| Skip Navigation Links | |
| Exit Print View | |
Oracle® Storage 12 Gb/s SAS PCIe RAID HBA, Internal Security Guide For HBA Models 7110116 and 7110117 |
Oracle Storage 12 Gb/s SAS PCIe RAID HBA, Internal Security
After the initial installation and setup of the HBA, use Oracle hardware and software security features to continue controlling hardware and tracking system assets.
The following sections are included:
Use serial numbers to track inventory. Oracle embeds serial numbers in firmware on option cards and system motherboards. You can read these serial numbers through local area network connections.
You can also use wireless radio frequency identification (RFID) readers to further simplify asset tracking. Refer to an Oracle white paper, How to Track Your Oracle Sun System Assets by Using RFID.
Keep firmware versions current on your equipment.
Check regularly for updates.
All operating systems in general, and Oracle Solaris in particular, require you to log in with root credentials to administer the cards and to upgrade the drivers or firmware.
Always install the latest released version of the firmware.
Keep your software versions current on your equipment.
Software updates for Oracle Solaris drivers are available through Oracle Solaris patches and updates.
Software updates for drivers for other operating systems might be available from http://www.lsi.com/sep/Pages/oracle/index.aspx.
Refer to the HBA documentation, located at the Oracle website, for late-breaking news, information about software update requirements, or other security information.
Always install the latest released version of the software.
Install any necessary security patches for your software.
Devices also contain firmware and might require firmware updates.
Inspect and maintain your log files on a regular schedule.
Review logs for possible incidents and archive them in accordance with a security policy.
Periodically retire log files when they exceed a reasonable size. Maintain copies of the retired files for possible future reference or statistical analysis.
The HBA is managed by the LSI StorCLI command-line interface (CLI) or MegaRAID SAS graphical user interface (GUI) software. This software enables you to do the following:
Monitor HBA operation.
Update HBA firmware.
The StorCLI and MegaRAID SAS GUI software provide access only to users with root credentials. Therefore, unprivileged users cannot make changes to the SAN environment through the use of these utilities.
For information about the StorCLI CLI and MegaRAID SAS GUI, see the LSI documentation at the following website: http://www.lsi.com/sep/Pages/oracle/index.aspx
