Configuration - Reservation Types (cf_reservationtypes with CFG4.FMX)
Note: When printing this Report help topic, we recommend printing with Portrait page orientation.
The Configuration report for Reservation Types will display all Reservation Types that have been configured in the application.
Reservation Types are configured in System Configuration>Reservations>Codes>Reservation Types.
Active. Select the check box to include the active reservation types in the report.
Inactive. Select the check box to include the inactive reservation types in the report.
Preview. Select to preview the report in a PDF format.
Print. select to print the report.
File. Select to save the report as a file.
Close. Select to exit the specific report.
