previous
Configuration - Rate Code Header (cf_ratecodeheader with GENREPPAR.FMX)
The Configuration report Rate Code - Header will display Rate Header information of all Rate Codes that have been configured in the application.
Rate Codes are configured in Configuration>Rate Management>Rate Codes.
The following column headers map to these Checkboxes in the Application:
A - Package
N - Negotiated
E - Day Type
S - Suppress Rate
P - Print Rate
R - Redemption  (only if ORS is activated)
D - Day Use
M - Membership
C - Complimentary
H - House Use
G - GDS Allowed  (only if GDS is activated)
L - External Locked
Y - Yieldable
Rate Code
Rate Code. Single Select LOV to display a specific rate code. Leave this field blank to display all of the rate code.
