Creating a Console Connection
To create a console connection:
- Set the terminal application’s parameters to match the Acme Packet 6300/6350 default parameters listed in the table above.
- You must connect to the console port on initial booting of the Acme Packet 6300/6350.
- If the Acme Packet 6300/6350 is already powered on, press the Enter key a few times to activate the console connection. When ACLI text is displayed on the screen, the console connection has been successfully created.
- If you have created the console connection before powering up the Acme Packet 6300/6350, you can watch the boot process as it displays on your screen.
