Power Cycling
Power Cycling the Acme Packet 6300/6350 is the process of turning the chassis off and then turning it on by plugging and then unplugging the AC power cords from the power supplies. It is imperative that you wait at least 10 seconds between power down and power up to ensure that all components are completely powered down before restart.
Power cycling the Acme Packet 6300/6350 without performing a halt operation can lead to data loss to the storage device. To ensure stable operation a file system check will be performed on the next power up. This check may take several minutes to complete, and should not be interrupted.
