Network Management Ports
Standard shielded CAT5e or CAT6 (or higher) Ethernet cables with RJ45 jacks are used for connecting the Acme Packet 6300/6350 management Ethernet ports to your network. These ports support 10/100/1000 Mbps speeds.
Keep Ethernet cables separated from power cables by at least 60mm where possible and never run them in the same channel of a trunking system without segregation.
