In the discrete uniform distribution, you know the minimum and maximum values and you know that all non-continuous values between the minimum and maximum are equally likely to occur. It can be used to describe a real estate appraisal or a leak in a pipe. It is the discrete equivalent of the continuous uniform distribution (Uniform Distribution).
The discrete uniform distribution is used under these conditions:
