You can use the custom distribution in Crystal Ball to represent a unique situation that cannot be described using other distribution types. It can describe a series of single values, discrete ranges, or continuous ranges.
Variable, see Using the Custom Distribution.
The custom distribution is used under these conditions:
For an example of a custom distribution, see the ClearView tutorial (Growth Rate Assumption: Custom Distribution). Also see Using the Custom Distribution.
