PreviousNextJavaScript must be enabled to correctly display this content
Rear-Mounting a Square Hole Rack Installation
To install the stationary slide rails on the rear of a
square hole equipment rack:
Locate the
following components:
4 x 10-32 x 5/8” screws
2 x nut bar
Expand and line up
the stationary slide rail end with three mounting slots on the outside of the
rear rack slide rail at the height used for the front mount point.
Rear Mount Point
Hold the nut bar
behind the rear rack slide rail.
Place 2 x 10-32
screws through the stationary slide rail ear and screw in place.
Repeat Steps 3 and
4 for the other mounting point.
Stationary Slide Rail Secured to Rear Mount Point
Repeat this
procedure for the rear of the other stationary slide.
