PreviousNextJavaScript must be enabled to correctly display this content
Installing the Chassis Ears and Slides
In this second portion of system installation, two
chassis ears and two chassis slides are secured to the
Acme Packet 6300/6350.
To install the chassis slide rails on the
Acme Packet 6300/6350:
Locate the
following components:
6 x 10-32 x 5/16” flat head (black) screws
2 x front mounting ears (left and right)
6 x 6-32 x 5/16” screws
2 x chassis slides
Line up one chassis
ear with the tapped holes as shown in the following image. Position the chassis
ear’s spring-loaded thumbscrew toward the front panel of the system.
Chassis Ear Mount Points
Use 3 x 10-32 x
5/16” Flat head screws to secure the chassis ear to the chassis. Final
installation resembles the image below.
Chassis Ear Installed
Line up the chassis
slide with the
side panel. Position the slide’s large marker hole at the front of the
chassis. The remaining three tapped holes will line up with the slide’s holes.
The following image points out the tapped holes.
Chassis Slide Rail Mount Points
Use 3 x 6-32 x
5/16” screws to secure the chassis slide rail to the chassis. Notice that the
large hole in the slide rail is positioned toward the front of the
Chassis Slide Rail Installed
Repeat steps 2-5
for the other side of the
