Go to main content
SPARC T7 Series Servers
Exit Print View
Updated: October 2015
Oracle System Firmware
The Oracle system firmware uses a controlled update process to prevent unauthorized modifications. Only the superuser or an authenticated user with proper authorization can use the update process.
For information on how to obtain the latest updates or patches, refer to the product notes for your server.
