previous
Configuration - Rate Seasons (cf_rateseason with GENREPPAR.FMX)
The Configuration Report for Rate Seasons will display all Seasons that have been configured for the property.
Note: When the OPR <version number> ORS license code is active, the Select Property screen appears prior to the Report Parameters screen.  Choose the property you want to view and select the OK button.  The Report Parameters screen appears.
When the OPP <version number> PMS license code is active, Season Codes are configured in PMS in Configuration>Rate Management>Codes>Season Codes.
