Standby Mode for HA Nodes
When performing hardware maintenance on the Acme Packet 6300/6350, it is best to minimize any risk of interrupting network traffic or losing data. If the Acme Packet 6300/6350 is configured as an HA node, you should only work on the Acme Packet 6300/6350 that is in standby mode.
There are two ways to determine the HA state of each Acme Packet 6300/6350 in an HA pair.
- If you are in the same physical location as the Acme Packet 6300/6350, you can view the graphic display on the front panel. The display will indicate the HA state. There is no (S) designation for an active system, but there is for a standby system.
If you are not in the same physical location as the
Acme Packet 6300/6350, you can use the ACLI
show health command. The output of this command indicates the current HA state of the
Acme Packet 6300/6350.
Once you have determined that the Acme Packet 6300/6350 due for maintenance is in standby mode, you can continue with the appropriate procedures to replace a part.
If you need to perform maintenance on the active Acme Packet 6300/6350, you need to manually force the two Acme Packet 6300/6350s to switch HA states. Performing a switchover forces the currently active Acme Packet 6300/6350 to standby mode while the current standby Acme Packet 6300/6350 will assume all traffic processing and forwarding as the active system.
This procedure is only applicable to Acme Packet 6300/6350 in an HA deployment.To force a Acme Packet 6300/6350 into the standby HA state:
Confirm that the relevant systems on SBC1 and SBC2 are synchronized with the
show health command. Type
show health and press Enter on each system.
system-1# show health Media Synchronized true SIP Synchronized true REC Synchronized disabled MGCP Synchronized disabled H248 Synchronized disabled XSERV Synchronized disabled Config Synchronized true Collect Synchronized disabled RADIUS CDR Synchronized true Rotated CDRs Synchronized true IPSEC Synchronized true Iked Synchronized disabled TSCF Synchronized disabled Active Peer Address Redundancy Protocol Process (v3): State Active Health 100 Lowest Local Address 169.254.1.2:9090 1 peer(s) on 2 socket(s): system-2: v3, Standby, health=100, max silence=1050 last received from 169.254.1.1 on wancom1:0 system-2# show health Media Synchronized true SIP Synchronized true REC Synchronized disabled MGCP Synchronized disabled H248 Synchronized disabled XSERV Synchronized disabled Config Synchronized true Collect Synchronized disabled RADIUS CDR Synchronized true Rotated CDRs Synchronized true IPSEC Synchronized true Iked Synchronized disabled TSCF Synchronized disabled Active Peer Address 169.254.2.2 Redundancy Protocol Process (v3): State Standby Health 100 Lowest Local Address 169.254.1.1:9090 1 peer(s) on 2 socket(s): system-1: v3, Active, health=100, max silence=1050 last received from 169.254.2.2 on wancom2:0 -
Confirm that SBC1 and SBC2’s current configurations match by typing
display-current-cfg-version
and press Enter at the ACLI prompt.
NETNETSBC1# display-current-cfg-version Current configuration version is 5 NETNETSBC1# NETNETSBC2# display-current-cfg-version Current configuration version is 5 NETNETSBC2#
While the two current configuration version numbers on the two systems MUST match each other, they do not have to match the shared running configuration version. -
Confirm that the running configuration of SBC1 and SBC2 match by typing
display-running-cfg-version and pressing Enter at the ACLI prompt.
NETNETSBC1# display-running-cfg-version Running configuration version is 5 NETNETSBC1# NETNETSBC2# display-running-cfg-version Running configuration version is 5 NETNETSBC2#
While the two running configuration version numbers on the two systems MUST match each other, they do not have to match the shared current configuration version. -
Initiate a switchover on SBC1 by typing
notify berpd force and pressing Enter at the ACLI prompt.
NETNETSBC1# notify berpd force -
Wait for SBC2 to transition to the standby state. Confirm that SBC2 is in the standby state by typing
show health and pressing Enter at the ACLI prompt.
NETNETSBC2# show healthRefer to the Upgrade section of the Maintenance and Troubleshooting Guide (400-0063-40A) for more information.
