PreviousNextJavaScript must be enabled to correctly display this content
Top Menu
The top menu provides top-level access to information in
distinct categories of system functionality.
To access the top menu from the base display or alarm
display:
Press the
Enter button. The
first entry in the top menu appears.
Press the
Up and
Down buttons to
scroll through the top menu categories. The top menu rolls over when you reach
the top or bottom of the menu.
The top menu displays only one category at a time. You
press the
Enter button to
select a displayed category and show its submenu information.
Scrolling Through Menu Categories on the Graphic
Display
After 30 seconds of displaying a menu option or
submenu information without any user input, the system automatically returns to
the base display during normal operating conditions, or to the alarm display
during an alarm condition.
The following diagram shows the complete menu of
options available from the graphic display. Lines in black indicate results
from pressing the
Up or
Down buttons. Lines
in blue indicate results from pressing the
Enter button.
