| Skip Navigation Links | |
| Exit Print View | |
Sun Storage Common Array Manager Software Release Notes, Release 6.10 for Solaris OS Hosts |
1. CAM 6.10 Release Notes for Solaris OS
Controller and Disk Firmware Updates
Clearing Controller Recovery Mode
What You Get With the Software
Mixing Drive Speeds and Capacities
2500 Array Support for VMware ESX 4.1 with Firmware 07.35.55.10 and later
6540, 6140, and FLX380 Arrays Upgrade
Sun Storage F5100 Flash Array Notes
Controller Smart battery replacement procedure
Battery nears expiration: 06.xx write back cache should not be disabled
Both RAID controllers reboot after 828.5 days--2500/6000 arrays
Reboots occur due to ancient I/O being aborted in large configurations
Reregister Auto Service Request for CAM
Auto Service Request advisory note: DTS Listener transfer
Array name remains unchanged after a full array reset
Access Configuration: Cascaded J4400 issues
Access Configuration fails with error: java.util.HashMap cannot be cast to java.util.Properties
Access Configuration: non-zoned SAS2 wide port aggregation FRU Report display—F5100 + 6Gb/sec HBA
Array lock key must be set before configuration files are imported
ComponentInsertEvent not generated for disk drive inserted into J4200
Current Jobs page can take more than five minutes to display
Expander firmware 5.3.73 does not persist a SAS zone group
Replication status incorrect when primary volume fails
Service Advisor: replacing failed SIM with dual path configurations
Volumes not deleting from the Single Page window
Attempt to delete partner replication set on secondary array fails
Incorrect Windows server OS listed in CAM 6.9 Release Notes
Incorrect sscs add notification description in CLI guide
2500 Series Release Notes: Simplex vs. Duplex Configurations
Disk Locked description is inaccurate in online help
Firmware upgrade fails with error: FWR_UPGRADE_FAILURE,6 for J4200/J4400 arrays
Firmware upgrade fails on J4400 SATA drives
Firmware upgrade fails when expander and disks are upgraded together
Firmware upgrade not recognized by GUI until agent runs
Sun Blade 6000 firmware upgrade fails with down-level expander
Sun Blade 6250 and 6270—upgrading network expansion modules fails
Installation and Upgrade Issues
Error occurs when upgrading 2510 controller and drive firmware
Installation fails on SUSE 10.3 32-bit and 64-bit hosts
Solaris with Veritas DMP or other host type
Error—”no execute access to opt/SMgr/agent/ notifysmagent.sh”—occurs during system boot-up
UTM LUNs Controlled by “Solaris Traffic Manager” 6000/2500 arrays
System requirements for Sun Storage Common Array Manager software are described in the following sections:
Sun Storage Common Array Manager software supports the following Sun storage systems:
Sun Storage 6180 array
Sun Storage 6580 array
Sun Storage 6780 array
StorEdge 6130 array
StorageTek 6540 array
StorageTek 6140 array
Sun Storage 2530-M2 array
Sun Storage 2540-M2 array
StorageTek 2510 array
StorageTek 2530 array
StorageTek 2540 array
StorageTek FLX380 array
StorageTek FLX280 array
StorageTek FLX240 array
Sun Storage F5100 Flash array
Sun Storage J4200 array
Sun Storage J4400 array
Sun Storage J4500 array
Sun Blade 6000 Disk Module
Sun Blade 6000 Multi-Fabric Network Express Module
Sun Blade 6000 10GbE Multi-Fabric Network Express Module
Sun Blade 6000 Virtualized Multi-Fabric 10GbE Network Express Module
Table 1-3 Management Host Operating System Support
Table 1-4 Supported Web Browsers
If you install the CAM management host software on a Solaris 10 SPARC sun4v system, you might have problems accessing the CAM GUI using Firefox. To access the GUI using Firefox, log into the management host as root and enter the following:
wcadmin add -p -a se6130ui java.options="-D sun.security.pkcs11.enable- solaris=false"
svcadm disable webconsole
svcadm enable webconsole
For best web browser performance:
Enable pop‐up windows.
Specify No Proxy for the Sun Storage Common Array Manager host to avoid situations where your browser might hang, time out, or generate error messages. From Preferences > Advanced > Proxies (or a similar path, depending on your browser), add the Sun Storage Common Array Manager management host name to the “No Proxy for” section.
Recent Firefox versions might require you to accept and add a security certificate prior to bringing up the authentication page.
Because locales are part of the installation, there is no need to download additional software other than appropriate patches.
For Solaris, Linux, and Windows, the Browser User Interface (BUI) is available in:
English
French
Japanese
Simplified Chinese
Command-line interface (CLI) is available in:
English
Online help is available in:
English
Simplified Chinese
Japanese
Man pages are available in:
English
Japanese
To obtain patches for the SAS HBA using Solaris, install the following patches for Solaris 10 Update 9.
The mpt_sas driver requires these patches:
Oracle Solaris 10 10/09 plus patch 142676-02
Oracle Solaris 10 10/09 plus patch 143523-02
The mpt_sas driver also requires this Solaris 10 update:
Oracle Solaris 10 09/10 Update 9
See http://www.lsi.com/support/sun for information about LSI HBA packages.
