, output error packets
Slot 1: Port0 UP
PKT IN: 1,001K OUT: 223K
ERR IN: 0 OUT: 0
To exit the INTERFACE menu in the graphic display:
- From the top menu of the graphic display, press the Enter button.
- Press the Up or Down button to scroll to the INTERFACE selection.
- Press the Enter button.
- Press the Up or Down button to scroll through the list of configured physical interfaces.
- Press the Enter button to refresh the display.
- Press the Up or Down button to scroll to the RETURN selection.
- Press the Enter button to return to the Top Menu.
