Prerequisites
In order to create a console connection to the Acme Packet 6300/6350 you need to configure the terminal hardware and software appropriately. The following table lists your terminal application’s serial configurations.
Table 5-1 Serial Connection Settings
| Serial Connection Parameter | Setting |
| Baud Rate | 115,200 bps |
| Date Bits | 8 |
| Parity | No |
| Stop Bit | 1 |
| Flow Control | None |
Your terminal application and serial port MUST be capable of operating at 115.2 Kbps for creating a console session.
