Configuration - Room Classes (cf_roomclasses with GENREPPAR.FMX)
Note: When printing this Report help topic, we recommend printing with Portrait page orientation.
The Configuration report for Room Classes will display all Room Classes that have been configured in the application and that have at least one Room Type associated with them. The display of this report and the corresponding information is available when the General>Room Class application function is set to Y.
Room Classes are configured in Configuration>Reservations>Room Classes.
Preview. Select to preview the report in a PDF format.
Print. select to print the report.
File. Select to save the report as a file.
Close. Select to exit the specific report.
