Incomplete Address (princompleteaddress with PRF6.FMX)
Note: When printing this Report help topic, we recommend printing with Portrait page orientation.
The Guests Incomplete Addresses Report displays all Profiles that have incomplete address information. A complete address is defined as populating at least one Address line, City, State, Postal Code and Country Code fields on the Profile. Use this report to track all incomplete Profile records in your system so you can either correct the address information, or purge the Profile from the system.
Name Range. Filter on a specific range of names. This is helpful if the property wants to cleanup profiles in a certain order. For example, all of the Profiles beginning with ‘A’.
Filter. Multi Select LOV allows the property to select the Profile Types they would like to review. Individual, Company, Travel Agent, Source, Group, or Contact.
