You can save all open forecast windows and other charts as well as simulation data after you run a simulation in Crystal Ball. You can only save results after a simulation stops. Although only results are saved and not an entire model, restored results files are displayed in Crystal Ball chart, report, and Extract Data dialogs so you can work with them. You can run new charts and reports against them and extract their data to worksheets. Only results from the current simulation are saved.
Because the saved files contain only results and are not complete models, you can load more than one results file at a time and you do not need to reset the current simulation before loading results.
