Global 2000 Export Integrity Report (exp_gl2000_integrity with GEN1.FMX)
Note: When printing this Report help topic, we recommend printing with Landscape page orientation.
The Global 2000 Export Integrity Report assists the Six Continents hotels with the verification of their Global 2000 data prior to the transmission. Records listed on the report show discrepancies either related to the CRP account, the Six Continents Club, the Frequent Flyer Program, or the GEO1/SR1 entries. When the report is printed, a date prompt allows you to enter the start and end dates of the report. These dates refer to the departure dates of the guest record.
From Date. Select the from date for the report.
To Date. Select the from date for the report.
Preview. Select to preview the report in a PDF format.
Print. Select to print the report.
File. Select to save the report as a file.
Close. Select to exit the specific report.
