Cabling Procedure
To connect Ethernet cables to the rear panel Ethernet ports:
- Locate the Ethernet cables you plan to connect to the Acme Packet 6300/6350.
Insert the RJ45
connector on the end of the Ethernet cable into one of the NIU management
Ethernet ports. These ports are labeled Mgmt0, Mgmt1, and Mgmt2. The release
tab on the RJ45 jack will click into place when you insert it properly.
Network Management Ethernet Ports
Route the cable
away from the
Make sure that the Ethernet cables are not stretched tightly or subject to
extreme stress.
Acme Packet 6300/6350 with a network management cable connected and inserted in Mgmt0.
Connected Network Management Port Cable
- Repeat Steps 1 through 2 for each additional management Ethernet cable you will connect to your Acme Packet 6300/6350.
